    [concept] plugin launcher
    39 Posts 10 Posters 7.6k Views 10 Watching
    • srxS
      srx
      👍 Good concept...Keep on, please
      www.saurus.rs
        Aerilius
        I just found http://forums.sketchucation.com/viewtopic.php?t=22599. 😲 If I had found it before, maybe I wouldn't have realised this plugin. But on the other side it's similar but not really the same.
        @driven said:
        are you using the mac version
        When I made the animation, I didn't have a windows or mac machine arround, but the webdialog should match automatically to the color scheme of any OS.
        @driven said:
        Maybe as your web dialog loads the 'desired tools' ruby,
        I don't understand what you mean with "desire tools". I searchd for it, is that an existing plugin? Do you have a link for it? Or are you just referring to my index file?
          Jim
          Have been playing with this a little also and am starting to like it. A couple of I thoughts that I think would make it better:
          1. Be able to use multiple index.txt files to help organize the commands. It's easier to edit smaller files, and easier to group related commands (Fredo tools could go in fredo.txt, for example.)
          2. An option to close the dialog after a command is selected.
          I think I can nearly do away with the Plugins menu using this - and that's a good thing!
            Jim
            This topic might get more views if it were moved to the Plugins forum. It could be tagged as a "concept" there also. I understand why it's posted in the Dev forum, but it is too hard to find here because it is not listed in the index.
              driven
              I've had a play on the mac,
              I can only get some of it to work if I use 'enable debug' in scripts mode on the WebDialog.
              Once I've done that the Problems are:
              auto resize is not taking the menu bar height into account.
              when I have the WD menu with images, and click the image/area the commands to ruby don't run.
              Attached is the actual output html as seen by Safari in SU.
              Safari_LaunchUp.htm.zip
              Maybe someone can spot the problem...
                Aerilius
                I think it could have been the problem with Safari+onload. I added my current version (0.2).
                Note that that I added an index for demonstration purposes (it lists tools that are maybe not installed). That's because the fundamental obstacle is still that we don't have access to the commands of other plugins (I'm curious about Thomthom's aliasing or interception approach).
                The plugin contains a method LaunchUp.build_index which parses the other plugins to find their UI:Commands but the resulting index can contain mistakes and it's not a solution that I want to publish for common use, so it's still experimental.
                Actually a "search" user interface fits well in the scope of Google.
                  driven
                  @aerilius said:
                  hi,
                  I got some of it working, sort of, and I don't think the loading was the issue, on Safari.
                  It seems more to do with the focus function and works better if I comment out line 261
                  // $("combo-input").focus();
                  otherwise you add to the placeholder text rather then replace it.
                  Tab and Return key codes are intermittent.
                  Mostly they appear to be locked into the input box, even after the arrows have worked as intended.
                  When I changed it to show_modal, JPP worked once. soap skin, a couple of times...
                  also
                  in the ruby:
                  there seems to be an error line 90 it has if width I changed to if height so it doesn't 'over' shrink now.
                  in html:
                  Input type "search" [with css- margin top:4px;] looks better and doesn't seem to add to the problems.
                    Jim
                    I don't know what's going on - it's probably my computer. LaunchUp used to work, but now I get this at first:
                    And expanded:
                    I do tend to have a lot of problems with WebDialogs. I've never been able to figure out what is happening.
                      driven
                      @Jim,
                      did you ever get the default text?
                      what happens if you type into the box?
                        Jim
                        @driven said:
                        @Jim,
                        LaunchUp worked when I first tried it a few weeks ago - now a get the dialog which only shows me the source for the html. No idea what I did.
                          driven
                          @jim said:
                          • now a get the dialog which only shows me the source for the html. No idea what I did.
                          I would check other WD's first to see if it's a 'LaunchUp' specific problem
                          If you haven't touched the files, I'd look at the IE settings.
                          have you disabled js or set it to 'show as plain text'.
                          can you set those type of things a PC?
                          sorry, not very helpful
                            Aerilius
                            I have never seen this problem.
                            What happens when you create a webdialog on the console and then set_file(".../LaunchUp.htm") ?
                            I don't believe that, but could there be a reason that Internet Explorer thinks it's a plain text file and not html? (confused mime type, or is the encoding or file header wrong?)
                              Jim
                              When I inspect the html in the dialog, I see it is incorrectly nested somehow..
