    Namespace question on noob level
    16 Posts 3 Posters 1.0k Views 3 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @liquid98 said:
      The require("liquid/useful.rb") line is mandatory inside the two modules 'Liquid' and 'FancyPlugin' ??
      NO
      @liquid98 said:
      Or is it also possible to put it among the first lines of the script?
      YES
      @liquid98 said:
      What do you mean by
      'But never include() modules into the TOPLEVEL_BINDING, which is Object. ? '
      Unwrapped methods are evaluated in Object, and become global methods. They get inherited by EVERYONE's modules and classes, and make us angry. πŸ‘Ώ
      The same for constants, instance variables and class variables.
      Just plain code within your own namespace, and we will love you. πŸ˜†
      I'm not here much anymore.
        Dan Rathbun
        @liquid98 said:
        So every script should be in a double namespace ?? (Liquid and Name).. with or without loading other scripts ??
        All your code needs to be within YOUR namespace (whatever you decide to call it.)
        You will find that you wish to separate each of your plugins from one another. So each goes in it's own sub-module namespace, so they do not clash with each other.
        Also in the "Plugins" directory.. your files need to go in YOUR "author" sub-directory.
        You will want to maintain your plugins separately, so each should go in a sub-dir of your "author" directory.
        I suggest having the directory names and modules the same. It helps syncing up the require arguments with the include or extend arguments.
        • liquid98L Offline
          liquid98
          Cooool! Thanx, I was hoping for this! πŸ‘
          Global methods: just methods without any namespace? -- Refrain from using them, right?
          What do you mean by:
          EDIT:
          require("liquid/useful.rb") include(Liquid::Useful)
          Should be placed outside the modules!!
          Thnx
          Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
          • liquid98L Offline
            liquid98
            Thanx again Dan,
            Really beautiful to see it running this way!! πŸ˜„ πŸ˜„
            This trick is not widely known according to my grep.. πŸ€“
            Liquid
            • liquid98L Offline
              liquid98
              Hi Dan,
              Thnx for the information. The next script I've written will have this namespace treatment!
              By the way I found that calling :
              include(Liquid;;Useful)
              only works outside the module definition.. ❓ ❓
              edit: Other question: Is there some evil in using load instead of require?
                Dan Rathbun
                NO.. This is not true, .. and Do not do this. If you do, you will add methods to EVERYONE's modules and classes, not just yours.
                If you cannot get it to work, then you are doing something incorrect.
                FYI: The mixin methods, in a mixin module, must be defined as instance methods, without a self. before the name.
                  Dan Rathbun
                  [off:2wuy0iss]
                  They do different things:
                  require() checks the $LOADED_FEATURES (aka $",) array and only loads the file if it has not already been loaded, and if it does (without error since v1.8.4, or so,) adds the filepath to that array. (Beware that v1.8.0 adds the filepath before the load attempt, so under Windows Sketchup < 8.x, that is still running v1.8.0, filepaths for failed files will exist in $".)
                  load() does not check $", always attempts to load the file, even it it was previously loaded, and does not push any filepaths into the $" array.
                  So.. we use load() during debugging, to re-load scripts, which will re-define methods with the new changes.
                  After release... require() is used so libraries are only loaded once.[/off:2wuy0iss]
                    Dan Rathbun
                    I will need to disagree. It is not a "trick."
                    Mixin Library Modules, that are used with include() and extend(), is basic Ruby (perhaps in the second semester course,) but still one of the fundamental principals of the dynamic nature built into Ruby.
                    The problem is that most people are impatient, and refuse to read the Ruby textbook, to learn the fundamentals first. They read the first chapter and start hacking away.
                    My Question to YOU: Have YOU read the book yet ??
                    (I do not think you have given your questions.)
                    It is in the "doc" folder of the the Full Ruby install, usually on Windows:
                    %(#004000)["C:/Ruby186/doc/ProgrammingRuby.chm"]
                    Also online at:
                    http://phrogz.net/ProgrammingRuby/frameset.html
                    Am I the only person in the world, who read this book cover-to-cover, before ever writing a single line of Ruby ?? πŸ˜’
                    Doing so saved me much frustration ! Although that book is old (... written in the v1.6.x days,) it is still valid, and I still refer to it often.
                    • liquid98L Offline
                      liquid98
                      Dan,
                      No I haven't read the book yet. Though I scraped my information from several places, like this forum, google, other books, Rubydocs
                      'Automatic Sketchup', etc.
                      In my point of view 90% of ruby scripting for sketchup is just using the Ruby API. The other 10 % is a set of rules cq best practices
                      to manage the code in a efficient way.
                      Though I thank you for your suggestion, I have I complete folder of URL's with ruby books, to impressive to start with..
                      So a good starting point is welcome.
                      Rene
                      • liquid98L Offline
                        liquid98
                        Hi Dan,
                        I just copy pasted your example into two files:
                        It works only if
                        require("useful.rb")
                        is outside the modules.
                        Can you please take a look??
                        Thnx,
                        Rene
                        mixin test
                          Dan Rathbun
                          Ok got it.. you need to use a proxy class inside a module:
                          (1) The word useful has only 1 "L", by the way.
                          "Plugins/liquid/useful.rb"
                            module Liquid
                              MENU = UI.menu('Plugins').add_submenu('Liquid')
                              module Useful
                                module_function
                                def useful_1()
                                  msg = "I am method useful_1()."
                                  puts( msg )
                                  return msg
                                def useful_2()
                                  puts( msg )
                                  return msg
                                def useful_3()
                                  puts( msg )
                                  return msg
                              end # Useful
                            end # Liquid
                          "Plugins/liquid/fancy.rb"
                            module Liquid
                              module Fancy
                                class << self # proxy class
                                end # proxy class
                                useful_1()
                              end # module Fancy
                            end # module Liquid
                          But for a custom class, no proxy class is needed:
                          "Plugins/liquid/fancytool.rb"
                            require("sketchup.rb")
                            module Liquid
                              module Fancy
                                class FancyTool
                                  def activate()
                                    UI.messagebox( useful_1() )
                                    Sketchup.active_model.select_tool(nil)
                                end # class
                                unless file_loaded?('Liquid;;Fancy;;FancyTool')
                                  @@tool = FancyTool.new()
                                  Liquid;;MENU.add_item('FancyTool') {
                                    Sketchup.active_model.select_tool(@@tool)
                                  file_loaded('Liquid;;Fancy;;FancyTool')
                                end # unless
                              end # module Fancy
                            end # module Liquid
                          • liquid98L Offline
                            liquid98
                            Off topic:
                            thanx for your correction, the English language is not my mother language as you might have noticed..
                            /Off topic
                            All code is safe now and my code works like a charm, so thanx for your help. And yes I SHALL read the book before
                            I come here and ask questions like this.. πŸ˜„
