CAD new look for the fun!
For the fun because it's now again some cost!
[flash=560,349:1dme135t]http://www.youtube.com/v/XHOnhB3bPjI[/flash:1dme135t]But you have a free version here with less functions
Co Create modeling-express : free in Personal Edition!
Real-time, realistic 3D modeling
New modern user interface
Assemblies up to 60 parts(you will remark that the PushPull is some present
[flash=560,349:1dme135t]http://www.youtube.com/v/CmLwE104qn0[/flash:1dme135t]
[flash=560,349:1dme135t]http://www.youtube.com/v/Ni3Z6Tft8sQ[/flash:1dme135t]
[flash=560,349:1dme135t]http://www.youtube.com/v/bXxv2HVnunw[/flash:1dme135t]
[flash=560,349:1dme135t]http://www.youtube.com/v/4rD0zmA-Trc[/flash:1dme135t] -
PTC, put out one of the first parametric modeling tools, and ended up owning Personal Designer and CADDS. They have come a long way with their products. I tried to figure out the cost, but they have so many variations listed. Is it about $1k?
$1k * 6 for a complet product!
So not for hobbyist
Does the free version have at least the horse power that free SketchUp has? I looked at the comparisons, but am not able to judge. Did you install and run it?
Yes
(you must have an Internet connection for run it)
It's more for Industrial objects than architectural objects
And the concept to have a "work plan" is some disturbing against SU
A little training is necessary
I have tried also PowerShape and 1234D but Co Create is more near SU spirit
The crazzy thing is that you can load STP file (nurbs) in 3D and DWG & DXF in 2D
And you can export in STL (Polygons) for prototyping and 3D Print
(use MeshLab for transform it in OBJ for example)
You can of course also save in its native formatSo some possiblities for a free prog
it's a very nice toy for a 3D programs serial collectors
free has horse power that free SketchUp has
Yes as it has nurbs + boolean + Variable fillets + surfaces etc...
No as there is nothing for animation between scenes or specialised plugins (in free version)
and theoric limitation of 60 objects!
(Make boolean unions
It's a very strong strict modeler with Pushpull rotation inside!
The only default is cosmetic : icones are very uggly!
....The only default is cosmetic : icones are very uggly! :mrgreen:
Well, that by itself makes it completely unacceptable for an Architect.>_< Thanks for the update.
