    Own Dynamic Component supported function
    6 Posts 2 Posters 299 Views 2 Watching
      tictactoe
      Whith the DC function CURRENT you can access the dynamic dictionary value 'LenX' of the component:
      =CURRENT("LenX")/2
      How can I make a similar function and access the dictionary?
      class DCFunctionsV1
      protected
      def mycurrent(param_array)
      # Question:
      # WHAT CODE IS NEEDED HERE TO ACCESS THE DICTIONARY?
      • Dan RathbunD Offline
        Dan Rathbun
        You cannot do that, and still have a Dynamic Component that is version 1.
        I'm not here much anymore.
          Dan Rathbun
          The name of the dictionary is "dynamic_attributes"
          If you have to mess the Component's dictionary, do it using:
          comp.get_attribute("dynamic_attributes","keyname") and leave the **DC** classes alone. (They are scrambled for very good reasons, and should be considered a part of Sketchup.)
            tictactoe
            I found it. With
            @source_entity.get_attribute("dynamic_attributes", "somekey")
            you can access the dictionary-values.
              Dan Rathbun
              .. seems to be an echo in HERE... Here ... here ... here ... here
                tictactoe
                The
                @source_entity
                was the key. No echo!
                And get_attribute should only read values and not mess the dictionary.
