    Kill external process
    7 Posts 2 Posters 489 Views 2 Watching
      maricanis
      I'm running some external processes from my plugin.
      Since they can run rather long, I would like to offer a user possibility to abort started external process. Is there some elegant way to do it in SU?
      Only way I've found for now is when user press some button, I call:
      taskkill /f /im my_program.exe
      or
      tskill my_program
      (since no idea how to get PID of the external process from my Plugin, I use image name or exectuable name).
      BTW: I'm running process with UI.openURL() and batch_file.
      I'm using SU 8 in Windows 7 operating system.
      Thanks in advance,
      Marija
      • Dan RathbunD Offline
        Dan Rathbun
        You can use tlist.exe (XP) or tasklist.exe (Vista/Win7) to check when the SU process ended.
        (The catch is that XP Home doesn't come with tlist.exe, it must be ... installed separately*. It comes installed standard on XP Pro, or Win Server 2003+.
        • is referring to the separate "Support Tools" installer on the Windows install CD.
        And.. I do not know what the equivalent is on OSX.
        I'm not here much anymore.
          maricanis
          Thanks Dan,
          For now plugin is only Windows oriented so these tasklist or tlist would do the job for listing running processes
            maricanis
            I've implemented killing of external process (which is started by UI.openURL) with next method:
            -call 'tasklist' - to check is process is still running and to get process PID
            -then in plugin Process.kill("KILL",PID)
            This approach works, but I also want to inform object that started external process that process is killed (so some timers are stopped).
            I though to implement that with signals:
            -after process is killed I send signal "USR1" for example
            -and I trap the same signal in class that started process - and then stop timers.
            Problem is that Sketchup doesn't recognize "USR1" signal.
            I've tried in Ruby console:
            Signal.list.keys.join ", "
            TERM, SEGV, KILL, EXIT, INT, FPE, ABRT, ILL
            But none of these signals are the ones I need, I need some custom user defined signal for my plugin.
            Is the thing I need possible, and how to do it in Ruby/Sketchup?
            Thanks in advance,
            Marija
              Dan Rathbun
              Just pass a reference of the timer id object, to the method that kills the process, and call UI.stop_timer(tid) from that method, after it is verified, that the process is dead.
                Dan Rathbun
                OR.. in object 1, write a callback method that is called from the killing object:
                def deceased
                  UI.stop_timer(@tid)
                  # any other post death cleanup
                Assumes you save a reference to the timer id, in object 1, when you started the timer, like:
                @tid = UI.start_timer(delay,true) { # code block }
                  maricanis
                  Thanks Dan,
                  Your suggestion to write callback that is called from killing object, was very useful idea - and makes nice readable code.
                  Much better idea then various signals I planned to use before.
                  Thanks again,
                  Marija
