    Adding rain and splashes
    Scheduled Pinned Locked Moved Post Processing
    6 Posts 6 Posters 10.2k Views 6 Watching
      davidh
      This is a very quick and easy step by step.There are a lot of brushes for photoshop out there for creating rain but I have created a section and attached it here.Just use it with blend setting of "SCREEN" over your render and it will come through.
      For the splashes the process is as follows:
      1.Open the render and create a new layer called splashes.
      2.Using one of the default "star" brushes(see attachment for which one to use)paint a line of stars along the top of the walls.
      3.Add a motion blur at 90 degrees of between 30 and 40.
      4.Add a gaussian blur of about 7
      5.play around with the opacity of the layer but thats really it.The effect is that of rain hitting the surface and bouncing back up.Be careful in the strength of the effect that you use,it should be less for softer rain than for a heavy rainfall.
      You can use the same technique on vegetation (if you lighten the areas locally where the rain hits the leaves it can make the effect more pronounced,as if the leaves are so wet they are almost fully reflective)
      Hi Irwanwr,yes pretty much done with the holidays now but it was great while it lasted.
      • irwanwrI Offline
        irwanwr
        glad you have good time with your beloved ones, david.
        sometimes it just came into my mind, "when would david got a chance to have some rest, with this fast pace of productivity" πŸ˜„
        • Chris FullmerC Offline
          This is a great one David, thanks for sharing it! I love how simple these all are. For as much photoshop as I do, and as many little tricks of my own I've accumulated, everything you've shown is new to me. I'll hopefully get a chance to repay with some of my own tips and tricks in the near future, now that I'm back from vacation.
          Thanks again!
          • leedeeteeL Offline
            leedeetee
            David, even though I don't comment on every single thread, they are all so informative. Thanks so much for taking the time to write them. πŸ‘
            • boofredlayB Offline
              boofredlay
              Thanks again!!!
                jsmith
                Many, many heartfelt thanks for all you do - inspiring!
