    New Year, New computer....
    55 Posts 10 Posters 6.1k Views 10 Watching
    • irwanwrI Offline
      irwanwr
      thank you Steve.
      that image really helpful to make me understand better of the idea.
      i'd like to try that if i got the chance to upgrade my pc.
      • EscapeArtistE Offline
        EscapeArtist
        Wow, you replace the entire side of your case with a filter? That can actually reduce cooling capability of the fans in your case, i.e. the fans will just circulate hot air instead of being able to direct it through and out of the case. I guess if you only have fans taking air out it might work OK, but like you said that solution isn't for everybody.
        Generally you want positive pressure in a case (Neutral would be ideal), this will keep contaminants out of the case. Negative pressure would suck dirt in through every little hole in the case, and that can be in your USB ports, headphone jacks or any other port that is not sealed. My other half's PC has negative pressure and the ports are clogged with cat fur after a few months and they need to be vacuumed out. Eventually some sneaks through and clogs the processor fan and the graphics card necessitating further cleanup inside. Not really desirable as every time it is necessary you expose the components inside to damage or static discharge. Positive pressure will mostly avoid this.
        • hellnbakH Offline
          hellnbak
          The external 9 inch fan blows in air thru the filter, the others draw out the air. The computer stays cool, and it stays clean. I have been using this system on all of my computers for many years, works great. Like I said, this won't appeal to everyone, aesthetically.
            dsarchs
            Hellnbak -- I'm sure you're getting enough cooling, but not the most efficient. More open doesn't equal cooler. Here's an interesting article on air cooling setups.
            Smaller more confined spaces direct air current over the parts that need to be cooled where larger, more open cases have to move a lot more air. There's also the issues of pursuing a negative or positive pressured case.
            Plus... there are some pretty cool cases if you look around.
            Knowledge is a polite word for dead but not buried imagination.
            -e.e.cummings
            • hellnbakH Offline
              hellnbak
              Sorry to hear that my computers have not be running very cool and clean for many years. Guess I'll have to throw them out and build new ones with the correct cooling system 😒
                EscapeArtist
                Lol, bit dramatic eh?
                Whatever works. Aesthetically I wouldn't like it at all; but if you're not OC'ing and things aren't failing or causing crashes, who cares if it looks like a case designed by Home Depot?
                • utilerU Offline
                  utiler
                  So it turns out that I didn't buy my system when I originally posted as my wife bought a laptop for home so my work system stayed put.... 😒
                  But now its on!! Things haven't seemed to have changed much since unless you all have some updated tech info.... πŸŽ‰
                  So here's what I'm ordering:
                  i7 2600k 3.4Ghz
                  12Gb 133MHz DDR3 RAM
                  240GB SSD
                  1TB Hard drive
                  Nvidia GTX580 GPU
                  800W Power supply
                  Win 7 64-Bit
                  The only thing I am not convinced about ia whether to go with a GTX 680 rather than the 580. Had a look here again http://www.videocardbenchmark.net/high_end_gpus.html and also here: http://www.hwcompare.com/12366/geforce-gtx-580-vs-geforce-gtx-680/
                  Not sure what 'Texel rate v Pixel rate is or even if I would notice it but would love to know anyway... Also, the cost difference is not much so either way it doesn't make much difference.
                  Anyway, close to sending off final specs so if any of you have comment they are all welcome!!
                  Oh, and I'm thinking a bigger monitor.... yes, yes I know I have said in other threads that my 24' is sufficient but I am now coming around to something bigger..... HOW BIG???
                  πŸ‘
                  Cheers,
                  Just Curious...
                    sketchymick
                    Utiler, this looks like a nice machine... I'm pretty close to putting a system together but was leaning towards an i7-3930 (or maybe come back to a i7-3820), but otherwise very similar to yours. I was wondering how you came to your decision regarding CPU? I've also been bouncing the graphics card thing around - originally Quadro 2000, but now reconsidering the same choices as you. Cheers - Mick
                    "I love the sound that deadlines make as they rush past"
                    • utilerU Offline
                      utiler
                      Hey Mick, actually I this CPU was quoted to me a little while ago so I should ask about a the i7 3930.