                              <HTML><HEAD></HEAD>
                              <BODY><PRE>&lt;!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/strict.dtd"&gt;
                              &lt;!--
                              This file is required by LaunchUp.rb"
                              Copyright 2011, Andreas Eisenbarth
                              All Rights Reserved
                                Aerilius
                                I'm not sure what is nested wrong? (I haven't found it yet)
                                I know many browsers internally prepend a <HTML><HEAD></HEAD><BODY><PRE> when they display plain text files, so maybe this is only the result instead of the cause why IE shows the plain text.
                                I found that the doctype makes no sense (transitional <-> strict). Can you try
                                <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
                                  Jim
                                  I tried the new doctype - nope. I got rid of the doctype and comment beginning the .htm file with <html> and it started working again.
                                  I put the doctype back in and removed just the comment - it worked.
                                    driven
                                    I've got v2 stable enough to start looking at it on Safari... Selection from the search results only works with new keycodes and not the mouse...
                                    HTML Changes include:
                                    added a break after 'form' and moved the js to below that break... so line numbers reflect this.
                                    Line 01- DOCTYPE html
                                    Line 22- added to body>> height:100%;
                                    Line 23- changed in form>> top:4px;height:inherit;
                                    Line 49- input type="search"
                                    Line 57- [<]br /[>] ...without []
                                    Line 59>>296- scripts
                                    Line 210/211- // left-arrow: select first entry
                                    if (keycode == 37) {
                                    Line 222/223- // right-arrow: execute entry
                                    if (keycode == 39) {
                                    Line 275- // $("combo-input").focus(); #jb_mac
                                    in the Rudy:
                                    this forces it to only scroll down
                                    Line 54- changed to @launchdlg = UI::WebDialog.new("LaunchUp", false, false, 0, 1140, 270, 50, true)
                                    Line 92- added @launchdlg.set_position(1140,0)
                                    to get it to show_modal
                                    Line 98>>102 + Line 110>>102- if RUBY_PLATFORM.include?('darwin') # Do NOT 'do this if on a PC! @launchdlg.show_modal else @launchdlg.show end #mac _modal
                                    I also set a shortcut key in 'system' preferences and have started updating the txt file.
                                      Aerilius
                                      Thank you so much for your efforts! I included it in the code. For me it used to work in my browsers/configurations, so otherwise I couldn't have found these solutions on my own.
                                      I did some search about comments between doctype and <html>, but didn't find anything about issues. I probably leave the comment completely away (or does it work with the comment after <html> ?)
                                      I was a bit hesitant about %(#000000)[input type="search"] because it's not standard (html4), but since unknown type defaults always to text, it shouldn't be a problem and doesn't break anything in Internet Explorer.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        It IS a bit weird that the comment is outside the <html> block... I would put it inside the <head> block as well.
                                        I'm not here much anymore.
                                          driven
                                          Hi all,
                                          I'm bumping this, because I want to modify it to work with 'on_off' http://forums.sketchucation.com/viewtopic.php?f=180&t=41994#p372262
                                          Using the option to open SU without rubies but with Ruby we have the ability to open individual .rbfiles or folders containing .rb files using Alex's + Jim's methods or load from RC, which is great.
                                          However if you want TIG's 2DTools [for example] you need to change all the 'requires' in all the scripts into 'load' + full the path before it will run with 'rubies' turned 'off'. I've got that working and it will still run as normal with them 'on', but would be a pain to do for each new version for all my rubies. I haven't worked out any of Fredo's yet, but I'm sure there's a way.
                                          So I'm thinking it would be a lot easier to parse the plugins each time you call one to 'load' and leave the originals intact,
                                          if it needs support files they can be added, but also need full path's.
                                          Basically, use 'LaunchUp' to select the 'standard' ruby rather then it's individual items,
                                          because you only need to have a few sets on at a time the toolbar count is still low.
                                          when you get to many you start again.
                                          I'm stumbling through so any feed back is appreciated.
                                            Aerilius
                                            This is very far from a proper plugin. Parsing other ruby files in order to get commands is not an ideal solution and needs always manual editing. I would not publish the current state as a plugin.
                                            I've played around with alternatives (should probably make my current version ready and post it here). I tried aliasing the UI::Command before all plugins load. Problem is that this way I modify core methods, I have to make sure that my plugin loads always first and it can be harmful if another plugin aliases UI::Command.
                                            Jim inspired me to get the commands with Objectspace, which works for all the command's metadata, but I haven't figured out how to call the proc.
                                            Third possibility is to continue hoping and begging for SU9 that we will have better access to commands (and maybe removing/modifying toolbars and menus).
