    Truck & trailer application?
    32 Posts 5 Posters 22.9k Views 5 Watching
    • W Offline
      wyatt
      I agree, it's very close. I think the front wheels should turn right or left at the same time. Right now they swivel around the hinge independently so one wheel turns left while the other turns right. Maybe it's only the steering column that I'm missing? The rear wheels on the truck and trailer are fine as they are.
      • W Offline
        wyatt
        I have it working now, at least sort of. I had to move the steering column off the model and use a box pulling the truck like you did in your example. I can hide those groups so they won't show in the final animation, but I would expect there to be a better way. So far it's been the only way I could get the front wheels to turn properly.
        Another question is why the box sinks and drags the front wheels down with it. I have it set to no collision to avoid the box bumping across the ground. Is there a way to keep the wheels from sinking with the box?
        Also, is there a way to increase the speed of the truck following the curve? It would be great if the speed could actually vary (slower as it comes around the corner and then increasing to approximately 30mph).
        [edit] I found this explanation at google codes:
        setVelocity takes a vector that is the direction the object will
        #be moving and the length of the vector is how fast. It is different
        #from push because it actually sets the objects velocity rather than
        #just try to push it.
        onstart{
        setVector([0,0,10]) #set object to moving straight up at speed 10
        The sample code you had written has setVelocity(dir.to_a). I'm a little confused why this code starts setVector, but setVelocity([0,0,10]) works as described. I assumed dir.to_a would replace the distance and direction in this code. Adding the third variable doesn't seem to do anything.
        AnimationTest5.skp
          Mr.K.1
          Ya the model is as it should be now, needs just a couple of tweaks.
          • since you don't want the box to pull downwards you should just align everything at wheel height, even the curves, then it will pull at the same height
          • new ball joints come with angle restrictions, best to make them 0 for this system
          • you put motors on the front wheels, and motors don't like to be pulled, hinges are the best choice for this sort of setup
          • you steering rack seems to be a bit off center, that messes with steering a little
          The speed... well that need a bit of script tweaking, you know what I'll just add an updated example.
          And I made this steering example since it requires the least code, and the rest is just plain physics, I can try set up other examples if you need them.
          setVelocity(dir.to_a), dir.to_a is used because dir was a Sketchup class called Vector3d(allows easy vector manipulation), but since SketchyPhysics only needs the raw numbers the .to_a addition changes that vector class into an array like [0,0,10].
          I guess I could have mentioned it before, I just forget others aren't as familiar with these scripts
          AnimationTest5.skp
          • W Offline
            wyatt
            This is beautiful Mr. K! Thank you for all the examples, and for your patience as I attempt to learn the plugin. I greatly appreciate all your help.
            One question about integrating this with the rest of my model... The final animation I am making needs to have the camera drive down the road towards the truck as it pulls off a side street, comes toward the camera, and passes by it. I want the camera to remain looking straight ahead and not track the truck as it goes by. I have other plugins that animate the camera and create scenes. I have read that in previous versions SP was not scene-based but it might be in the future. I see that I can export animations from SP to skp's and it will create a series of skp files with the truck moving incrementally. Without a scene-based export, it seems that I could manually create the animation by copying the truck into each scene of my base model, but that seems difficult. I know you included a camera script earlier. Would modifying that be the best way to create my animation? When I started this project I had always envisioned doing a scene-based animation; but now that I've gone the SP route I guess I may need to go totally SP to finish it.
            • W Offline
              wyatt
              I've inserted the truck into my base model, set the base terrain group to static mesh and all the other objects (buildings, light poles, cars) to ignore (I've also tried static), an when I press play nothing happens. SU just locks up. After about 10 minutes of waiting I close out and try again. The model is only 108K faces. I've tried freezing all layers except the static mesh and the truck, as well, but that doesn't seem to have any effect. Is there something I'm forgetting to do?
                Mr.K.1
                Most likely there are too many groups to handle or your static-mesh is too complex(too many faces), that is usually the problem of freezing on startup.
                It's best to make statimesh only the portion of road you really need, and set all non essential groups/components to ignore.
                As for the camera, well the example script should work quite well, as long as you give it a good curve to follow.
                Exporting the animation tho I have no clue about, haven't used that myself, but I know there are alot of threads on these forums about those things.
                • W Offline
                  wyatt
                  I know you may not have much experience with exporting, but I can't find much on Sketchy Replay in the forums. Is there a reason that the exported images using Sketchy Replay wouldn't follow the camera? Yesterday I had everything working perfectly, recorded the animation and exported to jpgs. But when I opened the jpgs this morning I see the objects moving, but the camera is located in a random position off to one side, not following the desired object as the on-screen animation showed. Maybe I need to try a screen-capture program to get the animation.
