    Convert MaxScript to Ruby?
    6 Posts 4 Posters 1.2k Views 4 Watching
      Arightwizard
      since my last topic seems to have gone down without an answer (nothing I didn't expect), I would like to ask if it is possible to convert MaxScript [scripting for Gmax and 3ds Max, .ms file extension] to Ruby.
      Or if that is not possible, then maybe to be able to embedd MaxScript to be used in Ruby. Or simply configure Sketchup to use MaxScript.
      To answer any of these questions would mean a lot to me and it would literally change the experience of 3D modeling for games.
      Thank you,
      -Arightwizard
      • tbdT
        tbd
        what do you need it for - be more specific
        a conversion from MXS to SURuby needs a lot of work and it will not be 100% translation. it all depends on what do you want to accomplish.
        http://plugins.ro
          Arightwizard
          I am trying to convert a .jms exporter from MaxScript to Ruby called Chimp (Version 1.6).
          I am no expert in this situation, but here is the MaxScript code for chimp.ms:
          -- Copyright Β© 2004 Dark Knight Software
          -- Programmed by Jason Zimmer
          -- Chimp Halo Structure Exporter
          -- Version 1.6
          Utility Chimp "Chimp"
          	Rollout Structure "Chimp; Jms Exporter"
          		local ChimpMaterials
          		local ChimpVerts
          		local ChimpFaces
          		local ChimpTVerts
          		local ChimpNormals
          		local ChimpReverseLookup
          		local ChimpFaceIds
          		local ChimpCurrVert
          		local ChimpVertexOffset
          		local ChimpError
          		Button Export "Export Halo Structure"
          		RadioButtons OutputMode Labels;#("Jms File", "Listener Window") default;1
          		CheckBox ShowDebug "Write Debug Info" checked;true
          		fn AddError v1 v2 v3 Id =
          			SetNumVerts ChimpError ((GetNumVerts ChimpError) + 3) true
          			SetNumFaces ChimpError ((GetNumFaces ChimpError) + 1) true
          			SetVert ChimpError ((GetNumVerts ChimpError) - 2) v1
          			SetVert ChimpError ((GetNumVerts ChimpError) - 1) v2
          			SetVert ChimpError ((GetNumVerts ChimpError) - 0) v3
          			SetFace ChimpError (GetNumFaces ChimpError) ((GetNumVerts ChimpError) - 2) ((GetNumVerts ChimpError) - 1) ((GetNumVerts ChimpError) - 0)
          			SetFaceMatId ChimpError (GetNumFaces ChimpError) Id
          		fn ParseMaterials Obj =
          			local i, j, Valid
          			if SuperClassOf Obj == GeometryClass then
          				ObjName = Obj.name
          				if ObjName != "ChimpClone" then
          					copy Obj name;"ChimpClone"
          					Obj = $ChimpClone
          					CollapseStack Obj
          					ConvertToMesh Obj
          					if ClassOf Obj.material == MultiMaterial then
          						for i in 1 to Obj.material.count do
          							Valid = 0
          							for j in 1 to Obj.numfaces do
          								if i == (GetFaceMatId Obj j) then
          									Valid = 1
          							if Valid == 1 then
          								for j in 1 to ChimpMaterials.count do
          									if ChimpMaterials[j] == Obj.material[i].name then
          										Valid = 0
          								if Valid == 1 then
          									append ChimpMaterials Obj.material[i].name
          									if ShowDebug.checked == true then ( format "  Material %; %\n" ChimpMaterials.count Obj.material[i].name )
          					)else if ClassOf Obj.material == StandardMaterial then
          						Valid = 1
          							if ChimpMaterials[j] == Obj.material.name then
          								Valid = 0
          						if Valid == 1 then
          							append ChimpMaterials Obj.material.name
          							if ShowDebug.checked == true then ( format "  Material %; %\n" ChimpMaterials.count Obj.material.name )
          					)else(
          						if ShowDebug.checked == true then ( format "  Chimp Warning; Object '%' is using a bogus material type. Needs to be MultiMaterial or StandardMaterial\n" ObjName )
          				Delete Obj
          			)else(
          				if ShowDebug.checked == true then ( format "  Chimp Warning; Could not convert object '%' into a mesh\n" ObjName )
          		fn ProcessGeometry Obj =
