    How to properly create a LONG chain/rope?
    4 Posts 2 Posters 2.5k Views 2 Watching
      AcesHigh
      I want to drop a Sketchyphysics chain/rope, made of several components, over a complex object.
      But do I have to link each one of the possibly hundreds of chain segments to ball joints or is it possible to automate the process, so I can simply copy and paste the segments?
      • H Offline
        hpnisse
        Yes, there is a way to create a chain/rope (if you have SP3 with script field).
        in the model I have here there is two example, one with ball thats linked to each other direct, and one with a cylinder between each ball.
        [attachment=0:122zsqmx]<!-- ia0 -->ROPE.skp<!-- ia0 -->[/attachment:122zsqmx]
        The long ROPE:
        > ontouch{|t,s,p|
        >    connect(t,"ball") if frame==0
        -- This script is only connected everything it touch when you press play.
        The short ROPE.
        > ontouch{|toucher,s,p|
        >    if frame==0 #only at start
        >       case toucher.name
        >          when "Rope"
        >             connect(toucher,"ball")
        >       end
        >    else #after first frame
        >       ontouch{} #turn off ontouch event.
        >    end
        -- This script connect everything that have the name "Rope" when the Play button is pressed.
        hope this help...
        /hpnisse
        ` /hpnisse`
        ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
          AcesHigh
          I was expecting some way to do it without having to resort to scripting. Cause sincerely, that looks like greek to me 😄
          • H Offline
            hpnisse
            Okey 😐
            Perhaps the file that never show upp in the answer before understand what I mean?
            ROPE.skp
            That you see its not so hard, and Iam not good at neither scripting or english:P.
            This is better than having physics joints in every link that take a lot of the computer:P
            ` /hpnisse`
