    Unfold.rb script: useful for UV-mapping?
    61 Posts 23 Posters 16.7k Views 23 Watching
      Hi Rombout,
      See this post in the other topic you posted the same problem.
      • RichardR Offline
        Richard
        Bump, bump bump!!
        BUILTBRAND.COM.AU
          Jim
          I added preliminary support for refolding to my unfold tool.
          Maybe someone would like to try it?
          Download tip.zip from bitcucket.
          You can undo and redo the refold, but activating the Tool wipes out the history.
          I am not going to ty tyo make it work inside Groups or Components this day. Just works on loose geometry at the moment.
          • X Offline
            xrok1
            • RichardR Offline
              Richard
              Wow thanks jim! I'll take it for a run!
              I guess the simplest (considering your earlier point about not understanding UV mapping), would be that possibly a temp file be created that records the unfold steps and recalls them in reverse after the user has painted a map to the unfolded geometry!
              Cheers mate! Richard
              BUILTBRAND.COM.AU
                Jim
                Yeah, that's about it - it's all in-memory but a temp file is an option. It could become quite complex if I need to allow for interrupted unfolding (if that makes sense.)
                As I said, you will probably only get one go at it because re-activating the Unfold tool wipes out the history.
                Let me know how it goes.
                • RichardR Offline
                  Richard
                  Jim mate well done!!!!!
                  I just made a hex base and followed up a few bent lines > unfolded > mapped the surface > refold and bang all done with mapping perfect!!!!! Wow!
                  The big issue obviously is that complex models would need to be naved during the unfold and this seems to break the actual unfold itself.
                  Though at this point it will already make many mapping issues easy to complete!
                  Thank you thank you thank you!
                  BTW have never done this - hold does one install the button image?
                  BUILTBRAND.COM.AU
                    Jim
                    You know, this might be much easier. Instead of keeping a history of each step, it should be possible to go through and save the positions of each face one-time at the start. Then you can unfold however you like, in as many ways as you like; and the refold operation can go through and put things back where they were originally. Maybe. I think.
                    • RichardR Offline
                      Richard
                      Hmmm?
                      I've been playing some more and yeah its hard to get a well developed map without the option of breaking the unfold operation to view and understand the unwrap as one is doing it.
                      The form I've been playing with is a little like a tree trunk, the problem is one would want a unwrap out from one continuous common run of face with each unwrap around the trunk out from the common.
                      Dam good work though Jim!
                      BUILTBRAND.COM.AU
                        Jim
                        As a temporary work-around, added a prompt:
                        This will allow you to leave the unfold tool and resume when re-activated - but moving the geometry (including using Undo) will invalidate the history and the re-fold will fail.
                        Download from http://bitbucket.org/jimfoltz/sketchup-unfold-tool/get/tip.zip
                        • 4 / 4