          			local i, j, k, l, f, n, v1, v2, v3, n1, n2, n3, nf, OrigObj, nv1, nv2, nv3
          				ObjName = Obj.name
          					Obj = $ChimpClone
          					CollapseStack Obj
          					ConvertToMesh Obj
          					if ShowDebug.checked == true then ( format "  Processing Object '%' (F;% V;%)\n" ObjName Obj.numfaces Obj.numverts )
          					-- Build Normal Reverse Lookup
          					ChimpReverseLookup = #()
          					for i in 1 to Obj.numfaces do
          						f = GetFace Obj i
          						-- Build Reverse Lookup (For Normals)
          						if ChimpReverseLookup[f[1]] == undefined then ( ChimpReverseLookup[f[1]] = #() )
          						if ChimpReverseLookup[f[2]] == undefined then ( ChimpReverseLookup[f[2]] = #() )
          						if ChimpReverseLookup[f[3]] == undefined then ( ChimpReverseLookup[f[3]] = #() )
          						append ChimpReverseLookup[f[1]] i
          						append ChimpReverseLookup[f[2]] i
          						append ChimpReverseLookup[f[3]] i
          					ProgressStart ("Processing '" + ObjName + "'")
          						ProgressUpdate (i * 100 / Obj.numfaces)
          						f = GetFace Obj i
          						-- Build Face
          						append ChimpFaces [ChimpCurrVert + 0, ChimpCurrVert + 1, ChimpCurrVert + 2]
          						-- Build 3 Vertecies
          						v1 = (GetVert Obj f[1])
          						v2 = (GetVert Obj f[2])
          						v3 = (GetVert Obj f[3])
          						append ChimpVerts v1
          						append ChimpVerts v2
          						append ChimpVerts v3
          						-- Build Normals
          						for j in 1 to 3 do
          							nf = GetFace Obj i
          							nv1 = (GetVert Obj nf[1])
          							nv2 = (GetVert Obj nf[2])
          							nv3 = (GetVert Obj nf[3])
          							n1 = normalize (nv1 - nv2)
          							n2 = normalize (nv1 - nv3)
          							n = cross n1 n2
          							for k = 1 to ChimpReverseLookup[f[j]].count do
          								l = ChimpReverseLookup[f[j]][k]
          								if (GetFaceMatId Obj l) == (GetFaceMatId Obj i) then
          									if (GetFaceSmoothGroup Obj l) == (GetFaceSmoothGroup Obj i) then
          										nf = GetFace Obj l
          										n3 = cross n1 n2
          										n = n + n3
          							n = Normalize n
          							append ChimpNormals n
          						-- Build Material Id
          							Valid = 0
          							l = GetFaceMatId Obj i
          							if l <= Obj.material.count then
          									if ChimpMaterials[j] == Obj.material[l].name then
          										Valid = 1
          										append ChimpFaceIds j
          							if Valid == 0 then
          								if ShowDebug.checked == true then ( format "Chimp Error; Object '%' has an unknown material id. See Orange Error Geometry.\n" ObjName )
          								append ChimpFaceIds 0
          								AddError v1 v2 v3 1
          							Valid = 0
          									Valid = 1
          							if Valid == 0 then
          								ChimpWarning = 1
          								AddError v1 v2 v3 1
          						)else(
          						-- Build 3 Texture Coordinates
          						if (GetNumTVerts Obj) > 0 then
          							f = GetTVFace Obj i
          							append ChimpTVerts (GetTVert Obj f[1])
          							append ChimpTVerts (GetTVert Obj f[2])
          							append ChimpTVerts (GetTVert Obj f[3])
          						)else(
          							append ChimpTVerts [0, 0, 0]
          						-- Increment Counters
          						ChimpCurrVert = ChimpCurrVert + 3
          				Delete Obj
          			)else(
          		fn WriteJms =
          			local Jms, i
          			SavePath = GetSaveFileName Types;"Halo Structure File (*.jms)|*.jms|"
          			if SavePath != undefined then
          				format " Saving '%'..." SavePath
          				Jms = CreateFile(SavePath)
          				format "8200\n" to;Jms
          				format "3251\n" to;Jms
          				format "1\n" to;Jms
          				format "frame\n" to;Jms
          				format "-1\n" to;Jms
          				format "0.000000	0.000000	0.000000	1.000000\n" to;Jms
          				format "%	%	%\n" $frame.pos.x $frame.pos.y $frame.pos.z to;Jms
          				format "%\n" ChimpMaterials.count to;Jms
          				for i in 1 to ChimpMaterials.count do
          					format "%\n" ChimpMaterials[i] to;Jms
