    The A show (post your Thea images)
    152 Posts 41 Posters 39.8k Views 41 Watching
    • N
      notareal
      @xrok1 said:
      @earthmover said:
      Is there a Thea material repository or any plans for one in the future? (drooling over Pete's textures)
      do kerky materials work? they have a collection over there.
      Thea Render does a automatic material conversion for KT scenes. KT materials cannot be directly used in Thea Render because different engine and material systems.
      • majidM
        majid
        @gistman said:
        Majid- Really nice work. How do you feel about the ease of learning Thea now that you've seen it Kerky and Twilight?
        in my sight it is now "integrated and clear" each thing has it's own place and after a while of playing you'd be familliar with it.while Kt 2008 was toooooo clear and easy to use comparing to previous version, BTW making right materials needs using "layering system" that is really confusing for a beginner, so then twilight has made it easy tto make the materials, placing lights... and also I like it bkz it's working inside the SU and so no need to have "export-merge" process as it is needed in such render engines as Thea , maxwell, kt... etc. now , "scene", "workspace","settings" are the main panels that each one "says" you what is it doing". then at each sub-panel you'll find related questions. also I was hoping to have some minor change (such as an optoion to see a larger version of material ball , as there is such option in Fry render, and not only ability to see the textures larger).
        I am also noob at Thea, and so there are times that my changes in settings (I mean biased) causes undesired results. BTW I like the "clearness" and ease of Thea.
        here are just some playing,(after wisiting a furniture exhibition) models are raw (Su+wings3D to subdvide). the balls about toke 6-7 min!!! (biased) but the tray scene about one hour to be cooked!!! and less noise (unbiased). I used unbiased bks was not sure about lighting and was interested to make some good caustics, so used the relight system after rendering to have it "clearly" (while I guess now I culd use the same settings in biased way πŸ˜’ )
        also maybe we must be patient about the Thea , as it is a beta, and in it's starting steps πŸ˜„
        • N
          nomeradona
          after using vray.. i am hesistant to try Twiglight nor Kerky.. but man after seeing your render. i think i will try thea..... excellent render pete. your play with materials is excellent.
          • EarthMoverE
            EarthMover
            Can someone point me to a good "Relight" tutorial for Thea? Can't seem to find one on the Thea site.
            Content Creator at Skapeup
            • FrederikF
              Frederik
              Hi Adam,
              I don't think there's a public relight tutorial, only an internal video, which needs to get updated... 😳
              I've never used the relight option myself, but I know that Pete master it... πŸ˜„
              Here's what he wrote some time ago...
              Save the scene .scn.thea and then save the image as .img.thea
              Now you can either continue the render or just load the completed image for relight adjusting and saving etc by reloading them.
              Please also see page 26 in the "Manual.pdf", which can be found in the directory, where Thea is installed...
              (I.e. C:\Program Files\Thea Render\Manual.pdf)
              Cheers
              Kim Frederik
              • soloS
                Adam
                Do you have a scene you want to use relight with?
                Please feel free to ask any questions and I will try help where I can.
                If I get some time I will compile a simple scene and set up for relight then make it available as either a test scene or tutorial (time being the decider)
                Alternatively if you have Skype then I could walk you through a basic setup.
                • daleD
                  dale
                  Would it be possible to video the Skype session?
                  • X
                    xrok1
                    i think the best part of relight is that you can play while the render is happening. its freakin awesome! pretty well worth the price of admission for that alone. πŸ˜„
                    • arail1A
                      arail1
                      Okay, I'll stick my neck out and possibly look like a fool - could someone explain what relighting is? I read the manual but I don't quite get it - and I've had my third cup of coffee already so I can't blame my incomprehension on lack of caffeine.
                      Thanks.
                      • X
                        xrok1
                        check solo's video on the first page of this thread and drool. in short its the ability to adjust individual lights in the scene after or during render! 😲 in a lifetime it could save years of rendering;re-rendering;re-rendering...
                          remus
                          Its basically a feature that allows you to control the intensity of light sources in the scene after youve finished rendering. As an example, imagine you have a room lit from a window and 2 intreior lights, using relight you could do one daytime image with the scene lit entirely from the window and then a night image lit entirely by the interior lighting, and you get all that from a single render.
                          • N
                            notareal
                            There is a small relight example scene in Thea Render installation dir ".\Thea Render\Scenes\RelightExample". At Scenes dir you will find some other sample scenes in Thea format (note. there is a outdated glass-liquid interfacing scene too, don't bother with it, but get this scene by harford).
                            • arail1A
                              arail1
                              Got it! Thanks.
                              Now we need a good tutorial ...
                              • EarthMoverE
                                EarthMover
                                Thanks everyone. Looking forward a rundown on how to setup for Relight. β˜€ Pete, I sent you a link (PM) to download my scene if you get a chance. If not, no big deal.
                                • RichardR
                                  Richard
                                  I've been using Maxwell's Multilight feature for years which is obviously very similar to the Thea Relight system and even use it for exteriors where no emitters are in scene, I just create an emitter and place it beyond the scene where it will have no effect, you can though still set it's power to nil or disable once processing (to enable ML one needs an emitter other than just the sun). This allows me to play with both camera and sun power to get the best lighting / shadows results!
                                  SO I'd suggest this may be something worth testing even for the most simple exterior scenes, and trust you will likely never render again without this feature enabled!
                                  BUILTBRAND.COM.AU
                                  • X
                                    xrok1
                                    @arail1 said:
                                    Got it! Thanks.
                                    its pretty simple, turn it on in render settings and you get a slider and a color picker for each light. play away!
                                    (might not actually be that simple but it was for me ;~) )
                                    • 8 / 8
