    Georgia House
    29 Posts 10 Posters 3.1k Views 10 Watching
    • olisheaO Offline
      olishea
      I'm pretty sure he said thanks!
      oli
        the.pjt
        OK .. my english is not good ... I felt you disliked it ... so I became sad ....
        . πŸ˜‰
        I'm a little agree with you after observing this image trough OSX .. here it looks quiet dark and the only visible PPs are ref.s and lens flares ...
        ...you can turn off the lens flares or REFs or outher twiks .... but I recomend them ... they are good details
        here is the version with enhanced exposure It's tooo dark in osx ......but I have added several details ... but the only visible part with OSX is reflection and lens flare .....
        to moderators : you can move my posts to the PP forum ... my PSD file , It maybe use full for educational porposes . it's a free sample ,,.
        • olisheaO Offline
          olishea
          too much now! It wasn't too dark if that was the mood he is trying to produce. If it is dusk/evening, the sky is not bright. The foreground wouldn't be bright.
          I believe some simple foreground detail to the left would improve image massively. Road bump is a bit low and material is flat. All tarmac/asphalt has a slight reflection...not wet looking....but it has a very subtle sheen. Play with specular too as some variation in reflection is more realistic. If it very rarely rains in Cyprus, it would be wrong for him to represent the conditions as being wet. which is how the tarmac appears.
          pjt: constructive criticism is great, it helps us improve. I suggest the lens flare does not add anything to the image, I am not saying this in a bad way. Only the sun would cause a lens flare to this degree, but at night time, I can't see any artificial light causing a flare like this. Maybe some "star" like rays, but not a flare.
          Overall I think scene is almost too tidy, it needs imperfections; dirt, age, life. Hope this helps.
          oli
            the.pjt
            THANKS FOR TIPS ..,
            • cheddaC Offline
              chedda
              Updated image after architects feedback. PJT i used a subtle simulens in maxwell for diffraction in this image. Olisha thanks for the comments, your right about the road it needs a film.I think this one has more punch.
              Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
              • olisheaO Offline
                olishea
                That's significantly better!! Great work! The framing is nicer now. All it needs now.....maybe some age and dirt maps, still a bit too clean. Then I think you'll be there!
                Long exposure images like this look great with headlight streaks on the road, just a suggestion.
                Also, you see the green hue over the whole image? Levels will sort this immediately.
                http://ak.picdn.net/shutterstock/videos/584377/preview/stock-footage-headlights-at-sunset-on-highway-hd-time-lapse-clip.jpg
                Couldn't resist a quick PP...corrected levels, dirt and vignette added. Only 2 minutes. This kinda reminds me of my regas render: http://forums.sketchucation.com/viewtopic.php?f=81&t=27916&start=0 (look at the sheen on the concrete floor, it reflects the lights of the house beautifully....this is what I meant for your road.
                oli
                • cheddaC Offline
                  chedda
                  Thanks for the reply Olishea. I think colour casts and tints may be issues between all our monitors. I see a difference between my home and work monitor already (both apple) I can only imagine the difference between all our displays.For now the client and I are happy so i'll move to the next view. Thanks for the dirt advice, i noticed the white wall in the foreground is now more structured after your gentle PP, i think it helps.I have used long exposure night shots in the past, i am sure i will again. I remember all the cars wondering what i w` doing with my tripod next to the road. It was tricky using a remote shutter timing the shot to get a good streak of light. But in the end i had some success.
                  • jo-keJ Offline
                    jo-ke
                    what kind of sky did you use? Is it SU Beckground or an HDR sphere?
                    http://www.zz7.de
                    • cheddaC Offline
                      chedda
                      It's the physical sky which comes with maxwell.
                      • tademaT Offline
                        tadema
                        Another beauty πŸ˜„
                        John
                        • cheddaC Offline
                          chedda
                          Here is the rear view. Thanks John.
                          • tademaT Offline
                            tadema
                            Hello chedda, I really like this one, the warmth and mood πŸ‘ . Darken the grass a little and you've cracked it! That Doberman looks menacing again, it's a breed you never see over here anymore, maybe fell out of favor like most "fashion accessories" do.
                            John
                            • cheddaC Offline
                              chedda
                              Here is an interior from this project. Tadema the doberman is indeed a menacing beast. Our family always kept labradors, but if i had the time, space & climate i'd love a wolfhound (i don't think turbosquid stock them!).Your right about the grass if i have time i'll fall back on it. I look at this image and i'm not happy with the texture particulary the tiling also a skirting board may have helped. C&C welcome. This scene was a real wrestling match the super high poly sofa's crippled the scene. Sketchup would crash when launching, when saving almost doing anything. I spent a day almost doing nothing lol. I had to draw the line on 4 hours to adjust a texture and save !
                              • jason_marantoJ Offline
                                jason_maranto
                                This is when I would have unlocked the beta MXS referencing capabilities of the new plugin and at least tried it (no guaranteeing that it would work since it's beta, but still)...
                                http://www.maxwellrender.com/forum/viewtopic.php?f=107&t=39134
                                Best,
                                Jason.
                                • cheddaC Offline
                                  chedda
                                  Thanks Jason I think the next plugin release must be close now. I have been really struggling with the current one, I think it's silverlight making it hang. Is it just me or is sketchup on the Mac having issues ? I hope the next release has a HTML menu like grass. I've lost countless hours due to silver light (rant over)
                                  • cheddaC Offline
                                    chedda
                                    An interior image of the dining/entrance/stair area.This image was stubborn to clear at SL21 i ran a light de-noise plugin (topaz) C&C welcome as always.
                                    • KrisidiousK Offline
                                      Krisidious
                                      How very elegant...
                                      By: Kristoff Rand
                                        jpalm32
                                        Great work. Your lighting is art.
                                        • RichardR Offline
                                          Richard
                                          Cheeda, mate you are becoming a true genius at these renders - stunning work mate!
                                          A quick play with the exterior night shot.
                                          BUILTBRAND.COM.AU
                                          • cheddaC Offline
                                            chedda
                                            Thanks for the comments guys.
