    Street Project in London
    23 Posts 20 Posters 4.9k Views 20 Watching
      choppir
      wohww! Thanks for the replies guys!
      Ok,
      Artysmedia: Not sure, i have to look when my machine stopped rendering, but it is alot. I had to use proxies for all planting as this scene crashes instantly without it.... Rendered on a 8core machine,8 gig ram which was nessesary!
      Not sure what you mean by your 2nd question?
      D-space & spdesign: I chose the workflow of SU to C4D above max because it is so easy.
      I learned max and I was quite frustrated when I saw the different workflow between the 2....Max is waaaayy to complicated. So here you can also see what is the best way to export your model to Cinema 4D: http://www.vrayforc4d.com/forum/showthread.php?t=5426&highlight=export+sketchup+model
      Dale: I modelled all the different buildings on their own separate file, then the street with all the bits & pieces on ones file, then on the big file, I've imported all the models together....
      I definitely used components.
      What is very very important is to work on different layers, because it makes the exporting part easy and also good to work with.... I always layer my stuff in the correct layers so that my workflow is ultimately faster. Neglecting layering it, makes it hardly unbearable. I did ask somebody once to help me model, but because he did not really use layers I had to re-model everything.
      I also group objects alot. That makes the texturing bit very easy.
      So i don't have any plants in Sketch-up, but i use proxies in Cinema 4D.
      hope this helps!
      Feel free to ask, I'll be happy to help.
      Cheers
      choppir ๐Ÿ˜„
      • FrederikF Offline
        Frederik
        Awesome...! Awesome...!
        http://www.kerkythea.net/users/Frederik/Anim-Icons/praise.gif
        Cheers
        Kim Frederik
          jopsa2
          this is amazing!! shows the huge potential in sketchup, how many edges did you end up with?
          also I notice in the clays that you modelled the lines on the street, I imagine it's so you only had one asphalt texture? very clever!
            choppir
            Hi Jopsa2: I just looked and without the plants it comes to 3995564 poligons......yeah so almost 4 million.
            The lines was modelled separately and yes the tarmac is one big texture i painted in Photoshop.
            Hope this helps.
            Choppir
              steelers05
              these are great. Its nice to see someone using SU along with another program other than max. good work
                tomislavm
                Looks great, thank You!
                  kevsterman
                  ๐Ÿ˜ฎ Absolutely amazing! If it wasn't for the clay models I would swear it they were photos. Amazing work!
                  What was the reason for modelling this street? Is it an existing street or is it all made up?
                  "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                    choppir
                    Thanks kevsterman ๐Ÿ˜„
                    It is existing, but the whole street will be refurbished ๐Ÿ˜„
                    Here are some existing pictures. You will see they have already started building the School in the background of the 1st pic....
                    Laters!
                    choppir
                      kostas_designer
                      Really professional stuff ๐Ÿ‘
                      Excellent work, mate!
                        Mamer
                        Nice work!
                        I'm a novice trying to render my street. How did you get the scale nailed down? Did you have access to planning documents or did you just use the ruler in Google Earth to approximate everything?
                          choppir
                          @mamer said:
                          Nice work!
                          Hi Mamer,
                          What i did is, got some CAD plans from planning, then worked from that ๐Ÿ˜„
                          choppir
                          • 2 / 2