                  For some reason after that export fiasco, without saving the model, the curve I want the camera to follow has now reversed. Is there a way to force a curve to reverse? It doesn't seem to matter which way I draw it, SP always assumes the opposite end is the beginning. I have tried modifying the speed control script to use the max_distance-frame script you wrote earlier, but adding those lines seems to disable the script altogether.
                    Mr.K.1
                    Ya SP recording doesn't have on option to add camera recording, I guess in this case that is quite crucial... I don't know howmuch work it would be to add this, but I'll have a look at the files.
                    You could also record it with Fraps, not really ideal but it's the only thing I know.
                    Curves tend to flip directions at random, and not just when created but also when you open/close the file, it can't really be helped because only SU has full control over curves, so scripts need to be adapted.
                    If you can't fix the script make a model with just the curve in question and your scripted object and I'll fix it up to work.
                    • W Offline
                      wyatt
                      Yeah, recording the camera view is really important. I have a screen recorder so if I can get the camera and curves working properly, I think I can get something usable, even if the files can't be modified.
                      I attached a file with the curve reversed. The model actually contains two curves, an "original" that follows the terrain and a "simplified" that is a roughly straight-line approximation of the original. My first intention was to have the camera follow the actual terrain so I would have a constant 5' eye height, but the one time I actually got everything to work correctly that seemed to create jitters in the camera that I didn't like. So if the simplified curve will be smoother, I'm fine with the relatively constant eye height. I replaced the camera script I had tried previously with the one you wrote for softsoap. I only need the camera to move along the curve. The box pulling the car is only there because I want the view angle of the camera to adjust to the curve as it wiggles near the end, and to help achieve the more accurate eye height described above. Using the steering column is the only way I've been able to get the camera angle to adjust in that manner. Other than that, I have no need for the "car" itself.
                      I am using your "speed control" script with the max_distance-frame lines added to try and reverse the curve. When I switched the equation to read distance=(frame-max_distance) the camera stayed at the proper end of the curve, but did not actually move as desired.
                      CameraCurve.skp
                        Mr.K.1
                        Alright did a quick fix up of SP files to add camera recordings, but make sure you backup your original files in case this doesn't work for you.
                        So make sure you backup your /Sketchup/Plugins/SketchyPhysics3 folder, and then extract these two files in there.
                        SketchyPhysics3.rar
                          Mr.K.1
                          I think this is how you wanted the script, try it and let me know.
                          CameraCurve.skp
                          • W Offline
                            wyatt
                            The new SP code seems to work fine on a test model. I can't run the simulation on the cameracurve.skp though. I get the attached error. I'll try to download SU7 if you think that might be causing the problem.
                            • W Offline
                              wyatt
                              I copied everything into a new file and it works, but I'm not sure what it's doing. The car travels the right direction down the curve, but the camera watches the car as it goes by from about ground level. Should the camera be moved to the curve, or joined in some way to the car/box? If I read the script correctly, I thought the camera would get the car location whereever it was and follow it.
                              • W Offline
                                wyatt
                                Alright, this is just bizarre. I downloaded the file again, copied everything to a new file, and the simulation seems to run ok now. โ“ The only thing this doesn't do is give me the first-person view that I need. I need the camera view to be coming from the box looking straight down the curve.
                                • W Offline
                                  wyatt
                                  I think I just got it to work! I got rid of the car and the second curve entirely and added this code to the camera On Tick dialogue:
                                  @RedAxis=1
                                  @GreenAxis=0
                                  @BlueAxis=00
                                  target=$curEvalGroup.bounds.center
                                  eye=[$curEvalGroup.bounds.center[0]-@RedAxis,$curEvalGroup.bounds.center[1]+@GreenAxis,$curEvalGroup.bounds.center[2]+@BlueAxis]
                                  up=[0,0,1]
                                  Sketchup.active_model.active_view.camera.set eye,target,up
                                  I'll post the video once I get it cut. Crossing my fingers that there are no more big hiccups.
                                  • W Offline
                                    wyatt
                                    Here's the completed animation. Thank you so much for your help, Mr. K.
                                    • F Offline
                                      faust07
                                      Would be great if the modifications for camera recording (Mr.K.) could be integrated in to the improved version of SP by AntonS, if it isn't yet.
                                      • 2 / 2
