    How to make a frame/dialog/window always on top?
    23 Posts 7 Posters 4.6k Views 7 Watching
      alexmojaki
      @thomthom said:
      show_modal will keep the WebDialog on top of the SketchUp window under OSX. But not on top of all other child windows of SketchUp.
      Well, for me it's not even showing on top of the main Sketchup window. I have no other dialogs open, the only other window is Sketchup itself. And when I click on it, the dialog disappears right behind it.
      @tig said:
      Your test
      if #the selection is appropriate# and sel.length>0
      Presumably you have some 'real code' in there... otherwise the line is
      if
      as everything after the first # is ignored ?
      Then you'll always get 'b'...
      Yes, I replaced the real code with the comment.
      @tig said:
      Also [incidentally] the
      path = Sketchup.find_support_file("scale.html",#...#)
      would be better as
      path = File.join(File.dirname(__FILE__), "scale.html")
      assuming it's in the same folder as the ruby script itself...
      Thanks, I'll give that a try.
      @chris fullmer said:
      No, you can draw it to the screen if you make your own 'tool'. Use the view.draw method of your tool class and you can do some pretty interesting things.
      BUT, that requires the user to be using your tool so they can see the info you've written to the screen. Once they switch to rotate or pan or select, move, etc the data disappears. So it is also flawed.
      Thanks, I'll consider that. But still not ideal, of course. Is that all then?
        hm... you sure you didn't use show()?
        If you try this base bone example:
        w=UI::WebDialog.new('test').show_modal
        If that doesn't produce a WebDialog that keep on top of SketchUp; what OSX do you have?
        Btw, while on topic of Webdialogs, have you seen this thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=23445#p198883
          alexmojaki
          Yes, I've seen the lost manual. What was critical to me at the beginning of the thread was that show in Windows kept the dialog on top (which isn't obvious), maybe add that to the manual.
          OK, I edited the wrong file when I was testing show_modal. So it works correctly. Then I discovered that the problem with my code is that for some reason when I reclick on the object to put Sketchup in focus, for some reason onSelectionCleared gets called, and then immediately after onSelectionBulkChange. I have no idea why: as far as I can see the selection never gets cleared. So the dialog was actually being closed, and then it wasn't opened again because I didn't edit @prevSelection when the selection was cleared. But now that I've done that, I'm back to the original problem: each time I click on the object to try and put Sketchup in focus, the dialog is closed and reopened and so regains focus.
          So now it seems my main problem is that the selection is momentarily cleared unnecessarily. In fact, I tested a bit more and found that it seems to get cleared pretty much all the time. It hasn't even got anything to do with the dialog or reclicking, onSelectionCleared gets called whenever I change my selection at all. I need to keep the definition because onSelectionBulkChange doesn't react to clicking an empty space. So I need a way to distinguish between the selection being genuinely cleared and this quirk. I considered InputPoint, but I've never used that before and I don't see how it can be used from the context of a SelectionObserver.
            hm... I've noticed that the Selection observers misbehaves: http://www.thomthom.net/software/sketchup/observers/
            (Btw - I have other observations I've not published yet. Available in the BitBucket repo: https://bitbucket.org/thomthom/sketchup-observers/issues?status=new&status=open)
              driven
              on the mac show_modal and bring_to_front appears on top of everything, so they're really the same except one returns 'true' and the other returns the object.
              > webdialog=UI;;WebDialog.new('blur_focus')
              #<UI;;WebDialog;0x110e2a48>
              > webdialog.show
              true
              > webdialog.show_modal
              true
              > webdialog.bring_to_front
              > webdialog.execute_script('window.focus()')
              true
              webdialog.execute_script('window.blur()')
              true
              > webdialog.close
              nil
              'window.focus()' and 'window.blur()' work with 'show', 'show_modal' or 'bring_to_front', so you can do stuff like
              > webdialog.set_html("Hi!")
              true
              > webdialog.set_html("Bye!")
              true
              true
              > webdialog.set_html("I'm going to hide!")
              webdialog.close
              true
              > webdialog.show
              true
              just say if I'm 'barking up the wrong tree'
              • Dan RathbunD
                Dan Rathbun
                Yup! Been there, done that, just yesterday, in fact (edited the wrong Js function and wondered why things did not change.)
                @alexmojaki said:
                Then I discovered that the problem with my code is that for some reason when I reclick on the object to put Sketchup in focus, for some reason onSelectionCleared gets called, and then immediately after onSelectionBulkChange. I have no idea why ... So now it seems my main problem is that the selection is momentarily cleared unnecessarily. ... onSelectionCleared gets called whenever I change my selection at all.
                This is expected. The selection must be cleared in order to receive the elements for the new selection, regardless of whether they are the same as the old selection.
                Sketchup::ToolsObserver
                The SelectionTool is tool id #21022
                You might get some benefit from watching the tool state (integer) changes.
                Also the Sketchup::Tools collection, might help.
                But be sure you always check that active_tool_id != 0 before attempting to access active_tool_name() (if active tool is undefined, trying to get a name string can BugSplat! SketchUp.)
                @alexmojaki said:
                Is wxSU my only option?
                Not for Mac, which is where you had the Z-order problem. AFAIK, it is still MS Windows only. (Unless they've gotten it working on the Mac now?)
                I'm not here much anymore.
                  Not the same. If you have a dialog opened with show then call bring_to_front then it will put the window at the top of the stack. But if you click the SketchUp window it'll appear above the WebDialog.
                  If you use show_modal then the webdialog will never drop behind the sketchup window.
                    driven
                    I stand corrected... if acting on a previously show_modal, then bring_to_front will stay on top.
                    ` > webdialog=UI::WebDialog.new('blur_focus')
                    webdialog.set_html("You'll only see me flash!
                    but I'll exist in a 'show_modal' state")
                    webdialog.close
                    nil
                    webdialog.set_html("You'll see me, and because I was 'show_modal' to start with, I'll behave like a 'show_modal' dialog!
                    However, I won't have focus, because 'window.blur()' has been called")
                    true`
                    My main point was that blur and focus can be set independently of the show-status.
                      alexmojaki
                      webdialog.execute_script('window.blur()') solves everything instantly. Did not know I could do that. Thanks a lot, driven!
                      Thanks also to others for staying with my problem for so long.
                      And yes, wxSU is available for Mac.
                      Incidentally, I haven't tested any of this on Windows yet, so we'll see what happens when I try there. This might not be over yet.
                        driven
                        @alexmojaki said:
                        [Thanks a lot, driven!
                        Glad to assist, I'm not a rubyist, but I do alot of mac testing, and ('window.blur()') buggered something up recently, so I tested ('window.focus()') to try to fix that and it was fresh in my mind... chance
                        whenever I've tested anything to do with wxSU it plays havoc on the mac, it can work, but little else will after installing it, I now treat it with the same contempt as a lot of people treat MacPorts... use at your own peril.
                          alexmojaki
                          Aaaand...I'm back! Indeed, this solution doesn't really work on Windows, because as soon as window.blur() is called, it doesn't just remove focus from the dialog, but from the whole Sketchup application! Sketchup goes into the background, yet somehow it is the window that is open according to the taskbar, and if you click on it in the taskbar to try and reopen it it minimises it.
                          • 2 / 2