          					format "<none>\n" to;Jms
          				format "0\n" to;Jms
          				format "1\n" to;Jms
          				format "unnamed\n" to;Jms
          				format "%\n" ChimpVerts.count to;Jms
          				ProgressStart "Writing Data"
          				for i in 1 to ChimpVerts.count do
          					ProgressUpdate (i * 100 / (ChimpVerts.count + ChimpFaces.count))
          					format "0\n" to;Jms
          					format "%	%	%\n" ChimpVerts[i].x ChimpVerts[i].y ChimpVerts[i].z to;Jms
          					format "%	%	%\n" ChimpNormals[i][1] ChimpNormals[i][2] ChimpNormals[i][3] to;Jms
          					format "0\n" to;Jms
          					format "%\n" ChimpTVerts[i][1] to;Jms
          					format "%\n" ChimpTVerts[i][2] to;Jms
          					format "0\n" to;Jms
          				format "%\n" ChimpFaces.count to;Jms
          				for i in 1 to ChimpFaces.count do
          					ProgressUpdate ((i + ChimpVerts.count) * 100 / (ChimpVerts.count + ChimpFaces.count))
          					format "0\n" to;Jms
          					format "%\n" (ChimpFaceIds[i] as integer - 1) to;Jms -- Material
          					format "%	%	%\n" (ChimpFaces[i][1] as integer - 1) (ChimpFaces[i][2] as integer - 1) (ChimpFaces[i][3] as integer - 1) to;Jms
          				Close Jms
          				format "Done.\n"
          			)else(
          				format " Save canceled.\n"
          		fn WriteListener =
          			local i
          			if ShowDebug.checked == true then ( format "***** Begin Jms *****\n" )
          			format "8200\n"
          			format "3251\n"
          			format "1\n"
          			format "frame\n"
          			format "-1\n"
          			format "-1\n"
          				format "<none>\n"
          			format "0\n"
          			format "1\n"
          			format "unnamed\n"
          				format "0\n"
          				format "-1\n"
          				format "0\n"
          				format "0\n"
          				format "0\n"
          			if ShowDebug.checked == true then ( format "***** End Jms *****\n" )
          		on Export Pressed do
          			local i
          			ClearListener()
          			if ShowDebug.checked == true then ( format "----------------------------------------\n" )
          			if ShowDebug.checked == true then ( format "Chimp; Start...\n" )
          			if SuperClassOf $ChimpError == GeometryClass then
          				delete $ChimpError
          			ChimpError = Box()
          			ChimpError.Name = "ChimpError"
          			ConvertToMesh ChimpError
          			SetNumVerts ChimpError 0
          			SetNumFaces ChimpError 0
          			ChimpError.Material = MultiMaterial numsubs;1
          			-- Material Error
          			ChimpError.Material[1].DiffuseColor = color 255 160 0
          			Update ChimpError
          			if SuperClassOf $frame == GeometryClass then
          				if $frame.children.count == 0 then
          					MessageBox "Chimp Error; There is no geometry linked to the frame"
          				)else(
          					-- Parse Materials
          					if ShowDebug.checked == true then ( format " Parsing Materials\n" )
          					ChimpMaterials = #()
          					for i in 1 to $frame.children.count do
          						ParseMaterials $frame.children[i]
          					if ChimpMaterials.count != 0 then
          						-- Geometry
          						if ShowDebug.checked == true then ( format " Parsing Geometry\n" )
          						ChimpVerts = #()
          						ChimpFaces = #()
          						ChimpTVerts = #()
          						ChimpNormals = #()
          						ChimpFaceIds = #()
          						ChimpCurrVert = 1
          						ChimpVertexOffset = 0
          							ProcessGeometry $frame.children[i]
          						if ShowDebug.checked == true then ( format "  Verts; %\n" ChimpVerts.count )
          						if ShowDebug.checked == true then ( format "  Faces; %\n" ChimpFaces.count )
          						if (GetNumVerts ChimpError) > 0 then
          							MessageBox "Chimp found errors. View the 'ChimpError' Object and fix the corrosponding faces"
          						)else(
          							if OutputMode.state == 1 then ( WriteJms() )
          							if OutputMode.state == 2 then ( WriteListener() )
          					)else(
          						MessageBox "Chimp Error; Unable to find any used materials.\n Ensure your objects have materials properly assigned to them."
