    Render this: SSS
    174 Posts 44 Posters 27.9k Views 44 Watching
    • EscapeArtistE Offline
      EscapeArtist
      @dale said:
      Tried an experiment. Copied the dragon, pasted it in place, scaled one copy down by 10%, placed it inside the other dragon to give it a real subsurface, assigned the outer skin a transparent material, and the inner a green translucent material. Didn't turn out like I expected, but was fun.
      The mint jello dragon
      Hmm, if the IoR is the same it may have negated the effect. Perhaps applying a mild fresnel effect to the outer layer?
      • david_hD Offline
        david_h
        woulda sounded better if you called it sour apple or something 😄
        Looks more like Lime Green Life-Saver.
        • olisheaO Offline
          olishea
          great renders guys. man this is getting technical!
          how about some sub surface scat?! im sure a good old dump has some sss haha, so come on guys lets polish a turd 😄
          oli
          • E Offline
            Ecuadorian
            @woodtick said:
            I had to give it a try with this little guy.Twilight #9....let it render while I was at work yesterday for about 12 hrs.
            Rich
            http://www.forums.sketchucation.com/download/file.php?id=37074&t=1
            Woodtick, this looks very interesting. Could you share how you did it?
            -Miguel Lescano
            • arail1A Offline
              arail1
              modo with drag and drop presets
              • soloS Offline
                Playing again.
                • W Offline
                  woodtick
                  Ecuadorian,
                  Well, since I'm really new to this I'm just trying different ideas to see what happens. Nothing scientific to my approach, but I'll share as best I can.bowl,dome.JPG
                  Dragon sits in the bowl: high reflective template
                  Dome goes on top for the render:diamond glass
                  spotlights as shown
                  Two small red omnis, nose& throat
                  skinny spotlight on tongue
                  tiny orange omni eye
                  started with rubber ball material and tweaked :material.JPG
                  SU fog on
                  TW preset #9
                  That covers most of it I think.
                  Lots of great images here folks......keep 'em coming.
                  Rich
                    richcat
                    Pete that's not the Lockness monster is it 😮
                    • daleD Offline
                      dale
                      [/quote] escapeartist wrote: Hmm, if the IoR is the same it may have negated the effect. Perhaps applying a mild fresnel effect to the outer layer?[/quote]
                      I haven't had much time to play lately, but when I do I'll give this a try. Thanks
                      • E Offline
                        edmund
                        playing
                        http://www.hyndman-hyndman.com/Ryan/dragons2.jpg
                        • soloS Offline
                          Edmund, those look fantastic, what render app?
                          • E Offline
                            edmund
                            twilight
                            preset 9
                            let it run overnight
                            Thanks Solo.
                            • boofredlayB Offline
                              boofredlay
                              That is excellent. I've not been able to get that kind of result from Twilight. Will have to have another go at it. Do you mind showing your lighting setup?
                              Does the orange dragon have an eyepatch?
                              • E Offline
                                edmund
                                of course
                                http://www.hyndman-hyndman.com/Ryan/dragon setup.jpg
                                http://www.hyndman-hyndman.com/Ryan/omni setup.jpg
                                It was an accident that my light bulb size(radius) was at 50.8 😲
                                I also used a HDR lighting for the sky probe. Oli posted the link to said hdr images a little while ago.
                                Thanks Oli.
                                and you did spot my eyepatch... haha
                                • daleD Offline
                                  dale
                                  edmund, you nailed it 👍
                                    Chris_at_Twilight
                                    50.8 is millimeter equivalent of 2 inches, the default light size. 😄
                                    http://www.TwilightRender.com
                                    • E Offline
                                      edmund
                                      thank god. I was looking at it like "really?" thats what I made the light bulb size.
                                      thanks for clarification
                                      Thanks Dale
                                      • E Offline
                                        Ecuadorian
                                        Those looked really good, Edmund. 👍
                                        Now, they say imitation is the most sincere form of flattery, so I hope Remus doesn't mind my try to achieve a similar look to his blue rubber dragon:
                                        -Miguel Lescano
                                          pav_3j
                                          ok, been putting it of, but here is my V-ray attempt.
                                          i used a preset as a guide and made this material, not sure what it is!
                                          its has some mega harsh shadows which i have no idea how to get rid of as i am still learing V-ray.
                                          Rendered in less than 40s which i was mega impressed by!
                                          pav
                                          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                            boofredlay
                                            Wazzaaaah...
                                            • 4 / 9
