    Why is the geometry showing in my render?
    17 Posts 7 Posters 1.2k Views 7 Watching
    • E Offline
      Ecuadorian
      Make sure it's smoothed and not in contact with other materials (keep them as groups). Still, you might have more luck asking in the forum of the render software.
      -Miguel Lescano
      • honoluludesktopH Offline
        honoluludesktop
        How did you create the glass surface? I am guessing that the answer is whether it is a high poly surface, or a low poly one built with the SU tool set? Click down on the model until you see rectangles or triangles. If you see triangles, someone else may have an answer. If rectangles, and they correspond with the render. Then that's why.
          Click Draw
          I have it up off a surface a bit so it shouldn't being touching any other material and it's grouped. It was drawn with follow me using a profile and a 90 segment circle as the path. I'm not sure what you mean by the rectangles corresponding with the render???
          Thanks,
          Jeff
          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            Click Draw
            I do see the rectangles but only when I triple click to select. So is there another way to draw this that you don't have that outcome? I apologize if I'm not quite getting your explanation but I do really appreciate the help. Thanks very much.
            Jeff
            • soloS Offline
              Try exploding model, then applying material to surfaces, then regroup.
              • X Offline
                xrok1
                looks like it was push/pulled with ctrl, i can see interior faces!
                PS, you can upload models here just like images so people don't have to play the guessing game. 😛
                  honoluludesktop
                  Well, guess I was wrong, my rectangles rendered OK.
                    Click Draw
                    Thanks for everyones input. Pete is the winner on this one. I exploded and re-colored, then re-grouped. Just rendering now. What a huge difference!!! I'll post as soon as it's done cooking.
                    Cheers,
                    Jeff
                    • X Offline
                      xrok1
                      out of curiosity would it work to just open the group; select all; texture; close, or do you have to explode it?
                        Click Draw
                        I'm not sure Rocky but that is pretty much the same thing isn't it? Editing group is what you are talking about I assume?
                        Jeff
                          honoluludesktop
                          Do you know how you got the original effect? I like it.
                            Click Draw
                            I believe it happened by grouping the object, then painting it, then rendering. It's only noticed when rendered when done in that order, which is wrong....as far as rendering goes.
                            Jeff
                              Click Draw
                              What a difference....thanks for the tips and suggestions guys.
                              Cheers,
                              Jeff
                              • stefanqS Offline
                                stefanq
                                It's a vray issue. You only need to explode the model, then regroup.
                                • arail1A Offline
                                  arail1
                                  Have to admit that the 'ribbed' look of the original has a nice quality to it. Could be a useful technique for something else.
                                    Click Draw
                                    Yes....it is kinda neat looking. Maybe I'll try to do it on purpose but with better lighting....
                                    Jeff
