π Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
Text tool default text
Is it possible to change default "Enter text" text for Text tool?
It is not an option in SketchUp, that I know. Why does it matter?
It's likely that "Enter Text" is a localized string, defined within the Sketchup executable's resources (ie, a string table.) It will change depending on which language edition the user is running.
You could write a custom Text tool, and use either UI.inputbox() or a UI::Webdialog instead.. then you can control what the default text is.
