    UI.messagebox
    9 Posts 3 Posters 1.7k Views 3 Watching
    • sdmitchS
      sdmitch
      In the middle of testing out a new plugin I was creating, the UI.messagebox stopped displaying. The command was being executed because I could hear the beep and the plugin would lock up until I pressed Enter. I added a UI.messagebox command in a reset method that is executed when plugin starts and that one displayed as expected but no other messageboxes after that.
      http://sdmitch.blogspot.com/
      • Dan RathbunD
        Dan Rathbun
        Well one rule.. don't put UI.messagebox calls inside UI.start_timer blocks.
        You can have the console open when loading the plugin, and use puts("string") statements instead of messageboxes.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          I have also found that if you have an error in the messagebox string argument... the UI.messagebox call silently fails.
          Copy the argument for the messagebox to the console and press enter.. see if you get errors.
          Second.. use puts and have the console open when loading... if there's an error in the arg.. then Ruby should spit out an Exception message.
          So rule 2: What works or doesn't for puts, will or won't for UI.messagebox
          • sdmitchS
            sdmitch
            I don't have any UI.start_timer blocks so that can't be the problem. I did copy the entire code statement "UI.messagebox("There are no valid snap points", MB_OK)" to the console and the message displayed normally. I even added a UI.inputbox statement to see if it would display and, like messagebox, the tone sounded but nothing displayed. Other than a method that does a calculation, I can't think of anything in this plugin that I have used many times before.
            • Dan RathbunD
              Dan Rathbun
              Can you call the plugin's method(s) from the console, and see if you get any errors ?
              • Dan RathbunD
                Dan Rathbun
                That's likely it then.
                I had a similar problem with a messagebox silently failing.
                The error was a math calculation error, but not an exception. In other words Ruby was happy with the result, but the answer was a different class than I expected. (I wanted a float, but was getting a rounded integer, or visa versa.)
                The algorythm was my path_knife() method, for displaying long absolute path strings in a messagebox.
                See this post for the method: [code] Split a long pathstring ~in half at the nearest '/'
                Anyway whenever there's an error, the messagebox would not display.
                Did you know that you that you can use rescue as a modifier ? (Good to use, when wrapping the whole block in a begin .. rescue .. end block is overkill.)
                var = 2 1.0/var
                0.5
                var = nil 1.0/var
                Error: #<TypeError: (eval):414:in `/': nil can't be coerced into Float>
                var = nil 1.0/var rescue 0.5
                0.5
                • sdmitchS
                  sdmitch
                  Dan, It turned out to be an unneeded View.invalidate statement.
                  Once it was removed, all was OK.
                  • JuantxoJ
                    Juantxo
                    Something similar occurs if you close dialog in a callback:
                    my_dialog.add_action_callback("test") do |web_dialog,param|
                    	web_dialog.close
                    	UI.messagebox('NOT DISPLAYED')
                    • Dan RathbunD
                      Dan Rathbun
                      On the PC, this might work:
                        web_dialog.close
                      my_dialog.set_on_close {
                      AFIAK, set_on_close is still bugged on the Mac