          			)else(
          				MessageBox "Chimp Error; 'frame' object was not found."
          			if ShowDebug.checked == true then ( format "Chimp; End\n" )
          			ChimpVerts = undefined
          			ChimpFaces = undefined
          			ChimpTVerts = undefined
          			ChimpNormals = undefined
          			ChimpFaceIds = undefined
          			gc()
          			ProgressEnd()
          	Rollout Wrl "Chimp; Wrl Importer"
          		local Wrl, l, Data, DataPos
          		local ChimpError
          		local ChimpErrorVert
          		local ChimpErrorFace
          		local ChimpErrorNum
          		Button Import "Import Wrl"
          		fn ProcessIndexedLineSet =
          			format " +ProcessIndexedLineSet \n"
          			ChimpError.name = "ChimpEdgeError" + (ChimpErrorNum as string)
          			DataPos = DataPos + 1	-- Skip IndexedLineSet
          			DataPos = DataPos + 1	-- Skip {
          			DataPos = DataPos + 1	-- coordIndex
          			while DataPos <= Data.count do
          				if Data[DataPos] == "}" then ( exit )
          				f = [ (Data[DataPos + 0] as integer) + 1, (Data[DataPos + 1] as integer) + 1, (Data[DataPos + 1] as integer) + 1 ]
          				ChimpErrorFace = ChimpErrorFace + 1
          				SetNumFaces ChimpError ChimpErrorFace true
          				SetFace ChimpError ChimpErrorFace f
          				SetEdgeVis ChimpError ChimpErrorFace 1 true
          				DataPos = DataPos + 3
          		fn ProcessIndexedFaceSet =
          			format " +ProcessIndexedFaceSet \n"
          			DataPos = DataPos + 1	-- Skip IndexedFaceSet
          				f = [ (Data[DataPos + 0] as integer) + 1, (Data[DataPos + 1] as integer) + 1, (Data[DataPos + 2] as integer) + 1 ]
          				while Data[DataPos] != "-1" do
          		fn ProcessMaterial =
          			format " +ProcessMaterial\n"
          			DataPos = DataPos + 1	-- Skip Material
          		fn ProcessMaterialBinding =
          			format " +ProcessMaterialBinding\n"
          			DataPos = DataPos + 1	-- Skip MaterialBinding
          		fn ProcessCoordinate3 =
          			format " +ProcessCoordinate3\n"
          			DataPos = DataPos + 1	-- Skip Coordinate3
          			DataPos = DataPos + 1	-- Skip point
          				p = point3 (Data[DataPos + 0] as float) (Data[DataPos + 1] as float) (Data[DataPos + 2] as float)
          				ChimpErrorVert = ChimpErrorVert + 1
          				SetNumVerts ChimpError ChimpErrorVert true
          				SetVert ChimpError ChimpErrorVert p
          		fn ProcessSeparator =
          			format "+ProcessSeparator\n"
          			DataPos = DataPos + 1	-- Skip Skip Separator
          			ChimpErrorNum = ChimpErrorNum + 1
          			ChimpError = Box()
          			ChimpError.name = "ChimpFaceError" + (ChimpErrorNum as string)
          			ChimpErrorVert = 0
          			ChimpErrorFace = 0
          				if Data[DataPos] == "Coordinate3" then ( ProcessCoordinate3() )
          				if Data[DataPos] == "MaterialBinding" then ( ProcessMaterialBinding() )
          				if Data[DataPos] == "Material" then ( ProcessMaterial() )
          				if Data[DataPos] == "IndexedFaceSet" then ( ProcessIndexedFaceSet() )
          				if Data[DataPos] == "IndexedLineSet" then ( ProcessIndexedLineSet() )
          			Update ChimpError
          		fn ProcessData =
          			DataPos = 1
          			ChimpErrorNum = 0
          				if Data[DataPos] == "Separator" then ( ProcessSeparator() )
          		on Import Pressed do
          			local FileName
          			local Temp
          			FileName = GetOpenFileName Types;"VRML Files (*.wrl)|*.wrl|"
          			Data = #()
          			if FileName != undefined then
          				ClearListener()
          				Wrl = OpenFile FileName
          				ReadLine Wrl
          				DataString = ""
          				while 1 == 1 do
          					try
          						l = TrimLeft (ReadLine Wrl)
          					catch
          						exit
          					Temp = FilterString l " ,[]"
          					Join Data Temp
          				Close Wrl
          				ProcessData()
          	Rollout Surface "Chimp; Walking Surface"
