    Ordered my new computer
    19 Posts 5 Posters 2.2k Views 5 Watching
      rv1974
      @sketchymick said:
      @ely862me said:
      Pff !!! Guys ,you are definitely running some machines over there , and I am struggling with my dual core 2.8 ghz , 2gb ram ,160 gb hdd , and 1 gb nvidia gt 8600 .
      Your recent machines look like 22 century for me , lol !!
      If you don't mind,guys, what are your recently configuration, and what are you doing with them? I might buy some parts(or the entire) from you , if you are not going to use them further of course !
      Cheers !
      And keep it under the radar speed will you !
      I think that is one of the great advantages of sketchup in that it will work reasonably well with low spec machines.
      I have a number of machines as part of my business (which although only 2 or 3 years old, are all definitely "old"), but I'm not looking to sell any. thanks for the interest.
      The SU is just initial point. The Max+Vray+Evermotion stuff eat huge amount of CPU.
      • ely862meE Offline
        ely862me
        I am glad I use Sketchup then !
        Someday....
        Elisei (sketchupper)
        Come and See EliseiDesign
          sketchymick
          Well... put the computer together today. One thing surprised me... it worked first time ! (it was my first build )
          Not surprisingly it's pretty fast. Probably the main thing to report is that the gtx680 card seems to work very nicely, no glitches, very smooth orbiting, etc. this was the only area that I was questioning myself.
          I threw all my biggest models at it and I couldn't fault it, so not much more to report from the sketchup side I think.
          Haven't done any renders though... maybe in a few days.
          Cheers
          • Mick
          "I love the sound that deadlines make as they rush past"
            sketchymick
            I thought I'd give an update here on this build, as well as a 2nd computer I put together pretty quickly after the first:
            Both have:
            i7-3930K CPU
            ASUS p9x79 motherboard
            16Gb ram
            SSD system drive (240 and 256 Gb versions) and HDD for data storage
            The main difference between the two computers is the graphics card. First one has GTX680, my 2nd one has GTX670 (both EVGA reference). For my 2nd computer I was perilously close to buying a Quadro card, just to satisfy my curiosity... in the end I went with the 670 for the 2nd one because it is only slightly lagging behind the 680 in performance, but runs cooler, less wattage and was about $200 cheaper. I posted some performance figures in a speed test thread on this forum. I have a bias for nvidea cards, but I understand that the AMD 7970 card is the man if you want GPU computational power (the 680 apparently is a poor performer in this regard... if you google it you'll find some articles). Having said that, I haven't been able to stall sketchup with any model I've previously put together and I get smooth orbiting, etc. at all times. I stayed away from the GTX580 because it is pretty power hungry, but otherwise I understand it is pretty good performance for money.
            The 6 core i7-3930 chip is only used fractionally with sketchup (1 core), so it is wasted if that is all you're doing. I tend to run things in the background a lot, so that's how I justified the cost, and I don't regret it.
            The reason I went with the p9x79 board is that it has 8 ram slots, so I filled 4 and have a 2nd set free for future upgrade. Honestly, I think 16Gb is wasted, so 24 is not likely to provide value for money. I used autocad, sketchup, photoshop, office, etc. often all at once and have never had any ram issues.
            I went for ASUS VE278Q 27in Widescreen LED Monitors - good price and no complaints at all.
            Problems: well these were my first 2 builds ever, and I was patting myself on the back thinking everything was going perfectly, but in the end I did have some hiccups...
            • the BIOS version that came with the asus p9x79 motherboards were considerably out of date. I had some hard lockups that I was getting frustrated with, which instantly went away when I upgraded the bios (quick and simple !). I spend quite a bit of time looking at my drivers, to see what was out of date, before I realised it was the bios that was the problem.
            • my first computer was built in a corsair 550D case. It was fractionally too large for the space I have in a desk recess at my office (the CD tray couldn't open fully), that computer is my home office version now. My second build was based on the corsair 300R case which is a bit smaller.
            Hope this helps someone
            Cheers
            • Mick
            • utilerU Offline
              utiler
              Great reporting, Mick! Good to have some feedback on someone that has done comparisons....
              Going to the computer shop now to discuss specs!!
              πŸ‘
              Just Curious...
              • utilerU Offline
                utiler
                Hey Mick, I'm just finalising my new computer specs and have a question for you. You say you run a lot in the background when using SketchUp; I assume AutoCAD, PS, etc but do you run a render program such as Maxwell or SU Podium while flicking back to AutoCAD or any other program and if so; do you notice any stalling..? Currently, if I want to export a reasonable quality render I have to drop everything and leave my system run as even as much as open Windows Explorer makes everything hang.... 😠
                Be good to know if either of your systems have this happen... πŸ‘
                Just Curious...
                • utilerU Offline
                  utiler
                  Any comments on this before I sign the check? I'm keen to get some feedback.....
                  Thank!!
                  Just Curious...
                    sketchymick
                    Hey utiler ! sorry, I only just saw your posts here... I guess you've got your new computer now - how's it go?
                    Cheers
                    • Mick
                    • utilerU Offline
                      utiler
                      Great Mick, Ta!!! Loaded it last weekend and its pretty slick!!!
                      Just Curious...
                        sketchymick
                        Good to hear ! I don't think you'll regret the 3930K and I bet you are already impressed with the SSD ! My 2 machines have been going flawlessly now for quite a while. Not so much sketchup work at the moment, but heaps of autocad. Pretty keen to get into another sketchup project soon.
                        Cheers
                        • Mick
                        • utilerU Offline
                          utiler
                          Magic mate!!! Drop that autocad and you'll never look back.....!
                          Just Curious...
