    What is it?
    70 Posts 23 Posters 10.4k Views 23 Watching
      pmiller
      A scupper?
        Roger
        Not a scupper but related to a well known skipper. It is the bane of a man with one eye and one arm overlooking a square that is really a circle. There, I think I have given it away. Almost like transmitting in plain text.
        http://www.azcreative.com
          dolphus
          3d Model of Nelson's coat of arms ......
          • ely862meE Offline
            ely862me
            door eye hole ?
            Elisei (sketchupper)
            Come and See EliseiDesign
            • daleD Offline
              dale
              A fountain?
              • chrisglasierC Offline
                chrisglasier
                Roger Hawkins works from his base in Phoenix,Arizona, and accepts challenging design, photo and writing assignments from discriminating clients.
                ...and answers from wimps like us.
                btw: Trafalgar Square is not circular.
                  john.warburton
                  Telescope support...?
                  Life's a reach, and then you gybe.
                  • EarthMoverE Offline
                    EarthMover
                    Grate cover for a heating vent?
                    Content Creator at Skapeup
                      john.warburton
                      Musket firing port
                      • DanielD Offline
                        Daniel
                        Have something to do with Nelson's statue/column in Trafalger square?
                        My avatar is an anachronism.
                        • soloS Offline
                          It's clearly a Sketchup model. that was too easy. πŸ’š
                          • W Offline
                            watkins
                            Well, that would be Horatio. Is it the scroll work at the top of the column, or decorative work on a ship? However, the bane of Horatio would be pigeons.
                            Regards,
                            Bob
                              Roger
                              My dear Watkins. I apologize for transposing the statue of King Charles the 1st with the all but invisible Horatio Nelson. But be that as it may, the bane of Nelson's statue are the pigeons, but the bane of Nelson himself was more feline than avian. Still matey methinks you are hot on the trail.
                                Roger
                                Meanwhile I struggle with the dolphins. Hint. This is another clue meant to both inform you and throw you off at the same time.
                                  john.warburton
                                  Well, feline - there are the lions around the base of the column;
                                  ...and dolphins - many in the fountains there.
                                    john.warburton
                                    ...surely it is not a vent for the loo's...
                                    ...or an overflow outlet for the water features...
                                      Roger
                                      Lions no, but bronze tigers I will give you and dolphins too. Arty bronze she be. Near the water but has never has sailed the sea.
                                        Roger
                                        The clues get stronger, let hope the answers don't get wronger.
                                        Maybe this will put you inTOUCH with the answer.
                                        I thought this would be an easy model, but there was more detail than I imagined.
                                          d12dozr
                                          Touch hole for a cannon!!
                                          http://goo.gl/f7ooYh
                                            Roger
                                            Good work. Yes, it is a touch hole for a cannon, but which cannon? This one actually has a unique name other than its classification as an artillery piece. And if you figure that out you should be able to give a location and describe the damage it did.
                                            • 2 / 4
