[Bug][SP3Jun27a] UI doesn't work after a few tries
If you turn an object into a thruster or emitter, and then open the UI a few times, eventually it will just stop working and this is really annoying, and interrupts a perfectly good SP model
I've found that if you close Sketchup and re-open it, the problem goes away. Also, if you just keep the UI minimized instead of closing it, that helps.
