    Sketchy Physics Problem
    4 Posts 3 Posters 1.5k Views 3 Watching
      Pacbot
      My problem is when ever i want to play physics simulation the SketchyPhysics control panel appeares only blue and in the top left it says I need SketchyPhysics3 RC1 but I installed it right and I have all the Icons and everything is in the plugin folder.
      What can the problem be please help me.
      http://www.mypicx.com/uploadimg/1824004810_06212010_1.jpg
      πŸ˜„
      • H Offline
        hpnisse
        Do the motors have controlleble functions.
        When you open the UI and select a jonit (motor), it should be in the controller field: slider('NAME'). (left picture)
        !AND the joint need too be connected to something to show the slider.!
        Then there will pop-up a "slider" in the blue controllpanel when you start simulation. (right picture)
        /hpnisse
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          Pacbot
          Thanks but I found out what was the problem. It was I didn't make hold the ctrl to group them.
          but sadly I have another problem and its when I place more than one object to move everything shuts down and it shows this
          http://www.mypicx.com/uploadimg/320294756_06232010_1.jpg
          • W Offline
            Wacov
            If you use the forum's upload feature to upload the model it'd be easier to tell if the problem is just for you, or is something to do with the model itself πŸ˜‰
