    Adding wet grass
    Scheduled Pinned Locked Moved Post Processing
    2 Posts 2 Posters 9.9k Views 2 Watching
      davidh
      Adding wet grass:
      1.render out an image with a reflection on the grass surface
      2.locate an image for the wet grass you want to use - try and find one that has the same colour reflection as the sky in the render so it blends with the image easier.
      2.distort the image so it matches the render perspective.
      4.copy and paste the grass layer over the original rendered grass.
      5.using a soft eraser ,remove the grass that overflows onto the road.(material ID can be of great use here)
      Use the clone tool if required to smooth out any transitions.
      6.edit the curves of the new grass layer.this step is optional.
      The second image shows another before and after image
        ccs1987
        can we have the wet grass ?
        Sketchup 8 pro
        Vray
        Intel Xeon W3520 2.67Ghz
        12Gb Ram
        Nvdia Quadro FX 1800
