    JSON in Ruby
    48 Posts 7 Posters 8.5k Views 7 Watching
      jeemang
      Quick question: what are people using to create JSON strings in Ruby? I did a little poking around and apparently even the "pure" version of the JSON implementation for ruby doesn't work within Sketchup, which my testing seems to confirm. So, I thought I'd see if anyone had any suggestions in this area.
      Thanks,
      Josh
      • Dan RathbunD Offline
        Dan Rathbun
        Well if you look at a Hash using the .inspect() you will see that it looks almost like JSON, except that the "=>" symbols need to be replaced with ":" (a colon.)
        So for a quick and dirty simple JSON string you might try bulding a Hash of values:
        hash = {} hash['KeyOne']= somevalue
        .. etc ...
        jsonStr = hash.inspect.gsub('=>',':')
        I'm not here much anymore.
          Dan Rathbun
          I guess I should cover what happens in the other direction, when you are returning a JSON string from a webdialog, and want to use the data on the Ruby side.
          You reverse the process of "=>" to ":" replacement, then eval() the string back into a Hash object.
          Ex:
          hash_obj = eval( jsonStr.inspect.gsub(':','=>') )
          πŸ’­
          Works as long as you don't have any colons embedded within any of the string datavalues. If you do, you'll need to iterate the hash_obj afterward, and replace them.
          hash_obj.each {|k,v|
            hash_obj[k]= v.gsub('=>',';') if v.is_a?(String)
            jeemang
            Hi Dan;
            Thanks for the response -- I'll give that a shot.
            Josh
              Myhand
              You can also try this class wrote. It can serialise Ruby objects, including nested arrays and object graphs and escapes strings to produce valid valid Ruby. I did not need de-serialisation so have not added that yet.
              http://www.keepingmyhandin.com/Downhome/Sketchup/simplejsonserializerrubyimplementation
                Dan Rathbun
                Thanx for sharing.
                However it has one major drawback. You defined your class at the toplevel. This should be reserved for Ruby Core basclasses.
                Why? We all cannot be defining custom classes in the global ObjectSpace, otherwise MY class JSON will clash with YOUR class JSON !
                Custom classes should be defined within YOUR "Author" namespace, or sub-namespace, however you wish to organize it.
                For example:
                module MyHand
                  module Lib
                    module JSON
                      # the code here
                    end # module JSON
                  end # module Lib
                end # module MyHand
                Then if anyone (including you,) wishes to use it from within one of their sub-modules, they have several options.
                (1) Create a reference that aliases into your lib class:
                module Author
                  module NiftyPlugin
                    # make sure the lib file is loaded
                    require("myhand/lib/json.rb")
                    # create an alias;
                    JSON = MyHand;;Lib;;JSON
                    # use it;
                    json = JSON.new()
                  end # module NiftyPlugin
                end #
                (2) Make your JSON a MIXIN module instead of a class.
                Users then mix it into their nested namespaces:
                module Author
                  module NiftyPlugin
                    # mix in the library module, as a nested class;
                    class JSON
                      # bring in methods as instance methods;
                      include(MyHand;;Lib;;JSON)
                      # bring in methods as class methods;
                      extend(MyHand;;Lib;;JSON)
                    end # class
                    # use it calling a class method;
                    str = JSON.escape("\tHello World!\n")
                end #
                They can do similar by mixing into a nested module.
                In fact the way you wrote it, the methods never the ref to the self instance, so basically you wrote class (ie, singleton) methods, so it really IS a library module, but you mis-defined it as a class.
                If you change it to a module (within some custom modular namespace,) and then at the top of the module call module_function(), and Ruby will make a copy of each of the methods for you (one instance and one singleton.)
                πŸ’­
                  Aerilius
                  Just for completion, if someone uses Dan's simple example it works well if you know what key/values you have (configurations, options...).
                  In case you don't know the possible values (ie. user input that might contain colons : or =>), you have to make sure that you don't replace them within strings, only between keys and values.
                  def from_json(json_string)
                    # split at every even number of unescaped quotes; if it's not a string then replace ; and null
                    ruby_string = json_string.split(/(\"(?;.*?[^\\])*?\")/).
                      collect{|s|
                        (s[0..0] != '"')? s.gsub(/\;/, "=>").gsub(/null/, "nil") ; s
                      join()
                    result = eval(ruby_string)
                    return result
                  rescue Exception => e
                  def to_json(obj)
                    json_classes = [String, Symbol, Fixnum, Float, Array, Hash, TrueClass, FalseClass, NilClass]
                    # remove non-JSON objects
                    check_value = nil
                    check_array = Proc.new{|o| o.reject!{|k| !check_value.call(k) } }
                    check_hash = Proc.new{|o| o.reject!{|k,v| !k.is_a?(String) && !k.is_a?(Symbol) || !check_value.call(v) } }
                    check_value = Proc.new{|v|
                      if v.is_a?(Array)
                        check_array.call(v)
                      elsif v.is_a?(Hash)
                        check_hash.call(v)
                      json_classes.include?(v.class)
                    return "null" unless check_value.call(obj)
                    # split at every even number of unescaped quotes; if it's not a string then turn Symbols into String and replace => and nil
                    json_string = obj.inspect.split(/(\"(?;.*?[^\\])*?\")/).
