    Atmospheric drag
    5 Posts 4 Posters 1.3k Views 4 Watching
    • E Offline
      Elukka
      Is there any way to get empty, Newtonian space in SketchyPhysics? Gravity is easily set to zero but how about the atmosphere? Moving objects stop on their own which implies there's an atmosphere and I can't find any way to turn it off.
        mptak
        The answer seems to lie in this command
        setLinearDamping(0.0) and setAngularDamping(0.0)each of which are set in the script box. Hope this helps.
          CPhillips
          It should be:
          onstart{
            setAngularDamping([0.0,0.0,0.0])
            CPhillips
            Numbers larger than 100.0 will work. Experiment to find out what values work for whatever you are trying to do.
            • W Offline
              Wacov
              I'd use those commands in the onstart event. I reckon this code should achieve what you're after:
              onstart{
              Edited, didn't try it originally 😳
