    Using Visual Basic 2008 Express dialog form in Ruby.
    15 Posts 6 Posters 4.9k Views 6 Watching
    • OscarLokO
      OscarLok
      Hai toxicvoxel,
      There is a new version which is more stable in the first post. β˜€
      And don't know you can understand my english's explaination at the above. 😳
      Is this "what is going behind the scenes" means how to use it, or others? 😳
      Anywhere I do my best! πŸŽ‰
      [b:dhgwcjdo][color=#0080BF:dhgwcjdo]JAYA Design & Renovation Sdn. Bhd.[/color:dhgwcjdo][/b:dhgwcjdo] [b:dhgwcjdo][color=#00BF40:dhgwcjdo]T[/color:dhgwcjdo][color=#00BC42:dhgwcjdo]h[/color:dhgwcjdo][color=#00B843:dhgwcjdo]e[/color:dhgwcjdo] [color=#00B247:dhgwcjdo]e[/color:dhgwcjdo][color=#00AE48:dhgwcjdo]x[/color:dhgwcjdo][color=#00AB4A:dhgwcjdo]p[/color:dhgwcjdo][color=#00A84C:dhgwcjdo]e[/color:dhgwcjdo][color=#00A44D:dhgwcjdo]r[/color:dhgwcjdo][color=#00A14F:dhgwcjdo]t[/color:dhgwcjdo] [color=#009A53:dhgwcjdo]i[/color:dhgwcjdo][color=#009754:dhgwcjdo]n[/color:dhgwcjdo] [color=#009058:dhgwcjdo]c[/color:dhgwcjdo][color=#008D59:dhgwcjdo]u[/color:dhgwcjdo][color=#008A5B:dhgwcjdo]s[/color:dhgwcjdo][color=#00865D:dhgwcjdo]t[/color:dhgwcjdo][color=#00835E:dhgwcjdo]o[/color:dhgwcjdo][color=#008060:dhgwcjdo]m[/color:dhgwcjdo][color=#007C62:dhgwcjdo]i[/color:dhgwcjdo][color=#007963:dhgwcjdo]z[/color:dhgwcjdo][color=#007565:dhgwcjdo]e[/color:dhgwcjdo][color=#007267:dhgwcjdo]d[/color:dhgwcjdo] [color=#006B6A:dhgwcjdo]o[/color:dhgwcjdo][color=#00686C:dhgwcjdo]f[/color:dhgwcjdo][color=#00656D:dhgwcjdo]f[/color:dhgwcjdo][color=#00616F:dhgwcjdo]i[/color:dhgwcjdo][color=#005E71:dhgwcjdo]c[/color:dhgwcjdo][color=#005B73:dhgwcjdo]e[/color:dhgwcjdo] [color=#005476:dhgwcjdo]s[/color:dhgwcjdo][color=#005178:dhgwcjdo]y[/color:dhgwcjdo][color=#004D79:dhgwcjdo]s[/color:dhgwcjdo][color=#004A7B:dhgwcjdo]t[/color:dhgwcjdo][color=#00477D:dhgwcjdo]e[/color:dhgwcjdo][color=#00437E:dhgwcjdo]m[/color:dhgwcjdo][color=#004080:dhgwcjdo].[/color:dhgwcjdo][/b:dhgwcjdo]
        Jim
        Yes, interesting. Does this mean forms can be created using VB express, and used from SketchUp/Ruby?
        Is it available across platforms (on a Mac?)
        • OscarLokO
          OscarLok
          Hai Jim,
          There is an example inside the zip file.
          Yes! The forms is created using VB.Net(free version), and call by SketchUp(MUST be ver 7.1...) ruby.
          We can pass the parameter to the form and pass back to SU. It shows in the latest youtube video.
          I never try it on Mac, and the dll is build on Windows PC.
          • T
            tomot
            I'm curious?
            Does that mean that Grasshopper VB.net code samples can run under Ruby?
            my plugins
            tomot
            • OscarLokO
              OscarLok
              Hi tomot,
              May I know that where I can get Grasshopper VB.net code samples, please?
              I do try to search in this forum but no result.
              • T
                toxicvoxel
                Tomot,
                Grasshopper uses the Rhino graphics engine and wouldn't run separately. Unless you wish to execute the grasshopper script, let Rhino do the processing and then return the geometry to Sketchup. - Which would be a little silly as there will be easier ways to achieve it.
                By the way, calling .NET/COM code from SU Ruby has been available since the first release through ole32.
                Talking the other way is a different matter. That is why I have asked for a ruby script to be executable through the Sketchup COM API. Initially HQ agreed it was a good idea but for whatever reason the didn't implement it (since last I checked).
                Maybe Oscar will be so kind as to let us know how he achieves the bridge.
                • T
                  tomot
                  Hi tomot,
                  There are no "Grasshopper VB.net code samples: in this forum, but there are here:
                  http://en.wiki.mcneel.com/default.aspx/McNeel/GrassHopperGallery.html
                  my plugins
                  tomot
                  • T
                    tomot
                    thanks, I'm also just simply, trying to expand my general understanding πŸ˜„
                    my plugins
                    tomot
                    • OscarLokO
                      OscarLok
                      This is the example ruby script :
                      def test
                      input = UI.inputbox ["Ruby says"], ["Hello! VB!"], "Make Friend with VB"
                      OscarVB.dialog(File.join(File.dirname(__FILE__),"HelloVB.exe"))
                      OscarVB.execute_script("HelloVB.exe","Label2_text","Ruby says ; " + input[0])
                      OscarVB.execute_script("HelloVB.exe","TextBox1_text","Hello! RB!")
                      The below is the VB.net script :
                      Public Class Form1
                      Dim rb As New OscarRB.Ruby
                      I use this two ruby script to call and pass parameter to the below VB.net Sub.
                      OscarVB.execute_script("HelloVB.exe","Label2_text","Ruby says : " + input[0])
                          Sub Label2_text(ByVal tx As String)
                              Label2.Text = tx
                          End Sub
                          Sub TextBox1_text(ByVal tx As String)
                              TextBox1.Text = tx
                          End Sub
                      This is the way we start to connect ruby and vb.net. It is a MUST.
                          Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
                              rb.Open(Me)
                          End Sub
                      Using "End" to Exit the VB.net form.
                          Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
                              End
                          End Sub
                      This is how we execute a ruby script in the VB.net form.
                          Private Sub TextBox1_Leave(ByVal sender As Object, ByVal e As System.EventArgs) Handles TextBox1.Leave
                              rb.execute_script(Me, "draw_text", TextBox1.Text)
                          End Sub
                      End Class
                      • OscarLokO
                        OscarLok
                        There is a Released Version of OscarVB in the first post.
                        The two bridges are inside the zip file.
                        And the free version of VB 2008 Express can be download from the Jim post above. πŸ‘
                        Thank You!
                        • OscarLokO
                          OscarLok
                          This is the youtube link. (I do not know how to get the video inside this forum. 😳 ) Thank You πŸ‘
                          [flash=560,340:2jyf8wrk]http://www.youtube.com/v/hGjFK5o9g-I&hl=en&fs=1&[/flash:2jyf8wrk]
                          This shows the latest version is more stable. πŸŽ‰
                          [flash=560,340:2jyf8wrk]http://www.youtube.com/v/ljVn-F7qxqQ&hl=en&fs=1&[/flash:2jyf8wrk]
                            ssyed1984
                            Hi Oscar,
                            Could you please just share the source code of your VB.net. It will be useful for me
                            Thanks in advance !!
                              Marthmatica
                              Who just loads up some guys exes and dlls with no source? Geez, just load up the vb project.