                      collect{|s|
                        (s[0..0] != '"')?                        # If we are not inside a string
                        s.gsub(/\;(\S+?(?=\=>|\s))/, "\"\\1\""). # Symbols to String
                          gsub(/=>/, ";").                       # Arrow to colon
                          gsub(/\bnil\b/, "null") ;              # nil to null
                        s
                      }.join()
                    return json_string
                  • OricAtmosO Offline
                    OricAtmos
                    Is there a reason to avoid libraries like Yajl, because that's what I'm using. I should note that our plugin isn't distributed in any way and only used internally so far and I just put all necessary Yajl files in a sub folder inside our plugin folder. So that's not too pretty I guess, but it works fine.
                      Myhand
                      Thanks! I have not seen Yajl. Will give it a try. I tried
                      http://flori.github.com/json/doc/index.html
                      before but could not get it to work within Sketchup hence me writing my own class.
                        Myhand
                        @dan rathbun said:
                        Thanx for sharing.
                        Thanks Dan, this class is actually part of a module in my code, I just cut and pasted it out to show how it works. Thank you for the tips about libraries though, I have not explored this side of Ruby yet.
                        You say that my methods are class methods. But I have done some tests and they seem to behave as object methods. i.e. each has access to the object's local state variables. I can also not call them as you would call a static method, i.e. JSON.escape().
                        Why do you think my methods are static?
                        Cheers
                          Myhand
                          Hi OricAtmos, I tried to get this to work but keep getting errors when trying to include the library:
                          require 'yajl'
                          fails with the following error:
                          load "c:/temp/yajl_test.rb"
                          Error: #<LoadError: c:/temp/yajl.rb:1:in require': no such file to load -- yajl/yajl> c:/temp/yajl_test.rb:1 c:/temp/yajl.rb:1 c:/temp/yajl_test.rb:1:in require'
                          (eval):1:in `load'
                          (eval):1
                          How did you install the library?
                            OricAtmos
                            I think it might have to do with the library search paths or something. I'll get back to you tomorrow with the details.
                              Dan Rathbun
                              require 'yajl'
                              If you do not specify some kind of filepath, then the file must be in one of the directories listed in the $LOAD_PATH array.
                              Ruby's require() first checks to see if the argument resolves to an absolute path, and if so, checks to see if the file exists, and if true, attempts to load it.
                              Secondly, it checks to see if the argument is a relative path (incl. no path at all,) and if so, require() then iterates the $LOAD_PATH array prepending the base paths in front of your relative path. If it finds match, it loads the file, IF such a path is NOT ALREADY present in the $LOADED_FEATURES (aka $") array.
                              What does the following LoadError exception message tell you?
                              Error: #<LoadError: c:/temp/yajl.rb:1:inrequire': no such file to load -- yajl/yajl>`
                              Answer: That "c:/temp/yajl.rb" on line 1, is calling require("yajl/yajl"), but no file named "yajl.rb", "yalj.so", "yalj.dll", etc., can be found, because it's a relative path, and there is no path containing a "yalj" SUB-directory in the $LOAD_PATH array, containing a file (of any valid extension that require() can load,) named "yalj".
                              IF you simply copied the "yalj" directory into the SketchUp "plugins" directory, and typed require("yajl/yajl") in the SketchUp Ruby Console, it would be found. (Not to say that it would work, because it itself may have other file dependencies, such as Standard Ruby library files, which requires you to have a full Ruby installation, AND push it's library paths into the $LOAD_PATH array.)
                              Understanding require() and load(), and how they use (or not,) the $LOAD_PATH (aka $:) and $LOADED_FEATURES (aka $") arrays, is Ruby 101 week 1.
                              Click on the link in my signature, and follow the advice to collect docs. And just below my Newbie Guide, I posted the old "Pick-Axe" book. Required reading.
                                Dan Rathbun
                                OK Example:
                                Assume your "plugins" dir, has sub-dir "myhand", which has a sub-dir "lib", which contains a file "json.rb"
                                I recommend having your nested dir names match your nested namespaces, so you can remember the relative paths when it comes time to type a require expression.
                                module MyHand
                                  module Lib
                                    module JSON # mixin module
                                      def escape(value)
                                        ret = ""
                                        value.split("").each do |c|
                                          if (/["\\\/\b\f\n\r\t]/.match( c ) )
                                            ret << '\\' << c
                                          else
                                            ret << c
                                        return ret
                                      end # escape()
                                    end # module JSON
                                  end # module Lib
                                end # module MyHand
                                .. and in a plugin:
                                module Author
                                  module NiftyPlugin
                                    # mix in the library module, as a nested module;
                                    module JSON
                                      # bring in public mixin instance methods
                                      # as public module methods in THIS module;
                                    end # module
                                    # use it calling a module method;
                                    puts(str)
                                end # module Author
                                OR ... using module_function() like the Math module does ...
