    Alienware - Area 51 - Graphics Cards ?
    7 Posts 4 Posters 1.0k Views 4 Watching
      rdcast
      I've tried to study what graphics cards are best for both SketchUp and gaming. Is it true that high-end gaming cards are more suitable for SketchUp, than workstation cards are for gaming?
      I'm looking at 💚 Alienware - Area 51 to do both, gaming and SketchUp projects.
      http://www.dell.com/us/en/home/desktops/alienware-area-51/pd.aspx?refid=alienware-area-51&s=dhs&cs=19&~ck=mn
      For graphics card, I'd like to upgrade it to either a Dual 1GB GDDR5 ATI Radeon™ HD 5870 CrossfireX, or Dual 1.5GB GDDR5 NVIDIA® GeForce® GTX 480 - SLI
      Any advice or recommendations?? Please keep in mind that I intend to move up to SketchUp Pro with Podium..
      Thank you 💚
      • PixeroP Offline
        Pixero
        I would go with a Nvidia card since my experience is that ATI cards have more driver issues.
        Plus Nvidia has CUDA which can be used for "realtime" rendering like the one soon coming with Thea render.
          rdcast
          Thanks for expressing your experience!
          Would you think a low-end workstation configuration might have more of a problem with gaming, than a high-end gaming computer would have with 3D drawing/rendering(both costing $2500)? In other words, spending $2500 on either a gaming or workstation, optimized at that price, then testing both on games and 3D drawing/rendering, then averaging those performances together for each separately, might you assume the gaming platform to reach a higher accumulative score??? That is, given equal expense, one being a high-end gaming computer, while the other a low-end workstation, at $2500.
          • N Offline
            notareal
            Looks like that Thea will use OpenCL, so it will not be limited to nVidia.
              dsarchs
              nvidia scales much better than ATI, so if you're thinking about multiple cards, definitely dual 480's in SLI. Having said that, they run very hot, noisy and draw a huge amount of power, so make sure you have a hefty (probably 1200 watt) PSU and a water cooling system.
              Knowledge is a polite word for dead but not buried imagination.
              -e.e.cummings
                rdcast
                Area 51 does come with a liquid cooler for the cpu, and a 1,000 watt power supply, upgradable to 1,100.
                Your recommendations are very much appreciated.
                • PixeroP Offline
                  Pixero
                  Here is a Graphics card test from cgarchitect:
                  http://www.cgarchitect.com/news/Reviews/Review076_1.asp
