    What is the url for the google account sign in dialog?
    7 Posts 3 Posters 730 Views 3 Watching
      Shoff
      Trying to figure out what the url is for the google account sign in dialog. Anybody happen to know or have a suggestion as to how to figure out?
      https://lh4.googleusercontent.com/pNXZjWqnRk3On8wKnVB-wud9ArXr_-Ir6Gg6TUBcNGlGlCqA-_bJU8lwjiAF09SfEy2ivRfF6NkHJDnMN1mM959gumFhdw9IrZ4=w1024
      • GaieusG
        That username is an email address that you used to sign up for the 3D Warehouse. In the simplest situation, it is the same as your Google account email address (most often than not it is a gmail account but not necessarily).
        The password is just the password you have for this account.
          Shoff
          I think my question wasn't clear. I'm not a SketchUp newbie, I'm working on a plugin, and I I want to load that dialog window using the api, and I don't know what the url is for that dialog box.
          • Dan RathbunD
            Dan Rathbun
            It's not a WebDialog.. it's a native dialog, and there is no API send_action string for it (that I know of.) I also cannot bring up the dialog with the ID on Windows, so this may be a security feature in the Skethcup.send_action() method.
            You'll need to direct users to manually press the LogIn button (3rd from left,) on the statusbar.
            I'm not here much anymore.
              Shoff
              Dan,
              thanks for your help. I was hoping it wasn't a native dialog. I've been poking around in SketchUp.dat hoping that would give me a clue, and came across this:
              [SUBSTITUTIONS]
              // Explict Substitutions - currently only these three are supported
              {WAREHOUSE_SERVER}=http://sketchup.google.com
              {GWS_SERVER}=http://sketchup.google.com
              {VERSION}=gsu8
              [URLS google.com]
              HELP_GAIA_ACCOUNT_ACCESS=http://www.google.com/support/accounts/bin/answer.py?answer=48598&hl={GWS_CULTURE}
              HELP_GAIA_CREATE_ACCOUNT=https://www.google.com/accounts/NewAccount?continue=http://sketchup.google.com/3dwarehouse/&hl={GWS_CULTURE}&service=warehouse
              [GAIA]
              GAIA_ACCOUNTS=https://www.google.com/accounts/
              GAIA_WAREHOUSE_SERVICE_NAME=warehouse
              GAIA_APP_SIGNATURE=Google-SketchUp-
              Looks like native dialogs are calling urls. Don't think anything can be done with this, but thought you might find that interesting.
              • Dan RathbunD
                Dan Rathbun
                However... that dialog DOES popup if the user is NOT logged in, and certain commands on the Google toolbar are activated.
                See my [Code] post on Sketchup.send_action() args. (just updated it to show the cross-platform strings for ver 8+.)
                [Code] Sketchup.send_action() : Arguments to
                • Dan RathbunD
                  Dan Rathbun
                  IF you must, you can instantiate a UI::WebDialog object, that uses:
                  def login_to_3D_warehouse()
                    title = "3D Warehouse Login"
                    key   = "3D_Warehouse_Login"
                    settings = Hash[
                      ;dialog_title, title,
                      ;scrollable, false,
                      ;preferences_key, key,
                      ;min_height, 500,
                      ;min_width,  600,
                      ;height,     500,
                      ;width,      600,
                      ;left,       400,
                      ;top,        300,
                      ;resizable, true,
                      ;mac_only_use_nswindow, true
                    dlg = UI;;WebDialog.new( settings )
                    lang = Sketchup.get_locale[0..1]
                    dlg.set_url("https://www.google.com/accounts/ServiceLogin?service=warehouse&passive=1209600&continue=http://sketchup.google.com/3dwarehouse/?hl%3D#{lang}&followup=http://sketchup.google.com/3dwarehouse/?hl%3D#{lang}")
                    return dlg
                  end # login method
                  # elsewhere in your code;
                  login_to_3D_warehouse().show()
