    SketchyPhysics Keyboard Controls
    4 Posts 2 Posters 5.1k Views 2 Watching
    • ashscottA Offline
      ashscott
      Hi all,
      discussion on sketchyphysics sure seems to have cooled off since I was last in this part of the forum 2 years ago - thats a shame, over the last few days I have been using SP to model a proposed walking machine and it really is an extraordinary plugin.
      I have a couple of questions for you folks that are more familiar with SP and Ruby:
      1. Using (rightx) how do I get servo to sit in a position and stay there without spring loading back to its midway point? I am lifting a leg with the servo, pressing one arrow raises the leg and pushing the opposing arrow lowers the leg but if I release the arrow at any time the leg springs back to the middle position. How can I set things up so the leg maintains it's position when I release the arrow key? Currently the controller says this:
      slider('A2_Tilt',0)+(rightx)
      1. Is there a way to apply the same set of keys for certain objects and toggle between them, for example my walking machine has four legs. I can use (rightx) and (righty) to lift and place one leg - is there a way that I can set up a toggle function to apply those keys to each leg in real time so I can move each one individually? IE press spacebar so that the (rightx) and (righty) functions apply to the next leg on the machine?
      Any help is much appreciated - I love the plugin and would pay for it if it would encourage Cphillips and co in their endeavours (you can't work for free) πŸ˜‰
      Ash
      Just some stuff I do with Sketchup.
      • ashscottA Offline
        ashscott
        Answers to these questions:
        1. Use a motor not a servo
        2. Toggling between keys looks something like this:
        if key("m")==1
        @B1_Tilt=(righty) and @B1_Twist=(0.5-rightx) and @B1_Ext=key("b")
        elsif key("m")==0 and key("n")==0
        @stick=0.5-(righty)
        If I hold down ("m") the joystick controls a different set of functions than if I hold down ("n"). I also have another set of functions for the joystick if no key is pressed so I have three joysticks in one.
        "m" and "n" have been assigned to my second joystick using the software 'joytokey' which I highly recommend. It allows you to set functions to the keyboard but then run them through a second joystick to your primary joystick.
        Thus, I am running my sketchyphysicks sim with a logitech attack3 joystick in each hand.
        It is an industrial simulation and I haven't seen anything else like it done online. I can't share more because its under NDA but if anyone wants help with something like this then let me know.
        Ash
        • ashscottA Offline
          ashscott
          There is a much better answer than using a motor to place a joint where you want it - you need to use a servo and a little ruby script
          Step1: place your servo within the group you want to move and attach it to a base group
          Step2: select the servo and open the sketchyphysics UI
          Step3: within the UI apply the following settings
          [list=]min:0
          max:1
          accel:4000
          damp:1000
          controller:@servo1 (you can actually call it anything starting with @
          [/list]
          Step4: Select the base of your model and open the sketchyphysics UI
          Step5: place the following rubyscript in there:
          if frame<1.00
          @servo1=0.00
          # this allows servo to incrementally increase based on joystick input (righty) you can change it to any of the joystick axes
          @servo1+=(0.5-righty)
          # this sets range of movement for the servo as it is not set in the servo's UI
          if @servo1>45;@servo1=45;end
          if @servo1<-45;@servo1=-45;end
          It took me a long time to work this out (reverse engineering another model) so I am more than happy to help anyone out with it if these instructions are too hard to follow.
          I believe this is a very powerful function in sketchyphysics and I have only seen it in one model in the 3DWH
            DL xyz
            This post is deleted!
