    Removal of unwanted internal polys (lines)?
    5 Posts 3 Posters 538 Views 3 Watching
      tomot
      This first, X-ray view pic shows some unwanted internal polys in this joint transition, highlighted in blue. Under normal SU conditions this would not create a problem.
      But if one were to do a remeshing procedure using an external program of this joint (ie. Do-Sabin) This joint would split into 4 individual pieces. However removing the internal polys (lines) before and then doing a Do-Sabin would create a uniform 1 piece joint.
      Is is possible to construct a Ruby script capable of Identifying and deleting all unused internal polys (lines) in an SU file?
      my plugins
      tomot
        MSP_Greg
        tomot,
        A key word might be 'internal.' See --
        Deleting Unnecessary Edges
        Posted by Sandra Winstead, SketchUp Team Have you ever opened a SketchUp file that you didnโ€™t create, or imported a model from another appli...
        (sketchupapi.blogspot.com)
        HTH,
        Greg
          you have this plug by Wikii remove inner face faces who can maybe help you ๐Ÿ˜‰
            tomot
            MSP_Greg & Pilou thanks for input. But I can't get either rubies to do what they advertise.
            I'm interested if you come up with the same results, try the attached file please
            tryarm.skp
            my plugins
            tomot
              Problem is that the internal "square faces" are not coplanar! ๐Ÿ˜ฎ
              So ruby "remove inner face" cant work ๐Ÿ˜’
              So you must ask a request in the Ruby section
              with a title like [REQ]Select internal lines
              don't believe that plug yet exist ๐Ÿ˜„
