    Interest in a Networking Sockets Workaround
    29 Posts 6 Posters 8.0k Views 6 Watching
      RabidCicada
      It would be event driven. You'll have to set up your own structure on your side for mapping the socket_id to whatever handler you want to handle it.
      On the sketchup side you would sit in an infinite loop reading from the named_pipe_file and then parse and handle everything that comes through.
      Given the example I provided above of it you would have to read in then parse SOCKET_ID EVT_ID DATADATADATA.
      I'll work on it some more in the coming couple weeks. It's not that difficult at all...I just don't have lots of time.
      • RichMorinR
        RichMorin
        Just wanted to note my interest in this effort. I'd love to have a reliable way to send and receive data on sockets.
        However, I'm curious why you're writing the server in C++. Is there some reason why it couldn't be written in Ruby?
        • tbdT
          tbd
          you will have a lot of fun with Sketchup stucked in an infinite loop. or you can use the existing Sketchup Bridge that I made in 2006.
          http://plugins.ro
            RabidCicada
            Wow....I forgot all about this.
            I'll check out your bridge. Looks like you probably tooka the same route I did. I had a successfulbridge built for quite some time....just never finished flushing out the command set.
            The client of the bridge wont have a problem sitting in an infinite loop. I handle that in the bridge.....and last I checked the google API supported threads...so that wouldn't be an issue.
            Any other concerns to be aware of TBD?
            • tbdT
              tbd
              the client bridge, the one that runs inside Sketchup in ruby code must return quickly otherwise Sketchup UI will freeze in "white death" as it is mono thread
              http://plugins.ro
              • Dan RathbunD
                Dan Rathbun
                For the Sketchup side you'll need a message queue and an Observer.
                Here's a preliminary example that seems to work.
                It uses an AttributeDictionary as the queue, and an EntityObserver (since that's the superclass of the AttributeDictionary class.)
                dictspy.rb
                ISSUES:
                (1) This approach will likely need an AppObserver and ModelObserver as well, to be sure that the 'SocketQueue' dictionary is removed from the model before saving, and when Sketchup closes.
                (2) May need modifiction to work on Mac with mutilple models open.
                I'm not here much anymore.
                • Dan RathbunD
                  Dan Rathbun
                  A word about the queue keys.
                  They will need to be unique and/or oridinal. Perhaps a timestamp string?
                    RabidCicada
                    Thanks guys. I appreciate the help you are willing to give:).
                    My motivation for doing this network bridge was because I wanted to pursue a larger project that required network comms.
                    I just recently became interested in actually doing that original project again so I think I will pick this up and run with it πŸ˜„
                      RabidCicada
                      Sorry I never answered this. I believe you've probably figured it out by now but Sketchup doesn't support sockets. Not in an official sense and not very well even in the hacked up unofficial sense:)...or at least...last time I looked (long time ago)
                      • Dan RathbunD
                        Dan Rathbun
                        Strange that for all the interest, noone at all took a look at the code example in my previous post.
                          RabidCicada
                          Hey Dan,
                          Tried to load it up...Don't know how to get it to work.
                          Running latest free Sketchup version and installed RDE etc. I think I execute the script correctly via your isntructions (copied all files into plugin dir, start sketch, start RDE, register Script, run code)but nothing valueable happens. I hit "run" after I type Sketchup.version into RDE....nothing useful, just error. Could use a little help if you really are up for getting your Ruby Bridge out there.
                          I'm using Sketchup 8 on Windows 7.
                          Your example ruby code for the Dictspy.rb doesn't do any good without the bridge part.
                          My Bridge was specifically networking...but if you get the whole shebang then I can just build ontop. Failing any further input from you I can keep working on my own interface which would be just the networking sockets.
                            RabidCicada
                            It seems that Sketchup is running the bridge_load script as I can get UI.messagebox statements that I put into it.
                            I even get the "SketchUp Bridge already started", if I force RDE to run the macro via Macro->SUB. So it seems like something is getting executed.
                            But when I go to use Sketchup.version in RDE I get C:/Users/RABIDC~1/AppData/Local/Temp/rb4126.tmp:1:in `<main>': uninitialized constant Object::Sketchup (NameError)
                            Which makes me think it's not being recognized.
