    Indoor work
    5 Posts 3 Posters 399 Views 3 Watching
    • N Offline
      nickenzyme
      One model in a competition held online in SU Rendering of China.
      Using Podium to manage it.
      A little dark, I still have no idea how to change it...
      I think it is of great joy to render works, so make a small scene in it~~~
      Feedback Welcome
      Life is not about waiting for the storms to pass... It's about learning how to dance in the rain!
        sepo
        You need more light in your scene or you postprocess the render.
        I did 2min pp.
        • I Offline
          imabzeous
          **@sepo
          plz can you share how u brighten up the scene using pp**
            sepo
            If you have Photoshop you either use curves or use levels. In this image I used levels although using curves is much better and more desirable. I also copied original layer and did highpass and blended it (normal blend) with base layer (around 30% transparency). You need to make sure you do it in stages and save. If you are confidend merge the layers and carry on. It is very important not to overblow the image. Sometimes you need to add a touch of noise. However in this case I did not need to add any as the basic image is good, allbeit dark. I must stress that I do not have one and only one set of things that I do in Photoshop,otherwise I would have created action. It all depends on the image at hand....I hope this helps.
            • I Offline
              imabzeous
              thx sepo it really helps
