    Workaround for "selectSelectionTool" Mac bug?
    6 Posts 3 Posters 436 Views 3 Watching
      jasef
      Hi all,
      I'm using SU 8 on Mac and I've noticed that when I do
      Sketchup.send_action "selectSelectionTool;"
      The selected tool in the floating SketchUp toolbar changes, but the one at the top of the model window does not.
      http://i.imgur.com/1rtGE.png
      In the above screenshot, you can see that the floating toolbar (left) has the selection tool, but the selected tool in the window toolbar (right) is still Rectangle. I can even click back and forth on the tools in the floating toolbar and the selected tool in the window bar doesn't change! (Until I "fix it" by selected a tool from that toolbar...)
      Any ideas for a workaround?
      Thanks,
      J
      • Dan RathbunD
        Dan Rathbun
        Well this should also work for ONLY the selectionTool
        Sketchup.active_model.select_tool(nil)
        ](https://developers.google.com/sketchup/docs/ourdoc/model#select_tool)":74a4ir3l]
        The select tool is returned if you pass nil to the select_tool method.
        Try that and report back. (I know it's not a fix for any tool 😞 )
        I'm not here much anymore.
          jasef
          Nope, same results. In the model window toolbar, the original tool stays visually selected even though the actual tool is now the selection tool (and the floating toolbar shows the selection tool is selected).
          It's some sort of refresh bug, annoying but doesn't hamper functionality...just afraid it'll confuse users that the cursor is now the selection tool even though that toolbar says otherwise.
          • Dan RathbunD
            Dan Rathbun
            @jasef said:
            It's some sort of refresh bug, ...
            try calling UI.refresh_inspectors() just after changing the tool ?
            The API docs say that if a model undo operation has disabled UI updates, then you can force a single UI update with this method.
              jasef
              Still no luck. And I just confirmed it's Mac-only, the toolbar refreshes correctly on Win...
              • bradB
                brad
                Howdy from Boulder,
                I do not see a bug in our database for this issue. I'll log a bug for you guys.
                Take care.
                Brad
                SketchUp QA