                            I know I could have all sorts of configuration problems so let me know what you think. Ruby 192, windows 7, Sketchup 8.
                            • Dan RathbunD
                              Dan Rathbun
                              @rabidcicada said:
                              Hey Dan,
                              Of course not! (I was showing what needs to be done on the Ruby-side.)
                              YOUR bridge needs to write "transactions" (which will be attributes consisting of a key [a unique timestamp is fine,] and a value which would be your data [as described in the first post,]) to the attribute dictionary of a special name.
                              I chose the dictionary name 'SocketQueue' for the example.
                              On the C++ side, you'll need to get the handle to the current model, and write your messages to the attribute dictionary named 'SocketQueue', using it's set_attribute() method.
                              You don't have a choice. The only way to have Sketchup perform an event-driven task, (because Sketchup "owns" the event loop,) is to use one of the Ruby API's observer classes that reacts to changes in a list-like object. The only candidate is the the AttributeDictionary class for the queue (which is a subclass of Entity,) and a custom EntityObserver subclass.
                              Then to process messages you (or whomever uses the bridge,) needs to replace the comment:
                              # This is where the message processing conditional statement goes.
                              (within the process_message method,) with some kind of conditional statement block(s) (if or case, etc.) that processes the messages.
                              In practice it may be easier if coders create a subclass of the DictSpy, and override the process_message() method. The name DictSpy could be changed to QueueSpy, SocketQueueSpy, etc. whatever you wish.
                              You can get fancy and add a module method that dettachs the observer to stop processing, and another to attach it again. Perhap some queue methods to clear the queue, etc.
                              • Dan RathbunD
                                Dan Rathbun
                                Sketchup 8 loads Ruby v1.8.6-p287
                                Sketchup cannot load Ruby in the 1.9.x branch (as far as I know, unless you found some trick?)
                                RDE could be the problem... try testing your code using Alex's WebConsole/Editor.
                                • tbdT
                                  tbd
                                  RabidCicada how do you run the code in RDE ? from that error it looks that you dont use sub.exe to send the code from RDE to SketchUp via SketchUp Bridge
                                  http://plugins.ro
                                    RabidCicada
                                    Thanks for the responses.
                                    I am SEVERELY unfamiliar with hacking up sketchup...FYI.
                                    Question:
                                    Does Sketchup have it's own local copy of Ruby 1.8.6 etc? Or are you saying that I must use that version if I am to successfuly drive sketchup externally?
                                    I run code through RDE by simply typing it into the main editing window and then selecting "run" from the menu. Is that not the right way?
                                    I've already registered the SUB script with RDE.
                                    I may not be "executing" ruby code the right way. I start Sketchup with the scripts and exe in the plugins directory. I believe bridge_load.rb runs because I get a messagebox notification I put in there on purpose (for the success case). Then I start RDE. I run SUB script via toolbar->macro->SUB (I get the error about only one instance being allowed). Then I type some code into the normal box in RDE. Then I hit "run" and I get the error.
                                    Am I supposed to do things differently?
                                    I would appreciate if you laid out an exact step by step example to successfully execute a "Hello World" in a messagebox from the RDE interface.
                                      RabidCicada
                                      Should I separately install Ruby 1.8.6?
                                        RabidCicada
                                        Thanks for the pointer to Alexs stuff...I'll play with that also.
                                          RabidCicada
                                          Oh...Wait a minute....
                                          I'm at work so I can't test this but.....
                                          Are you supposed to (For each and every piece of Ruby code you want to execute):
                                          (1)Put your code in normal RDE console
                                          (2)Execute SUB script via Toolbar->Macro->SUB
                                          I assumed that the bridge was a constant bridge and that you just execute it once....then input and "run" ruby code as normal in RDE.
                                          • tbdT
                                            tbd
                                            yup, that is the workflow to use SketchUp Bridge. there is no need to install separately Ruby 1.8.6, but it helps in developing (checking source, running quick tests outside Sketchup in an automated way, ...)
                                            http://plugins.ro