                                module MyHand
                                  module Lib
                                      module_function()
                                      def escape(value)
                                        ret = ""
                                            ret << '\\' << c
                                          else
                                            ret << c
                                        return ret
                                      end # escape()
                                    end # module JSON
                                  end # module Lib
                                end # module MyHand
                                .. and in a plugin:
                                module Author
                                  module NiftyPlugin
                                    # Use a library module function, via a
                                    # local constant aliasing the library;
                                    puts(str)
                                end # module Author
                                  OricAtmos
                                  Dan already explained more than I could have. He also wrote a nice ruby script to include additional folders in $LOAD_PATH. Read all about it here: http://sketchucation.com/forums/viewtopic.php?f=180&t=29412&p=342471&hilit=!loadpaths
                                    Myhand
                                    @dan rathbun said:
                                    require 'yajl'
                                    Thank you Dan for the detailed explanation and links to starter guides. I will review and try this when I get home tonight. One interesting point in this case though is that the only file called yajl.* is c:/temp/yajl.rb which is also the file that contains the
                                    require 'yajl/yajl'
                                    line. There is a a subdirectory called yajl, but no files named "yajl.rb", "yajl.so" or "yajl.dll" anywhere else in the yajl library distribution... So cannot see how adding the "c:/temp" path to $LOAD_PATH will find the file as it does not appear to exist.
                                    Will let you know.
                                      OricAtmos
                                      Sounds like you don't have the complete library.
                                      This is a list of files I have in my Yajl folder:
                                      [...]\rubylibs\yajl.rb
                                      [...]\rubylibs\yajl\1.8\yajl.so
                                      [...]\rubylibs\yajl\1.9\yajl.so
                                      [...]\rubylibs\yajl\bzip2.rb
                                      [...]\rubylibs\yajl\bzip2\stream_reader.rb
                                      [...]\rubylibs\yajl\bzip2\stream_writer.rb
                                      [...]\rubylibs\yajl\deflate.rb
                                      [...]\rubylibs\yajl\deflate\stream_reader.rb
                                      [...]\rubylibs\yajl\deflate\stream_writer.rb
                                      [...]\rubylibs\yajl\gzip.rb
                                      [...]\rubylibs\yajl\gzip\stream_reader.rb
                                      [...]\rubylibs\yajl\gzip\stream_writer.rb
                                      [...]\rubylibs\yajl\http_stream.rb
                                      [...]\rubylibs\yajl\json_gem.rb
                                      [...]\rubylibs\yajl\json_gem\encoding.rb
                                      [...]\rubylibs\yajl\json_gem\parsing.rb
                                      [...]\rubylibs\yajl\version.rb
                                      [...]\rubylibs\yajl\yajl.rb
                                        Myhand
                                        Yes OricAtmos, I think you are right. I took my version from here
                                        https://rubygems.org/gems/yajl-ruby.
                                        As I cannot install the gem in Sketchup I unzipped the gem file and took the files from the lib directory. This gives me the following files which is clearly not complete.
                                        C;\Temp\lib\yajl
                                        C;\Temp\lib\yajl.rb
                                        C;\Temp\lib\yajl\bzip2
                                        C;\Temp\lib\yajl\bzip2.rb
                                        C;\Temp\lib\yajl\deflate
                                        C;\Temp\lib\yajl\deflate.rb
                                        C;\Temp\lib\yajl\gzip
                                        C;\Temp\lib\yajl\gzip.rb
                                        C;\Temp\lib\yajl\http_stream.rb
                                        C;\Temp\lib\yajl\json_gem
                                        C;\Temp\lib\yajl\json_gem.rb
                                        C;\Temp\lib\yajl\version.rb
                                        C;\Temp\lib\yajl\bzip2\stream_reader.rb
                                        C;\Temp\lib\yajl\bzip2\stream_writer.rb
                                        C;\Temp\lib\yajl\deflate\stream_reader.rb
                                        C;\Temp\lib\yajl\deflate\stream_writer.rb
                                        C;\Temp\lib\yajl\gzip\stream_reader.rb
                                        C;\Temp\lib\yajl\gzip\stream_writer.rb
                                        C;\Temp\lib\yajl\json_gem\encoding.rb
                                        C;\Temp\lib\yajl\json_gem\parsing.rb
                                        Where did you get the library from?
                                        Cheers,
                                        myhand
                                          OricAtmos
                                          I don't remember where I got the Windows binaries from. Perhaps I still have a bookmark in my web browser at work, but right now I'm at home and can't have a look. But since I have access to our project repository from home I can offer you this:
                                          Dropbox - 404
                                          (dl.dropbox.com)
                                            Myhand
                                            Dropbox - 404
                                            (dl.dropbox.com)
                                            Thanks OricAtmos! Will give it a try.
                                            • 1 / 3
