    AERO-SPACE DRAWING
    154 Posts 25 Posters 19.3k Views 25 Watching
      dolphus
      Thanks for that Ken but these are not renders but just the model with a backround when i have completed the model i will try for some realistic looking shots, for now just showing off the detail
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta1.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta12.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta13.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta14.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta16.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/delta15.jpg
      http://i458.photobucket.com/albums/qq304/dolphus_006/DP0052.jpg
      • ken28875K Offline
        ken28875
        Ok, cool. Will be looking forward to the final render then.
        Nice detail. I like that "worm" think.
        Best,
        _KN
        Follow Your Dreams.
          dolphus
          Worm thing is the Living quarters, Command Deck etc
          Here is a shot off an Airlock on the Main Pseudo Grav cog
          http://i458.photobucket.com/albums/qq304/dolphus_006/airlock.jpg
          (As seen from the "worm thing")
            dolphus
            View of the Utility Module Shuttle port
            http://i458.photobucket.com/albums/qq304/dolphus_006/auxmod.jpg
              liam887
              wow this looks good dolphus cant wait for the render, hopefully ill have some free time soon to finish my solar explorer, http://forums.sketchucation.com/download/file.php?id=53230&mode=view
              what are you going to use to render?
              VISIT MY ONLINE GALLERY
                dolphus
                Thanks Liam, but sorry to disappoint My old laptop just doesn't have the grunt to render anymore, so this is as good as it gets......more to come later
                  dolphus
                  View of "Elevator system" From Crew Quarters to Central Walkway
                  http://i458.photobucket.com/albums/qq304/dolphus_006/ELE.jpg
                    liam887
                    looks great it is very detailed, shame about the render times! You should try a range of software render trials you may get lucky and find one that runs a bit smoother on an older machine?
                      dolphus
                      My problem is with the memory of the laptop soon as it builds up a biggish file it "bombs out" something to do with a swopfile glitch, just need some know-how (not me)
                      Anyway here is a more detailed view of the elevator (at the command module end) showing the access gangway, airlock, elevator entrance ans elevator shaft (elevator driven by compressed air) re-cycled of course!
                      http://i458.photobucket.com/albums/qq304/dolphus_006/ELE2.jpg
                        dolphus
                        Can you spot the Maintenance and service pod approaching the Utilities Module Spaceport?
                        http://i458.photobucket.com/albums/qq304/dolphus_006/utl.jpg
                          dolphus
                          Utility Pod during a routine inspection
                          http://i458.photobucket.com/albums/qq304/dolphus_006/utl5.jpg
                          • ken28875K Offline
                            ken28875
                            You've been quite busy, Dolph. Cool stuff.
                            Keep it up.
                            _KN
                            Follow Your Dreams.
                              Ben Ritter
                              Dolphus, everything looks great. On your first model, the airplane, along the lines of Eric's comments to remove the black line around the lettering, did you also eventually remove the black lines between the different paint colors?
                                dolphus
                                Thanks for the comment Ken and Ben ...Ben i remove the black line where it has the best effect mostly around lettering etc..hope this helps
                                  dolphus
                                  http://i458.photobucket.com/albums/qq304/dolphus_006/ringship.jpg
                                  Star-ship R-108 Undergoing "Warp Drive" trials
                                    dolphus
                                    Who wants to stick his/her neck out and identify the subject of my latest project
                                    http://i458.photobucket.com/albums/qq304/dolphus_006/F28fuz.png
                                    http://i458.photobucket.com/albums/qq304/dolphus_006/F28fuz1.png
                                    • numbthumbN Offline
                                      numbthumb
                                      Fokker F28?
                                      Comfortably numb...
                                        dolphus
                                        numbthum......????..man you are goooooood ๐Ÿ‘
                                          numbthumb
                                          Not that good, dolphus...itยดs in the image title once again ๐Ÿ˜„
                                          Comfortably numb...
                                            dolphus
                                            Aha...I'll get you next time!!!!! ๐Ÿ˜ฎ
                                            • 7 / 8
