    Kitchen reno
    51 Posts 12 Posters 6.1k Views 12 Watching
    • X Offline
      xrok1
      i'm going to try unlocking the color channel and making it white, then using the texture just to bump it and see what happens. will post results.
      • X Offline
        xrok1
        i also decided to change the paint from eggshell to semi-gloss and increase the sky brightness to 1.5, we'll see what happens. 😕
        i guess the next step will be sky portals if that doesn't work. but can you see background through sky portals? i do plan on adding a background.
        • E Offline
          Ecuadorian
          Sky portals only allow for more skylight to enter the room. 😎 If you're using the physical sky this will just produce a small blue cast in your kitchen.
          The problem, as I see it, is that unless you have some direct light reaching the ceiling, it will look relatively dark. A hanging lamp, for example, showers the ceiling with direct light, but the kind of fixtures you're using do not. How about adding a couple of apliqués?
          -Miguel Lescano
          • X Offline
            xrok1
            i really don't want to add lights just to make the render look better when i have no intention to add these lights for real. i switched to the linear tone mapping and that seems to be helping. i'll post a render in a couple of hours.
            • X Offline
              xrok1
              any better?
              AFTER
              BEFORE
                d12dozr
                Definitely better - good work, I've been closely following this thread.
                http://goo.gl/f7ooYh
                • X Offline
                  xrok1
                  thank you! 😄
                  • X Offline
                    xrok1
                    As for the space above the cabinets I've never really seen anything very appealing myself. I prefer the cabinets to go all the way up personally. They end up going way too high to be used on an every day basis but you can always put junk up there you don't need often.
                    -Brodie
                    what would you think of boxing in the tops and doing drywall? i'm considering trying that. 💭
                    complete with crown molding of course. 😉
                    • X Offline
                      xrok1
                      here it is with the tops boxed in and a redesign on cupboard construction:
                      what do you all think?
                      • X Offline
                        xrok1
                        OOH! gotta love the MLT, 109-passes 5.5-hours . 😄
                        • X Offline
                          xrok1
                          found this light at homedepot and just had to put it in 😄
                            Click Draw
                            Rocky ,
                            Looking good. Put a nice crown molding around the top of the cabinets. It is always a nice detail. Maybe a threshold on the joint on floor between tile and wood floor. Put a floor to top of cabinet gable on the right side of the fridge. Some handles....long brushed finish. Blah blah blah..... Looking good. Keep posting.
                            Jeff
                            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                              d12dozr
                              Rocky, the new light looks great!
                              ...but I got a bone to pick with you though - the view out your windows sucks! 👊 😄
                              Its easy to fix though...takes 5 minutes
                              -find an image you like
                              -import into SU
                              -project it onto a semicircle strategically placed outside your window
                              -hide or delete the original image
                              Here is a cabinet install project I did recently. I just searched for something like "Alaska mountains" for the image. The customer was tickled that his home value increased by $3 Mil 💚
                              The geometry
                              The finished view
                              • X Offline
                                xrok1
                                i was actually thinking of taking a picture on site to put in the background but don't know the best way to go about it.
                                besides i too busy actually working on the project. not the soft (SU) one but the hard (skin your knuckles) one. 😆
                                remind me to post some pictures of this place, a real shit hole. (before my magic touch of course) 🤣
                                • X Offline
                                  xrok1
                                  found some new track and wall lights at Rona 😄
                                  thanks again Equadorian for the awesome light shade material!
                                  • E Offline
                                    Ecuadorian
                                    😲 Wow, just look at the difference with the first image in this thread, just five weeks ago. I see this kitchen design has been quite a journey for you.
                                    September 25:
                                    http://www.forums.sketchucation.com/download/file.php?id=34031&t=1
                                    November 02:
                                    http://www.forums.sketchucation.com/download/file.php?id=36268&t=1
                                    -Miguel Lescano
                                    • X Offline
                                      xrok1
                                      yes, i'm living and breathing this damn project!
                                      but it is fun. and i think spending this much design time is really helping on site. when i'm working there i never have to pause for a minute to think about how something is going to look, i can just keep working and i feel as though i've already built it once before. 🤓
                                      • X Offline
                                        xrok1
                                        hey i found a picture of what i started with. trust me it was worse than it looks:
                                        http://by113w.bay113.mail.live.com/mail/SafeRedirect.aspx?hm__tg=http://65.54.168.249/att/GetAttachment.aspx&hm__qs=file%3D44fd8e3a-e4b3-46b7-838a-45ef3bd48231.jpg%26ct%3DaW1hZ2UvanBlZw_3d_3d%26name%3DMDAwMTgzODlMMDIuanBn%26inline%3D1%26rfc%3D0%26empty%3DFalse%26imgsrc%3Dcid%253aAD99660729CA4A58BDE8F1BFD76C2162%2540DJHKXB71&oneredir=1&ip=10.1.106.211&d=d2784&mf=0&a=01_f3e80dbeda569d8d2651a5e94b32705844e8aef495943a139b6a507ef0d46b18
                                        the window you can see on the left is where the patio door is in the render. the built-in desk on the right in the render is where the fridge and stove are in the photo.
                                        • dermotcollD Offline
                                          dermotcoll
                                          Hi xrok1
                                          pic not showing up on your post!! By the way love the job your doing on the renders - making me very jealous!!!! I know I make really cool kitchens but am totally embarassingly rubbish at modelling / rendering them!!!
                                          When you burn your arse - you gotta sit on the blisters!!
                                          • X Offline
                                            xrok1
                                            sorry! 😳
                                            the window you can see on the left is where the patio door is in the render. the built-in desk on the right in the render is where the fridge and stove are in the photo.The wall you see in the foreground is now gone except for a column where the light switches will be.
                                            • 2 / 3