          		Button Show "Show Walking Surfaces"
          		RadioButtons ShowMode labels;#("Show All", "Show Walkable Only", "Show Unwalkable Only") default;1
          		local ChimpSurface
          			local i, f, cv, n, u, w, Valid, c45
          				ObjName = Obj.name
          					Obj = $ChimpClone
          					CollapseStack Obj
          					ConvertToMesh Obj
          					c45 = cos 45
          						f = GetFace Obj i
          						cv = GetNumVerts ChimpSurface
          						n = GetFaceNormal Obj i
          						w = Dot n [0, 0, 1]
          						Valid = 0
          						if ShowMode.state == 1 then ( Valid = 1 )
          						if ShowMode.state == 2 And w >= c45 then ( Valid = 1 )
          						if ShowMode.state == 3 And w < c45 then ( Valid = 1 )
          						if Valid == 1 then
          							SetNumVerts ChimpSurface (cv + 3) true
          							SetVert ChimpSurface (cv + 1) ((GetVert Obj f[1]) + (n * 0.2))
          							SetVert ChimpSurface (cv + 2) ((GetVert Obj f[2]) + (n * 0.2))
          							SetVert ChimpSurface (cv + 3) ((GetVert Obj f[3]) + (n * 0.2))
          							SetNumFaces ChimpSurface ((GetNumFaces ChimpSurface) + 1) true
          							SetFace ChimpSurface (GetNumFaces ChimpSurface) (cv + 1) (cv + 2) (cv + 3)
          							if w >= c45 then
          								SetFaceMatId ChimpSurface (GetNumFaces ChimpSurface) 1
          							)else(
          								SetFaceMatId ChimpSurface (GetNumFaces ChimpSurface) 2
          				Delete Obj
          			)else(
          		on Show Pressed do
          			local i
          			ClearListener()
          			if SuperClassOf $ChimpSurface == GeometryClass then ( delete $ChimpSurface )
          			ChimpSurface = Box()
          			ConvertToMesh ChimpSurface
          			SetNumFaces ChimpSurface 0
          			SetNumVerts ChimpSurface 0
          			ChimpSurface.name = "ChimpSurface"
          			ChimpSurface.material = MultiMaterial numsubs;2
          			ChimpSurface.material[1].diffusecolor = color 0 128 0
          			ChimpSurface.material[2].diffusecolor = color 255 0 0
          				)else(
          					-- Geometry
          			)else(
          			Update ChimpSurface
          			Select ChimpSurface
          	Rollout Info "Chimp; Info"
          		Label lbl1 "Chimp v1.6"
          		Label lbl2 "Created by Jason Zimmer"
          		Label lbl3 "www.darkknightsoftware.com"
          	on Chimp Open do
          		AddRollout Structure
          		AddRollout Wrl
          		AddRollout Surface
          		AddRollout Info
          	on Chimp Close do
          		RemoveRollout Structure
          		RemoveRollout Wrl
          		RemoveRollout Surface
          		RemoveRollout Info
          • RunnerPackR
            RunnerPack
            BTW, jms files are meshes for use in the PC game Halo (don't sue me MS! πŸ˜‰ ).
            If anyone is crazy enough to do this, I found a (supposedly) better plugin called "Bluestreak" here (direct link to script).
            If this much time is to be spent, it should probably at least be used to convert the best example, no? Also, it might help in understanding the code to compare the two...
            I just want to (politely) point out to Arightwizard how incredibly difficult this task is (with very little payoff). You're probably better off just learning to use GMax/3DS...
            You might have noticed... I'm a bit of a ferpectionist.
              Arightwizard
              Runnerpack, I have little difficulty using GMax - and I know that converting scripts would be difficult. I was wondering if such a thing was possible, now all that's left is for me to learn Ruby and some more MaxScript before being able to come up with what would probably change the way common HCE maps are made. And trust me, the last steps won't take long.
              So I thank RunnerPack and TBD for trying to help me, and believe me, you did.
              -Arightwizard
              • Chris FullmerC
                Awesome, sounds great! Let us know if you need any help with it,
