    โš ๏ธ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Deleting duplicate components
    8 Posts 6 Posters 3.6k Views 6 Watching
      sabre
      I am try to find a way to locate duplicate component instances and then deleting all but 1 instance by just using ruby.
      The defintion of duplicate is where two or more of the same component definition have the exactly the same origin.
      Thanks for any suggestions.
        Matt666
        Hi Sabre, and welcome to this forum !
        I think Com def has her proper origin... So how can you choose which comp instance will not be deleted ?
        ๐Ÿ˜‰
        So you want to delete duplicate component definitions, right ? you want to make component definitions unique ? I don't understand... Sorry !
        Frenglish at its best !
        My scripts
          sabre
          As you noticed I am new to the forum (thanks for the welcome) and I am having difficulites the sketchup terminology.
          I will try explaining the problem in another way:
          The user selects several components and builds the first part of a frame. He then copies these components and pastes them to expand the framework. Sometimes he overlaps the existing components with the pasted copy hence he has the two of the same components sharing the same origin. In order to accurately price up the framework I need to remove the duplicate component as in real life I cannot put more than one component in the same place.
          Hope that helps.
          • Didier BurD Offline
            Didier Bur
            So you want to remove all duplicate instances refering to the same component definition and that have the same transformation as well:
            def remove_instances_duplicates
            defs=Sketchup.active_model.definitions
            to_delete=[]
            defs.each do |compo_def|
              next if compo_def.internal?
              instances=compo_def.instances
              instances2=instances
              instances2.each do |i2|
                keeping_instance=instances.shift
                instances.each do |instance|
                  if instance != keeping_instance and instance.transformation.to_a == keeping_instance.transformation.to_a and instance.definition.insertion_point.transform(instance.transformation)==keeping_instance.definition.insertion_point.transform(keeping_instance.transformation)
                    to_delete.push(instance)
                    puts "Erasing duplicate instance of " + instance.definition.name
            to_delete.each { |inst| inst.erase! }
            I'm not sure it works as is but it is near it...
            DB
              sabre
              Many thanks Didier.
              You have saved me a lot of time
                Gianfranco
                Good day
                I know this is an old thread but this seems to be exactly what I'm looking for. I would like to ask, how can I use the script that Didier posted?
                Thanks.
                  bjornburgh
                  Pasting the Script in the Ruby console doesn't work. Is there another way?
                  • sdmitchS Offline
                    sdmitch
                      to_delete=[]
                    There was an extra "end" in the code. Removing that should fix the problem.
                    After pasting into the Ruby Console, press Enter then type in "remove_instances_duplicates" to execute.
                    http://sdmitch.blogspot.com/
