    Summer/autumn
    45 Posts 18 Posters 7.7k Views 18 Watching
    • DanielD
      Daniel
      Beautiful images.
      My avatar is an anachronism.
        davidh
        attached is a revised image.I have lightened the building so it sits further back in the image.I have also desaturated it a bit and revised the foreground to add more texture .Rich,all trees and plants are 2d photoshop.for me,the fun only starts when I take the rendered image into photoshop.I try to render the minimum required with the model and then add all entourage in post.it saves a lot of time in rendering and allows extra leeway to experiment with vegetation.
          steelers05
          Look great...like 2 & 3 better than the other one
          • RichardR
            Richard
            Well I'll be buggered then!
            BTW number three is a reference photo right? πŸ˜„
            That is as good as it ever gets without doubt!
            BUILTBRAND.COM.AU
              davidh
              Attached is a lakeside version of the previous images.I have reused most of the original vegetation,just repositioning them.the reflection was done in photoshop using a technique from http://www.sketchupartists.org/tips-and-tricks/.
                davidh
                a misty morning version of the lakeside image.the model was re-rendered with a low sun but,again,all the same vegetation was used,just darkened and a low mist added over the far bank.
                • boofredlayB
                  boofredlay
                  Great!
                  I am sure you have been asked before but where do you get your Photoshop entourage?
                    davidh
                    A lot of the stuff I use over and over are Dosch and Evermotion products.I purchased them about 4 years ago and they were one of the best investments ever.But I also make a lot from images on the net,overlaying and blending in photoshop.I'm also constantly looking out for elements such as rocks leaves etc which can be easily extracted from their original image.It takes time but it means that you will have a ready made library and you can start post processing very quickly.
                    One thing I usually do is render out a very low res version of the model at the correct size and instantly start adding the entourage in photoshop while a hi res version of the render is cooking.Then, once the final model image is finished rendering at a higher resolution,you only have to drag and drop the hi res image in place of the low res and do some small tweaking.(I have attached a grass layer from the images, made in photoshop,feel free to use)
                    • boofredlayB
                      boofredlay
                      Great, thanks for the explanation.
                        davidh
                        1 more lakeside view with foreground depth of field added in the second image.the foreground rocks have had highlights burnt onto them in photoshop to try and make them more compatible with the lighting in the render.
                        • boofredlayB
                          boofredlay
                          Nice!
                            Roger
                            Very nice, most excellent, love it!
                            http://www.azcreative.com
                            • StinkieS
                              Stinkie
                              Very nice indeed! πŸ‘ I like the first one best.
                              Edit: I think (this might very well be a matter of personal preference!) the composition could be improved. Currently, the tip of the tower is in the upper part of the image. It should be in the lower part. Think of seventeenth-century Dutch seascapes - if that makes any sense. I've been wrong before, though! 😎
                                davidh
                                a distressed watercolour effect,maybe a bit too distressed!
                                  davidh
                                  a little less distressed
                                  • StinkieS
                                    Stinkie
                                    I like those. πŸ‘
                                    • B
                                      bhbarchitects
                                      Really nice renders, just something about the water, possibly reduce the reflection or more blur??
                                      Reflections in lake (photo)
                                        davidh
                                        I think looking at the above photo that the reflections in my renders should be much darker.Next render I'll try and do something similar.Its really all about getting the correct lighting.My favourite light is definetly the low evening/morning sun because its possible to get much more dramatic images.
                                        • pbacotP
                                          These are really nice! Both PR and WC. Peter
                                            Roger
                                            BORN TO RENDER
                                            • 1 / 3