                      From what it seems the Quadro cards are priced to target professional CAD users where as the GTX cards perform just as well if not better for what SU needs as you'll see by the links I provided.
                      πŸ‘
                      Just Curious...
                        sketchymick
                        πŸ‘
                        Don't get me wrong, what you have looks good - I was just wondering if there was something particular that swung your decision, as it's pretty hard trying to make a decision with all the choices out there. Having looked at it more, I think the 3820 isn't really a great option, so for me it seems its between the 2600 and 3930.
                        With the video card, I figure that I can always buy something like the gtx580 and if it doesn't work out for me then I'm sure someone will buy it off me for a reasonable price, but not sure I could say the same for the quadro. As a side note, it seems the gtx580 is being discontinued... so is already old 😞
                        Cheers
                        • Mick
                        • utilerU Offline
                          utiler
                          Thanks for that, Mick. I'll ask my tech guys whats hot in cards at the moment.... πŸ‘
                          Just Curious...
                            sketchymick
                            I'd be interested to hear what they say. From what I can work out the new gtx680 is the pick of them (less wattage, more triangles per sec), but I had a look online and there seems to be a lot of "out of stock" here in Oz, so not that confident of grabbing a cheap one any time soon.
                            Just to keep the door open on this topic.... I have yet to find anyone who actually has used both the quadro2000 and gtx580 and can offer any first hand comments.
                            Cheers
                            • Mick
                            • utilerU Offline
                              utiler
                              You sounded a little Aussie, Mick!!! Must be the way we write posts... 🀣
                              Just Curious...
                                sketchymick
                                Hey Utiler, yep aussie and proud of it πŸ’š
                                Any advice from your tech gurus?
                                I can't believe the amount of on-going debate all over the internet regarding Quadros and GTX's, even for apparently quadro optimised software.
                                Cheers
                                • Mick
                                • utilerU Offline
                                  utiler
                                  Hey Mick, we just bought a new system in the office. This is what we went for:
                                  i7 2600
                                  16Gb RAM
                                  Nvidia GTX 580
                                  240Gb SSD
                                  And it really hums!!!! πŸ‘
                                  Just Curious...
                                  • utilerU Offline
                                    utiler
                                    Ok, it's time to buys again.... The one we bought a month of so ago is a beauty but even in that short time things go out of date.
                                    The GTX 580 is obsolete; the 680 is apparently the current pick.
                                    The i7 3930 is the top end processor (apparently) although the Xeon E5 series are the next step up....
                                    RAM is cheap as chips so maybe 24mb...?
                                    Any news that I should know about before spec'ing up a new piece?
                                    BTW, we bought an AOC 27" 3D screen which seems pretty good although I do like to stay with Samsung (only because I have always had them...) any others you have good things to say about?
                                    Cheers,
                                    Just Curious...
                                    • N Offline
                                      notareal
                                      The GTX 580 is is far from obsolete if you are going to use it for cuda calculations, it will beat 680 that is actually heavily optimized for games. Before all nvidia cards tend to play better for GPGPU, if they where "latest", now the game has changed.
                                      • utilerU Offline
                                        utiler
                                        Maybe obsolete was not the right term notareal.... rather old stock. [well here in Australia anyway...]
                                        πŸ‘
                                        Just Curious...
                                          sketchymick
                                          Hi utiler... I added an update on my build at http://forums.sketchucation.com/viewtopic.php?f=72&t=45071&p=414555#p414555, partially in response to this thread but thought it probably belonged better there.
                                          Cheers
                                          • Mick
                                          • utilerU Offline
                                            utiler
                                            Cheers Mick! πŸ‘
                                            Just Curious...
                                            • 3 / 3
