Antiqe streets of old Baghdad
aa
No pictures?
In general how many time for an image render ?
The painter's style are very cool
Super modelling & images Kais. i just feel the camera is too wide and extreme. I like the last image with the super brick texture best. I have recently started using sketchup's 2 point perspective option then i crop the picture (mostly bottom) and the verticals remain vertical it's worth a try if you have time.Or does Lumion not retain cameras from sketchup ?
That's how the camera is in Lumion, super wide with no 2 point perspective option. Which for an Architectural rendering software is a bit counter intuitive.
Not quite true, in the weather tab, you can edit the camera FOV, I guess Lumion starts at 15 in build mode but I feel 35 is a much better FOV for images. Also, Shift + H will zero the z on the camera which will straighten the verticals in the image, might look funny if you don't change the FOV but I would experiment. It's not a traditional 2 point perspective but it works.
Another tip, since it won't be obvious until version 3, is that in build mode you can 'save scenes' like in sketchup by pressing ctrl + (1 to 0) to save, then press that number to return to that camera. The cameras will then show up in the image export window.
Great program but as I've found has some hard to find functions so I hope this helps.
aa
