πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Old KT Renders
11 Posts 6 Posters 936 Views
    david57
    Kt Renders.
      majid
      i like 2,3 and last one πŸ‘
        D-space
        The KT trees looks pretty awesome, any tips on how it was post-pro ? πŸ˜„
        http://blibestmentalt.no/54981
          david57
          Thanks Majid.
          D-space,
          What is Post-pro?
          I have problems understanding some of the words used here.
          The big trees are 3d trees made with ngPlant.
          Some of the smaller ones are blenders from:
          http://blender-archi.tuxfamily.org/Greenhouse
          and the other one's from the Google warehouse.
            markpyvi
            @david57 said:
            Thanks Majid.
            Hi david57!
            Can You tell if you imported plants made in ngPlant into blender or SU (using TIGs OBJ importer)?
            Have You ever managed to import "ng Plant" into SU? I have no luck with TIGs plugin, keeps me saying "No Geometry was made!" Have no idea how to get ng plants into SU. Maybe You do?
            Thanks,
            mark
              D-space
              @david57 said:
              Thanks Majid.
              D-space,
              What is Post-pro?
              Guess you solve my confusion. I thought your KT renders looks much like Blender so post-pro comes to my mind.
              Btw..post-pro is photoshop adjusments. πŸ˜‰
                majid
                @ david:post-pro = post processing, usually doing some changes using an image editor application like photoshp (PS).
                I guess you have imported the ng-plants directely into KT, and not into su . am I right?
                would you plz share your ng-plant settings here?
                  david57
                  Majid,
                  Some were imported directly in to KT and the ones from Google were exported
                  with SketchUp.
                  I have Encyclopedias of tree settings. πŸ˜„
                  Maybe if you send me a site were i can send my most recent big tree.
                    michaliszissiou
                    "Can You tell if you imported plants made in ngPlant into blender or SU (using TIGs OBJ importer)?"
                    Obj importers in SU are tooo slooow and full of problems.
                    Its easy to export 3ds from blender to SU. This works fine.
                    Just have in mind that the names of textures MUST have names less than 8 letters, in blender/texture editor use save as to rename files. Linked texture files MUST be in the same directory with the .3ds. This - and only this- works here!
                    Blender is a fine converter from .obj to 3ds actually.
                    Very nice renders david57! I always like your trees. Especially the big ones.
                      david57
                      Michalis,
                      The files are exported as obj files from ngPlant and imported into
                      blender as an obj file.
                      Here's the link to the tree file:
                      http://forums.sketchucation.com/viewtopic.php?f=40&t=28108
                        lapx
                        Has someone translated these trees to skp files. The images files can be made as skp components used interchangably on a tree or used in kerky as an instance. This would be nice.
