    Path following AI
    11 Posts 3 Posters 1.5k Views 3 Watching
    • W
      Wacov
      In sketchyphysics πŸ˜„
      Just thought I'd make anyone who hasn't recently graced the WH aware of this. I've developed a system that lets cars (or boats) drive themselves around a course. It supports multiple routes, and multiple vehicles very easily, and there's a detailed tutorial for installing it on models. I'll be building on top of this basic system to allow more complex behaviours, and the tutorial and up-to-date info can be found at:
      http://sketchupusers.freeforums.org/easy-ai-now-with-tutorial-t73-10.html#p945
      • E
        Ecuadorian
        Thank you, I render videos from time to time so it'll be totally worth to learn how to do this. πŸ‘
        -Miguel Lescano
          Davidfi1
          Very nice - Cool
          Could be nice to have a tool bar for more easy use.
          The "nodes" could be in flag shape, and outomatically named ect...
          ( set to "ignore" )
          Thank you
          David.
          Node flag
          • W
            Wacov
            Toolbar... ok, here you go:
            AI Tools.zip
            Same deal as normal plugins, unzip in your plugins folder. To register a vehicle as AI, select all parts, including hidden parts, and use the 'Set AI' tool. To auto-number your nodes, create them in order (that's important), select them all, and use the 'Number route' tool. It removes existing numbers in the name, so you can re-use the tool, after adding extra nodes, for example.
              Davidfi1
              WOW !!! - It is beautiful - incredible model !!!
              Still need more instruction on how to use the Toolsbar for all the tasks.
              I am missing the tool for inserting the script to the "floor" and seting the motors control.
              P.S.
              I don't understand the name AI - what does it stend for?
              Nice job !
              Thank you.
              • W
                Wacov
                AI... Artificial intelligence. Just the sweeping term for computer-controlled opponents, the main intention of the system. With the floor, you need SP3 X Apr2 or above, and the 'ontick' field will be visible under properties in the UI, with an object selected. Just copy/paste the main code from the tutorial into there. I found out how SP stores the ontick scripts though, so I could automate that as well. Setting the motor controllers, again, in the UI, paste the command into the motor's controller field.
                And you're welcome πŸ˜„
                  Davidfi1
                  Hi Wacov
                  I think I did every thing correctly
                  Could you check why the Red car does not move correctly?
                  Thank you.
                  david.
                  RedCar
                  • W
                    Wacov
                    Looks like you didn't register all parts of the car... select everything, every part of it, including wheels, steering assembly, everything with an AI-controlled joint inside, and use the AI registration tool. After that the axes of the car are wrong, but that's easily fixed, and covered in the tutorial.
                      Davidfi1
                      Didn't work
                      Could you post a working demo done with the tut?
                      same model a little bit cleaner
                      Thanx.
                      • W
                        Wacov
                        You presumably exploded and re-grouped the main body, so its ontick field is empty πŸ˜„
                        Here's a couple of example models, they both use slightly outdated code though:
                        http://sketchup.google.com/3dwarehouse/details?mid=63cfe4da6cd759a3d36844afc91c4691
                        http://sketchup.google.com/3dwarehouse/details?mid=5cba40fd49a9606c6cd8ad826e9017b8
                          Davidfi1
                          Wacov
                          I took your model and replaced the parts inside with the ones in my model.
                          The only problem now is to make my Track "Obey the traffic laws" πŸ˜„
                          Well - I would like it to stay in the correct lane....
                          The problem is I do not understand what is going on.
                          It would be grate if you could explain what I should do
                          AI Red Track
                          P.S it takes about 15 seconds to start after I press run - Is it normal?
                          Thank you.
                          David.
