    Sketchy Physics Code Sections not showing
    4 Posts 2 Posters 1.3k Views 2 Watching
      jblively
      Hello,
      I installed sketchup 8 (i've been using sketchy physics fine with sketchup 7) and then installed sketchyphysics via the exe install. I made sure it installed into the correct sketchup8 directory but now the ontick and ontouch boxes in the UI don't appear.
      I've tried reinstalling? Any tips?
      Joe
        camokid11
        can you please tell me which folder you placed the sketchyphysics into?
        what i did was copy all of the files in the plugin folder from sketchu 7 into the plugin folder of sketchup 8. that seems to work fine. you could use that as a last resort.
        If you can read this, thank a teacher.
        If you can read this in english, thank a soldier.
          camokid11
          also, try make a box first and try the UI on that first. it might work.
          try that before reinstalling anything, or trying my previous advice.
          A small test
          a small test to see if ontick does work, just put this script into the ontick field
          if key('space')==1;UI.messagebox("This script works!");end
          start the simulation and press space and a message should come up.
            jblively
            A small test
            Found out what it was. It was teh EXE install of sketchyPhysics I was having troubles with. I did the zip file and it worked perfectly. Sorry for the late update, but if anyone else has the issue, I wanted to make sure they find a resolution.
            Oh, and YES, the code you posted above does work. So, it's not that the code wasn't running, I just couldn't get access to it with the EXE install I was used via the UI panel. Weird, but it's working, and that's all I need πŸ˜‰
            Joe
