    Getting cursor position while SP simulation is running.
    7 Posts 3 Posters 1.4k Views 3 Watching
      Anton_S
      I post this because of November92's question: http://sketchup.google.com/3dwarehouse/details?mid=c366d4f6b95601de846af18c94f69f1a&prevstart=0
      My Scirpt in previous model is old and is not working now because of different LS.
      November92 basicly wants to get the cursor position while simulation is running, so the script is here.
      Note:
      This script only works in SU8. For some reason SU7 crashes when click play.
      If anybody could make this script work in SU7 too, please post and say what is wrong in the script or what is need to be added or changed.
      Anyway, copy this script to Scripted file:
      onstart{
       #### Variables ####
       $cursor_pos=[0,0]
       #### Loading File ####
       if defined?($tempfile_loaded)==nil then #prevent from loading more than once
        directory=Object;;Dir.pwd.split(";/")[0]+";/"
        tempfile=Object;;File.new(directory+"SUtempfile.rb","w+")
        tempfile.puts('module MSketchyPhysics3
       class SketchyPhysicsClient
        def onMouseMove(flags,x,y,view)
         $cursor_pos=[x,y] #Here is our variable
         @mouseX=x
         @mouseY=y
         if @CursorMagnetBody==nil then return() end
         ip=Sketchup;;InputPoint.new
         ip.pick(view,x,y)
         if ip.valid? then
          if @pickedBody!=nil then
           @simulationContext.doOnMouse(;drag,@pickedBody,x,y)
           if getKeyState(VK_LSHIFT) then
            #project the input point on a plane described by our normal and center.
            ep=Geom.intersect_line_plane([view.camera.eye,ip.position],[@attachWorldLocation,view.camera.zaxis])
            @attachWorldLocation=ep
            pos=ep
           else
            ep=Geom.intersect_line_plane([view.camera.eye,ip.position], [@attachWorldLocation,Z_AXIS])
            pos=ep
           @magnetLocation=pos
           if @CursorMagnet!=nil then NewtonServer.magnetMove(@CursorMagnet,pos.to_a.pack("f*")) end
        end #OnMouseMove
       end #class SketchyPhysicsClient
      end')
        tempfile.close
        load(directory+"SUtempfile.rb")
        Object;;File.delete(directory+"SUtempfile.rb")
        $tempfile_loaded=true
       #### Functions ####
       def getCursor(state=0)
        view=Sketchup.active_model.active_view #Shortcut
        case state
         when 0, "coordinates";
          return($cursor_pos) #return's cursor coordinates
         when 1, "position";
          return(view.inputpoint($cursor_pos[0],$cursor_pos[1]).position.to_a) #returns 3d position
         when 2, "best_picked";
          return(view.pick_helper($cursor_pos[0],$cursor_pos[1]).best_picked) #returns entity
      Now by calling function getCursor(state) you can get the cursor position and some other.
      Example:
      ontick{
       Sketchup.active_model.entities[1].text=getCursor(1).inspect
      Other:
      Writing my scripts I always began using notepad++.
      If anybody need it go here, it's free: http://notepad-plus-plus.org/release/5.9.2
        MrDailyBlah
        i thought u can just use MSketchyPhysics3::getCursor(), and put an array number thingy after it?
        curpos=MSketchyPhysics3;;getCursor()
        mousex=curpos[0] #get x coordinate
        mousey=curpos[1] #get y coordinate
          Anton_S
          MSketchyPhysics3::getCursor() returns cursor position relative to the whole screen, but the other one in sketchup tool, return cursor position relative to view. In most sketchup plugins, we need cursor position relative to view, not relative to screen.
            MrDailyBlah
            ah yeah...
            but can't u use a formula to work it out? i mean use things like view.center() or view.corner(), and use the coordinates from MSketchyPhysics3::getCursor() relative to them? just a thought... πŸ’­
            mouseX=curpos[0]-view.corner(0)[0]
            mouseY=curpos[1]-view.corner(0)[1]
            mouseX=nil if curpos[0]>(view.corner(3)[0]) #constrains mouseX coordinate to right size of view
            mouseY=nil if curpos[1]>(view.corner(3)[1])#constrains mouseY coordinate to bottom size of view
            would that work?.. ❓ πŸ€“
              Anton_S
              No, you can't. view.center, and view.corner[n] also returns cursor position relative to view. If I would write view.corner(0) (the upper left corner), it would always return [0,0], so the function is kind of not useful...
              Well, though, there is probably another way πŸ’­ Using win32-api to locate sketchup view and get its position. It will only work on windows and for mac ox x, I would have to use its library. And yeah I, still don't have good knowledge of win32-api functions, so it'ill most likely take a while before there would actually be a good script. Plus rightnow I only peaked at mac os x library, so yeah, need time to benefit the script...
                mptak
                Can anyone tell me how to get a list of all of the methods attached to
                MSketchyPhysic3::
                like
                Thanks(:))
                  Anton_S
                  To get all module methods:
                  MSketchyPhysics3.methods MSketchyPhysics3.private_methods MSketchyPhysics3.instance_methods MSketchyPhysics3.private_instance_methods
                  You can examine the sketchy physics files to see those methods and here is the source to module: http://www.ruby-doc.org/core-1.9.3/Module.html
