    Best SketchyPhysics Setup?
    8 Posts 3 Posters 2.6k Views 3 Watching
    • ashscottA Offline
      ashscott
      Is this the best sketchyphysics setup?
      http://t3.gstatic.com/images?q=tbn;ANd9GcQ3Bk8caduQQ3U55m6FuXqdbu5qmhoFunqx1hsRO4q81eSwpCeTcw
      I've been trolling the web far and wide to learn more about sketchyphysics and haven't seen anything like this but it seems amazing - it has automated walk functions so you press forward on the joystick and the machine places its own feet.....and the way the ruby is written seems totally contrary to any other models or the recommendations in the SPwiki - it doesn't use Wacov's infamous toggle script when it toggles between functionality.
      Have a play with it yourself:
      http://sketchup.google.com/3dwarehouse/details?mid=5b618d4ba6c22ca85fd35d52fb19ea9b&prevstart=0
      Youtube vid here: http://www.youtube.com/watch?v=GnblpHMRr7o&lr=1&feature=mhee
      If anyone can tell me anything about this cleverly designed SP rig then I would like to know more - I have been trying to reverse engineer some of the functionality out of the script but its not that intuitive to an SP noob like me. I would love to emulate the servos on the arms that stay where they are placed for example. I am also unable to make it crash wheras my models with similar functions crash regularly. Here's the ruby out of it:
      if frame<1.00
       @spc=0.00;@hokou=1.00;km=0;@st=0.00
       @lh1=0.00;@lh2=0.00;@lh3=0.00;@lh4=0.00;@lh5=0.00
       @rh1=0.00;@rh2=0.00;@rh3=0.00;@rh4=0.00;@rh5=0.00
      if (key("x")==1 or joybutton("a")==1) and @km==0
       if@hokou==1
       @hokou=0
       else
       @hokou=1
       @km=1
      if key("x")==0 and joybutton("a")==0;@km=0;end
      #@spc=@spc+((slider('sp')-0.50)*9.00)
      if @hokou==1.00
      @spc=@spc+((0.5-lefty)*18.00)+((0.5-rightx)*18.00).abs+((0.5-leftx)*18.0).abs
      @sin1=sin((@spc/360.00)*2.00*PI)
      @sin2=sin((@spc/360.00)*2.00*PI+PI/2.00)
      if @sin2>=0.00
       @sin3=@sin2
      else
       @sin3=0.00
      @sin5=sin((@spc/360.00)*2.00*PI+PI)
      @sin6=sin((@spc/360.00)*2.00*PI+PI*3.00/2.00)
      if @sin6>=0.00
       @sin7=@sin6
      else
       @sin7=0.00
      if rightx==0.5
       @la1=@sin1;@lc1=@sin1;@rb1=@sin1
       @lb1=@sin5;@ra1=@sin5;@rc1=@sin5
      else
       @la1=0.00;@lb1=0.00;@lc1=0.00
       @ra1=0.00;@rb1=0.00;@rc1=0.00
       @la2=@sin3;@lc2=@sin3;@rb2=@sin3
       @lb2=@sin7;@ra2=@sin7;@rc2=@sin7
      # @st=slider('st')
      @st=leftx
       @la1=@la1*@st;@lb1=@lb1*@st;@lc1=@lc1*@st
       @ra1=@ra1*(1-@st);@rb1=@rb1*(1-@st);@rc1=@rc1*(1-@st)
      if rightx!=0.5
      @sid=rightx-0.50
       @la3=@sin1*@sid;@lb3=@sin5*@sid;@lc3=@sin1*@sid
       @ra3=@sin5*@sid;@rb3=@sin1*@sid;@rc3=@sin5*@sid
      # @la3=-@la1;@lc3=@lc1
      # @ra3=@ra1;@rc3=-@rc1
       @la2+=-0.50;@lb2+=-0.50;@lc2+=-0.50
       @ra2+=-0.50;@rb2+=-0.50;@rc2+=-0.50
       @la1=@la1*1.50+1.50;@lb1=@lb1*0.50;@lc1=@lc1*1.50-1.50
       @ra1=@ra1*1.50+1.50;@rb1=@rb1*0.50;@rc1=@rc1*1.50-1.50
       if leftx==0.5
       @lh1=0.00;@rh1=0.00
      if @hokou==0
       @lh2+=(0.5-righty);@rh2+=(0.5-righty)
       @lh5+=(0.5-leftx)*2.00;@rh5+=(0.5-leftx)*2.00
       @lh4+=(0.5-rightx);@rh4+=(0.5-rightx)
       @lh3+=(0.5-lefty);@rh3+=(0.5-lefty)
      if @lh2>35;@lh2=35;@rh2=35;end
      if @lh2<-40;@lh2=-40;@rh2=-40;end
      if @lh3>15;@lh3=15;@rh3=15;end
      if @lh3<-55;@lh3=-55;@rh3=-55;end
      if @lh4>50;@lh4=50;@rh4=50;end
      if @lh4<-25;@lh4=-25;@rh4=-25;end
      if @lh5>40;@lh5=40;@rh5=40;end
      if @lh5<-50;@lh5=-50;@rh=-50;end
      if @rh5>40;@rh5=40;end
      if @rh5<-50;@rh5=-50;end
      if @hokou==1
       setVar("text","Walk 歩行")
      else
       setVar("text","work 作業")
      Just some stuff I do with Sketchup.
        Amazing model! ☀
        Maybe here the creator of ScketchyPhysics will can help you 😉
        • ashscottA Offline
          ashscott
          You had a play with it Pilou?
          Did you notice all of the functionality? - the toggle between legs and working arms? The automated walk feature? The way the arm servos stay where you but them rather than springing back?
          I love it
          Ash
            Not yet
            In the past i had play with this 😄
            • ashscottA Offline
              ashscott
              Thats cool Pilou - however, it doesn't have the scripting knowledge that is required to make something walk. Lifting and placing legs is a whole lot more complicated than turning wheels - but I agree, that is a beautiful warthog.
              • ashscottA Offline
                ashscott
                Boy, the sketchyphysics part of the forum sure is quiet compared to what it used to be - is there some other physics simulation software that I'm not aware of?
                I would love to get sketchyphysics back in the limelight - its such a fantastic bit of kit
                Ash
                • ashscottA Offline
                  ashscott
                  Managed to reverse engineer some of the stuff on this amazing setup - see this thread: http://forums.sketchucation.com/viewtopic.php?f=61&t=44399
                    DL xyz
                    This post is deleted!
