    Audi r8
    30 Posts 6 Posters 2.8k Views 6 Watching
    • F Offline
      fabiorossi
      @michaliszissiou said:
      Exporting using what?
      1. you own the pro version
      2. you use the free ruby obj exporter.
      3. a third party on line method.
      In any case vertices aren't welded. You can't apply smoothing.
      I use free ruby obj exporter and I can smooth the geometry!......sometimes I get the impression that we are talking about different software.... πŸ˜„
      my blog
      http://progettin3d.blogspot.com/
      • michaliszissiouM Offline
        michaliszissiou
        In blender/edit mode/select all[A]/[W] menu/remove doubles. How many removed? this welds these vertices.
        No, we're not talking about different software. The whole community noticed this. SU exports non welder vertices.
        • F Offline
          fabiorossi
          scottpara,
          thanks for the advice and compliments for the works, but there is a fundamental difference between showcases and cycles: you buy the first but the second .....................is freeeeeeeeeeeee!!
          my blog
            ScottPara
            Understood although free does not always equate to best. I was just trying to show a low cost ($995) solution for great quality rendering with a built in real time solution that works.
            Love the fact that some HATE my avatar.....
            • F Offline
              fabiorossi
              Scott believe me, no one doubts about the ability to Showcase but if you take a look around the net to looking for cycles tutorials you will be amazed!
              my blog
                ScottPara
                Does cycles offer a real time solution?
                Things I REALLY like about showcase:
                Alternatives (huge feature)
                Behaviors (accepts rigging from Maya)
                Real time rendering (done right).
                • F Offline
                  fabiorossi
                  just yesterday I discovered this feature of cycles ......
                  http://www.youtube.com/watch?v=b6Wm4r_FsrU&feature=player_embedded
                  my blog
                    michaliszissiou
                    Cycles is a modern render engine, a 2011 development. It still is alpha. Not all futures there, but I love it already.
                    You have to wait a few more months, yes development of blender is fast.
                    This last video doesn't show much. Yes, coordinates/windows projection, this probably goes for reflections.
                    You have to see and understand the superb nodes system to understand.
                    Here's a link to a small tut of me, in sculptris forum but shows what window projection means for textures. Nothing fancy but bumps are superb in cycles. We're going for micro displacements BTW, soon.
                    http://www.zbrushcentral.com/showthread.php?143454-My-beta-testing-doodles&p=917407&viewfull=1#post917407
                      sepo
                      Scott... Did you use Showcase or Showcase pro?
                        ScottPara
                        Showcase pro. Most users will never need pro IMO. It is not a perfect render engine but for a super small learning curve compared to results it is great. I rarely use anything else for product rendering. Once you start using things like alternative and behaviors you will realize the power of the software.
                          sepo
                          Is it possible to render the quality of that Mercedes render with Showcase (non pro)
                            ScottPara
                            Absolutely. Really not that big of a difference with Pro. As far as the render engine there is NO difference.
                              sepo
                              OK I am intrigued... I did try it last year and it looked really bad... So you are saying it is much better now. Do you have some very simple file willing to share which is already setup and looks good to render?
                                ScottPara
                                Sepo,
                                The differences between last year and this year are somewhat minimal. Mostly in file organization but very little in the render engine. I could have rendered the same results for the Mercedes with 2011 as I did with 2012. Showcase does take some getting used to in how the materials are set up and how the environment affects them. I do not have any files that I can share at the moment, most of what I have done is owned by a customer and in turn I can not share it. Showcase comes with 3 decent sample files that show the basic abilities of showcase. As with any software, it is going to take some investment in learning the process. If you need help or have questions send me a message as I would be more than happy to help. Once you get your feet wet with Showcase I think you will like it.
                                Scott
                                  sepo
                                  Thanks anyway. I will download it when I have some spare time.
                                    ScottPara
                                    fabiorossi,
                                    If you have not looked into Autodesk Showcase I would give it a try. It is really pretty straight forward. It will import FBX and dwg as well as many other engineering based formats. I have attached some of my more recent work using showcase. The Ram interiors and SLS have no post work done. The SRT8 Jeep has very little. These were not modeled in Sketchup (used Modo for most of it) although I wanted to show the capabilities of Showcase.
                                    http://usa.autodesk.com/adsk/servlet/pc/index?id=6848305&siteID=123112
                                    Scott
                                    • 2 / 2
