    Hospital Interiors (Maxwell Render)
    28 Posts 12 Posters 3.0k Views 12 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Hi Brodie, Hmmm..... Perhaps now that 3d is becoming more popular, a lay person can be expected to see a 3d plan. I have drawn blank stares by company presidents with 3d plans (they really do not know what they were looking at). If you attend presentation to lay-persons with a larger 3d floor plan, please let us know how it goes.
      Don't know how others do it, but in conjunction with modeling the space, the interior elevations are viewed in 2d in order to visually study the location, and proportions of the wall elements. Many times I do this outside SU, with my production Cad because by then I am moving into production drawings. Guess that I'm just a old f**t, unable to shed the way I learned how to design. When that happens, I rarely go back to amend the model..
      • RichardR Offline
        Richard
        Wow REALLY nice work again brodes!!!
        Mate i'd probably have used an MXI emitter for the ceiling diffusers, that way you could get the flouro's showing through look. The lights as they are just lack that bit of oumf!
        BUILTBRAND.COM.AU
        • brodieB Offline
          brodie
          Richard,
          Always good to get your input.
          Yeah, that's a great idea about using mxi's for the lights. I'll definately have to try that next time. That raises my mxi complaint though which is that there doesn't seem to be a way to adjust the power of the emitter within the material itself 😞 Always have to do it in multilight even for quick test renderings.
          -Brodie
          • EarthMoverE Offline
            EarthMover
            Really great stuff Brodie...as usual. I could smell hospital just by looking at the renders. The floor is suburb. In the 3D plan views, I think removing the near wall to expose the main hallway would not make them feel so boxed in. Other than that, I'm amazed.
            Content Creator at Skapeup
            • brodieB Offline
              brodie
              Probably a good point about the wall. Thanks. The camera position was a bit tricky. I was already going way overboard for what the interiors dept. was expecting. If I showed too much hallway I would have had to model some pretty tricky stuff. But I could have pulled it over or forward more and still been alright I think.
              I actually reduced the glossiness a lot from where it was originally. The reflection from the 2x4 lights above was really strong. I need to make a good bump to give the floor tile some variation so the reflection doesn't give away that the floor is perfectly flat I think.
              -Brodie
              • RichardR Offline
                Richard
                I know what you mean Brodes! There isn't a lot of control over MXI or HDRI even under Multilight.
                Btw if next time you do use an MXI for the diffuser lights I'd suggest using two emitters, one hidden and one as the light panel glow! Using just the MXI as I did in the little insert picture, when adjusting the light up you can quickly burn out the effect you are after!
                BUILTBRAND.COM.AU
                • brodieB Offline
                  brodie
                  Wait, what? I thought that was a reference photo to illustrate your point? I should have known better with you! πŸ˜„
                  -Brodie
                  • RichardR Offline
                    Richard
                    -Brodie
                    Just about had you hey!
                    Here mate is the map for your MXI!
                    BUILTBRAND.COM.AU
                      teofas
                      great work bro!
                      http://www.spazioarquitectura.com
                      • brodieB Offline
                        brodie
                        Richard, thanks. I'll adapt that and give it a shot on some ceiling fluoro's.
                        Thanks Teofas.
                        -Brodie
                        • olisheaO Offline
                          olishea
                          These are amazing. Well done pal I bet they took you ages. πŸ‘
                          oli
                          • brodieB Offline
                            brodie
                            Took about 16 hours of work time all together. Not too terrible I think. I'm working on a lobby for the same hospital at the moment. Hope it turns out as well.
                            -Brodie
                            • 2 / 2
