    Slope house Vue render
    7 Posts 5 Posters 440 Views 5 Watching
    • pugz1983P Offline
      pugz1983
      Hi Everybody,
      My latest model and render. Model made in SU 7 Pro and rendered in Vue 8. A lil PP because the leaves of the yellow bush were visible through the wall 😮 . Love some feedback on this one. I changed the vegetation 5 times because I wasn't happy with the result. This is the first one I Think is worth showing. I would love some feedback on the model and render. I'm still figuring out the AA options in Vue, because of the noise in the pic. But I think it's also caused by the wooden blinds and the volumetric lighting of the spots in the scene. After Finishing this one , It time to play with Thea Render tonight.
      Greetz Twan
      • DanielD Offline
        Daniel
        If it weren't for the moire effect on the building, I'd say it looks great. What rendering settings are you using?
        My avatar is an anachronism.
        • pugz1983P Offline
          pugz1983
          thanx for the reply. I've used Volumetric lighting and Global Radiosity. I used the superior render preset. Could you please explain Moire effect.
          Greetz
          • soloS Offline
            http://en.wikipedia.org/wiki/Moir%C3%A9_pattern
            • pugz1983P Offline
              pugz1983
              Thanxs pete, excuse my laziness. I could have googled it myself 😳
              Is there a way to get rid of this Moire effect. I/m ging to have this problem a lot because I love to work with blinds and grids in my models. It's kinda my style of modeling. Does it help to crank up the AA? or maybe change the perspective of hte view?
              • olisheaO Offline
                olishea
                increase the render resolution and scale down after if you need to...if increasing AA doesn't help.
                oli
                  Roger
                  Very nice render. Other than the moire, I would darken the sky a touch to separate it from the vertical wall. I suspect this probably looks better than your original but the contrast is dumbed down by viewing in the web.
                  Also I would move the red tree on the left. There is an unhappy coincidence with the bridge. It looks planted on the bridge. Cloning just a touch of trunk under the bridge would fix this.
                  Lastly just add a little bit of entourage in the foreground to increase the illusion of depth.
                  But mainly it is a beautiful image.
                  http://www.azcreative.com
