    One Submenu for many plugins
    4 Posts 2 Posters 682 Views 2 Watching
      kherv
      I Need some help.
      I wish to create the same submenu for some plugins.
      AS exemple:
      Plugin A
      Plugin B
      Plugin C
      For something like that:
      [pre:f9u5ni7z]Plugins
      -> Sub1
      -> sub11
      -> Plugin A
      -> plugin B
      -> Function Y
      -> Function Z
      -> sub12
      -> plugin C[/pre:f9u5ni7z]
      I tried something like that:
      plugin A:
      sub_1 = UI.menu( 'plugin' ).add_submenu( 'Sub1' )
      sub_11 = sub_1.add_submenu( 'sub11')
      sub_11.add_item("plugin A") {A}
      plugin B:
      Sub_Plug = sub_11.add_submenu( 'plugin B')
      Sub_Plug.add_item("Function Y") {Y}
      Sub_Plug.add_item("Function Z") {Z}
      plugin πŸ˜„
      sub_1 = UI.menu( 'plugin' ).add_submenu( 'Sub 1' )
      sub_12 = sub_1.add_submenu( 'sub12')
      sub_11.add_item("plugin C") {C}
      And it gives:
      -> Sub1
      -> sub11
      -> plugin A
      -> Sub1
      -> sub11
      -> plugin B
      -> Function Y
      -> Function Z
      -> Sub1
      -> sub12
      How can I do to fix this ?
      Thank you for the help and sorry for my bad english.
      Have a good day.
      • Dan RathbunD Offline
        Dan Rathbun
        Adding a 2nd level submenu:
        "Plugins/Kherv/pluginC/plugin_c.rb"
        module Kherv
          module PluginC
            require('Kherv/kherv_menu.rb')
            include(Kherv;;Menu)
            if SUBMENU['Sub 1/Sub 1.1']
              @sub = SUBMENU['Sub 1/Sub 1.1']
            else
              @sub = SUBMENU['Sub 1/Sub 1.1']= SUBMENU['Sub 1'].add_submenu('Sub 1.1')
            @sub.add_item('Item C') { # code here }
          end # submodule for PluginC
        πŸ’­
        I'm not here much anymore.
          Dan Rathbun
          Only create menu "Sub1" ONCE.
          (1) Write all your plugins so they are wrapped within YOUR toplevel module.
          "Plugins/Kherv/kherv_menu.rb"
          module Kherv
            module Menu # this is a "mixin" module
              TOPMENU ||= UI.menu('Plugins').add_submenu('Kherv')
              SUBMENU ||= {} # Hash to hold submenu references
              # hash keys can be menu paths like; "Kherv/Tools/Text"
          "Plugins/Kherv/pluginA/plugin_a.rb"
          module Kherv
            module PluginA
              if SUBMENU['Sub 1']
                @sub = SUBMENU['Sub 1']
              else
                @sub = SUBMENU['Sub 1']= TOPMENU.add_submenu('Sub 1')
              @sub.add_item('Item A') { # code here }
            end # submodule for PluginA
          "Plugins/Kherv/pluginB/plugin_b.rb"
          module Kherv
            module PluginB
              if SUBMENU['Sub 1']
              else
              @sub.add_item('Item B') { # code here }
            end # submodule for PluginB
            Dan Rathbun
            Although this should work.. because of current API bugs. It will not.
            See thread: http://sketchucation.com/forums/viewtopic.php?f=180&t=49912&p=449979#p449362
