    MR2 broke plugin during C extension require
    51 Posts 4 Posters 4.5k Views 4 Watching
      draftomatic
      Hmm, doesn't look like it was.
      RUBY_VERSION 1.8.6 RUBY_PATCHLEVEL 287
      Actually I just upgraded my laptop's SU, which is XP and it's loading. I have tested it on 2 Vista computers (one of which worked before MR2, and the other I did a totally fresh installation of SU and the plugin) and both are broken.
        draftomatic
        Ah, so I needed to leave off the ".so" part of the path.
        So that was the problem using loadin the Ruby console, but now the file is not found (which actually is the error I was having originally but then I started getting the other one in the console).
        Getting this error now:
        Error Loading File light_stanza_extension.rb 126: The specified module could not be found. - C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so
        I attached a screenshot as proof the file does exist in the correct folder and that my load paths are correct.
        • Dan RathbunD
          Dan Rathbun
          Let's see the light_stanza_extension.rb file, please.
          Does it use a path with backslashes, or forward slashes ??
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            It does not matter (at console or in script,) if you have the proper paths in the $LOAD_PATH array, then use
            require('openssl')
            instead of:
            load "Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so"
            BTW: the "\220" char is the backslash, aka the method call: 220.chr()
              draftomatic
              The error is only showing that file because it's the entry point for the plugin. I'm not requiring anything in that file, and certainly not openssl.so.
              It's nested several requires later, when I require the RestClient library, which is a 3rd-party library which itself includes openssl.
                draftomatic
                @dan rathbun said:
                require('openssl')
                This gives the same error.
                  draftomatic
                  Hmm well I just reinstalled SketchUp to this version:
                  Fastly error: unknown domain 151.101.1.91
                  (www.filehippo.com)
                  And it still can't find openssl.so
                  So perhaps it's not a problem with MR2...
                  • Dan RathbunD
                    Dan Rathbun
                    You could try:
                    Sketchup.require('openssl')
                    or
                    Sketchup.require('openssl.so')
                    it's a modified version of the Kernel.require method.
                    • Dan RathbunD
                      Dan Rathbun
                      By the way.. what are the green checkmarks over the folder icons mean ?
                        draftomatic
                        It's TortoiseSVN (I use SVN for version control). It doesn't modify the files and has never been a problem in over 200 revisions.
                          draftomatic
                          require('openssl') Error: #<LoadError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so: 126: The specified module could not be found. - C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so> (eval) C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/openssl.rb:17 (eval):0:inrequire'
                          (eval):0
                          false`
                          Interesting... does that mean anything to you? The latter returned false. Was it successful or no?
                          • Dan RathbunD
                            Dan Rathbun
                            It seems like TIG reported problems with access to Vista (64bit) folders during the last beta round, concerning the new rbz installer, but I thot the issue was resolved.
                            Check file permissions on the folders.
                            • Dan RathbunD
                              Dan Rathbun
                              false[/ruby]
                              It means (to me,) that [ruby:2l6gl0ii]Sketchup.require[/ruby:2l6gl0ii] still does not work as it should (rubywise.)
                              [ruby:2l6gl0ii]require[/ruby:2l6gl0ii] is supposed to return [ruby:2l6gl0ii]true[/ruby:2l6gl0ii] if the load was successful, [ruby:2l6gl0ii]false[/ruby:2l6gl0ii] if the file has ALREADY been loaded, and raise a [ruby:2l6gl0ii]LoadError[/ruby:2l6gl0ii] (or other,) exception otherwise.
                              Previous to the last MR, I had filed a bugreport on [ruby:2l6gl0ii]Sketchup.require[/ruby:2l6gl0ii] for various reasons, but one issue was that it was returning numerical error codes (which is a C thing, not a the Ruby way.)
                                draftomatic
                                Thanks Dan.
                                So, per your suggestion, I started going through the libraries that require 'openssl' and replacing it with Sketchup.require 'openssl'
                                It seemed to fixed one after the other, until I got this:
                                Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so 126: The specified module could not be found. - C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Light Stanza/lib/Ruby186/lib/ruby/1.8/i386-mswin32/openssl.so
                                Sorry, had a copy/paste error a second ago. Fixed it.
                                • Dan RathbunD
                                  Dan Rathbun
                                  Oh I REMEMBER what the problem is !!!!
                                  It Windows and how it handles custom icons for folders. When you change the icon for a folder, Windows sets it's read-only attribute (or similar.)
                                  This messes up Ruby.
                                  It's your Tortoise install changing the icons that is causing the problem.
                                  TIG is the one that figured this out during beta.
                                    draftomatic
                                    Eh, I don't think so. We also have a packaged installer that does not include any of the svn data. In fact I just stripped my plugin from the Plugins folder and used the installer, and still getting the same errors...
                                      draftomatic
                                      I don't suppose you have any references for this?
                                      Scott Lininger promised to get me into the next beta last time I met with him; unfortunately that doesn't help me today πŸ˜ƒ
                                      • Dan RathbunD
                                        Dan Rathbun
                                        If you copy the icon modified folders into the install package, they will have the modified flags. TIG had to completely recreate new default folders, and copy the files into the new folders.
                                        REALLY I am not making this up. It's a really stupid thing that Microsoft did.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Give me hour or so. I'll see what I can send you from the thread in the beta forum.
                                            draftomatic
                                            Are you kidding me?! I must have 75 different folders in my plugin. How am I supposed to do that?
                                            I am noticing however that the folders are in fact read-only. But SU isn't writing to them is it? It should only be reading? o.0
                                            I'm going to try removing the read only attributes from the folders, which yes, I know, is a pain in the butt on Vista. But I've done it before... argh
                                            • 1 / 3
