    Exporting layers to Photoshop
    7 Posts 3 Posters 791 Views 3 Watching
    • I
      ivan_pajares
      Hi there,
      let me first introduce myself: I'm Ivan, architect & teacher and Sketchup user...
      My first question now:
      I've modified thomthom's tt_export.rb script to get different layers of information for photoshop compositing.
      When I load a specific style I have to do it twice to get sketchup to load it properly (i.e. no edges style to get only the shadows).Presently I'm doing it like this:
          styles = Sketchup.active_model.styles
          styles.selected_style = styles["OnlyShadows"]
          UI.messagebox "Changing styles"
          UI.messagebox "Again..."
          filename_shadows = filename + "_shadows.png"
          UI.messagebox filename_shadows
          model = Sketchup.active_model
          shadowinfo = model.shadow_info
          value = shadowinfo["DisplayShadows"]=true
      If I try to do it straight away it doesn't turn edges off. Is this a bug or am I doing it wrong?
      I would love to forget about clicking 'OK' twice for every layer I export...
      TIA
      • I
        ivan_pajares
        OK,I just didn't think about
        view.refresh
        Now I get the first image & the profiles but: I don't get the shadows with 'no edges' as defined in the style... unless I repeat the command as in:
            refreshed_view = view.refresh
        Is this normal or am I missing something again?
        Regards
        • B
          Brett McAllister
          I recommend you go read this PDF to get you started otherwise you will be tearing your hair out and nothing will make sense.
          http://www.autosketchup.com/
          • Chris FullmerC
            That site isn't working for me. Is that Martin Reinhart's site?
            • B
              Brett McAllister
              No, it's a chap called Matthew Scarpino.
              The site seems to work all right for me, if it still doesn't work and your interested in the PDF, I will email you a copy.
              • Chris FullmerC
                Oh yeah, It's Matt's. Whatever was wrong before it seems to be back up and running now. Thanks
                • I
                  ivan_pajares
                  OK, I will.
